[PATCH] covoar.cc: Correct build path checks for multiple executables.
Cillian O'Donnell
cpodonnell8 at gmail.com
Mon May 21 06:26:12 UTC 2018
On Sun, 20 May 2018, 22:33 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On 21 May 2018 at 02:29, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> On Sun, 20 May 2018, 15:35 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 20 May 2018 at 00:53, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>>> wrote:
>>>> On Sun, 20 May 2018, 00:45 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> It works.. Sorry I was using the right covoar but the wrong
>>>>> rtems-test. Ahh its nice to see the data back in the reports again. Did you
>>>>> manage to track down 2 exes with the mismatch in symbol size?
>>>> Great! so next is the parsing of the symbol file.
>>>> I couldn't manage to track down the mismatch.
>>>> I have pushed these to my master branch.
>>> The latest update to cov-tester-support branch (please have a look)
>>> parses the symbol-set ini file from the coverage script. The parsing
>>> is working but currently it's not generating reports, as covoar
>>> needs to be updated .
>> It's best if covoar reads it's own config file, otherwise it creates a
>> dependency on the tester. Scanning over the recent changes to covoar there,
>> it looks like it can already handle multiple sets, so the one ini with
>> multiple sets in it is the way to go.
> Okay, Understood.
>> Here are the things that I have done and that needs to be
>>> done in order to generate reports :
>>> I have added a symbol-sets.ini file and parsed it from the coverage
>>> script
>>> this is how it works :
>>> - The ini file can be updated with all the symbols, separated by ' ,
>>> ' (comma)
>> This is the way covoar is actually handling it now. You should test a
>> multi set ini and see if that's working.
> Yeah, I have seen it. will try with multiple sets.
>>> - The coverages splits them and makes a list of all the sets
>>> - The respective libraries are parsed from the libraries section.
>>> - It returns a dict with all the symbols and thir resp. library
>>> addresses.
>>> - The library addresses are absolute so it can be run from anywhere
>>> top of build tree is not necessary.
>>> This was a good idea but it's just that dependency issue we want to stay
>> away from. Covoar has something to find the build directory too, it just
>> hasn't been connected up yet, so running it from the top of the build
>> directory is ok for the moment.
> yes it can find the build directory. I was giving it a shot to do it from
> the script.
> If covoar's standalone working is a necessity then it surely needs to be
> working
> from covoar and shouldn't depend on the script.
It should be working from covoar and it will.
>> Probably the most pressing thing now is investigating those mismatch in
>> symbol size.
> any advice on where/how to look for it ?
Before what I was doing was examining the objdump of 2 exes, looking there
on the weekend i think the info messages mentioned which ones were having
trouble for which symbol. It says something like "couldn't merge coverage
map for some_symbol because sizes from exe != to size of other_exe. Look at
the objdump of exe and other_exe, search for some_symbol and compare the
dissasembly. There'll be more lines in one than the other, nop padding
probably. Then you had to find a check that was strict enough to chop the
end of the symbol in question at the right place but not so strict that it
chopped other symbols in the wrong place. However the method of obtaining
the symbols has changed, I'll have to have a look over the covoar changes
tonight to see what would be the equivalent method of checking this now.
Unless Chris or Joel come back with the answer before then.
Also there will probably be multiple ini's with different collections of
sets that the user could run so it would be good to give them some method
of choosing which ini they want, like coverage=score will feed score.ini to
covoar. You could try have a go at that.
> This way we can parse all the symbols from the same ini file.
>>> what needs to be done :
>>> - I have added #FIXME s in the code , those are the small fixes that
>>> would be needed .
>>> - The covoar needs to be updated. My proposal is that we can feed the
>>> parsed dict to the covoar instead of feeding the symbol file and
>>> letting
>>> covoar parse it ( As I mentioned previously).
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/56e60ffc/attachment-0002.html>
