[PATCH 01/16] beatnik: Move -Dxxx to configure.ac
Fri May 18 14:02:38 UTC 2018
On Fri, May 18, 2018 at 8:44 AM, Sebastian Huber <
> On 18/05/18 15:42, Joel Sherrill wrote:
>> On Fri, May 18, 2018 at 8:25 AM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedd
>> ed-brains.de>> wrote:
>>     On 18/05/18 15:21, Joel Sherrill wrote:
>>         On Fri, May 18, 2018 at 12:41 AM, Sebastian Huber
>>         <sebastian.huber at embedded-brains.de
>>         <mailto:sebastian.huber at embedded-brains.de>
>>         <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>>             On 16/05/18 17:09, Joel Sherrill wrote:
>>                 Updates #3425.
>>                   bsps/powerpc/beatnik/config/beatnik.cfg      | 2 +-
>>                   c/src/lib/libbsp/powerpc/beatnik/configure.ac
>>         <http://configure.ac>
>>                 <http://configure.ac> | 2 ++
>>                   2 files changed, 3 insertions(+), 1 deletion(-)
>>                 diff --git a/bsps/powerpc/beatnik/config/beatnik.cfg
>>                 b/bsps/powerpc/beatnik/config/beatnik.cfg
>>                 index 1190cad..05bea38 100644
>>                 --- a/bsps/powerpc/beatnik/config/beatnik.cfg
>>                 +++ b/bsps/powerpc/beatnik/config/beatnik.cfg
>>                 @@ -14,7 +14,7 @@ RTEMS_BSP_FAMILY=beatnik
>>                   #  This contains the compiler options necessary to
>>         select
>>                 the CPU model
>>                   #  and (hopefully) optimize for it.
>>                 -CPU_CFLAGS = -mcpu=7400 -D__ppc_generic
>>                 +CPU_CFLAGS = -mcpu=7400
>>                   #T. Straumann; disable sdata=eabi for now until CEXP
>>                 supports it -meabi -msdata=eabi
>>                     # optimize flag: typically -0, could use -O4 or -fast
>>                 diff --git
>>         a/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>>                 b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>>                 index a48007c..b332aaa 100644
>>                 --- a/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>>                 +++ b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>>                 @@ -34,6 +34,8 @@ Note that the policy can still be
>>         defined by
>>                 the application
>>                   CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK this feature is
>>         removed
>>                   and a little memory is saved.])
>>                   +AC_DEFINE(__ppc_generic, 1, [PowerPC model option])
>>                   # Explicitly list all Makefiles here
>>                   AC_CONFIG_FILES([Makefile])
>>             I would rather eliminate the only user of __ppc_generic in
>>             bsps/powerpc/include/rtems/powerpc/powerpc.h.
>>         I have file another ticket #3431 to address this and assigned
>>         it to you.
>>         I am committing my changes because they eliminate use of -D on
>>         the GCC command line
>>         and allow packages using rtems_waf to compile.
>>     Did you check that every consumer of these defines includes
>>     <bspopts.h> somehow?
>> powerpc.h fails to compile if it isn't provided.
> Are these defines only used in powerpc.h?
$ grep -lr __ppc_generic .
./c/src/lib/libbsp/powerpc/beatnik/configure.ac
./c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac
./c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac
./c/src/lib/libbsp/powerpc/mvme3100/configure.ac
./c/src/lib/libbsp/powerpc/qoriq/configure.ac
./c/src/lib/libbsp/powerpc/t32mppc/configure.ac
./bsps/powerpc/include/rtems/powerpc/powerpc.h
I didn't check the others. If it broke something because
someone wasn't writing defensive enough ifdef's, then
that code should be fixed to be more defensive.
powerpc.h had a default to #error
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180518/b1a42cd8/attachment-0002.html>
