[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon May 21 10:49:48 UTC 2018
On 21 May 2018 at 11:56, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On Sun, 20 May 2018, 22:33 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 21 May 2018 at 02:29, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> On Sun, 20 May 2018, 15:35 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 20 May 2018 at 00:53, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>>>> > wrote:
>>>>> On Sun, 20 May 2018, 00:45 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> It works.. Sorry I was using the right covoar but the wrong
>>>>>> rtems-test. Ahh its nice to see the data back in the reports again. Did you
>>>>>> manage to track down 2 exes with the mismatch in symbol size?
>>>>> Great! so next is the parsing of the symbol file.
>>>>> I couldn't manage to track down the mismatch.
>>>>> I have pushed these to my master branch.
>>>> The latest update to cov-tester-support branch (please have a look)
>>>> parses the symbol-set ini file from the coverage script. The parsing
>>>> is working but currently it's not generating reports, as covoar
>>>> needs to be updated .
>>> It's best if covoar reads it's own config file, otherwise it creates a
>>> dependency on the tester. Scanning over the recent changes to covoar there,
>>> it looks like it can already handle multiple sets, so the one ini with
>>> multiple sets in it is the way to go.
>> Okay, Understood.
>>> Here are the things that I have done and that needs to be
>>>> done in order to generate reports :
>>>> I have added a symbol-sets.ini file and parsed it from the coverage
>>>> script
>>>> this is how it works :
>>>> - The ini file can be updated with all the symbols, separated by '
>>>> , ' (comma)
>>> This is the way covoar is actually handling it now. You should test a
>>> multi set ini and see if that's working.
>> Yeah, I have seen it. will try with multiple sets.
>>>> - The coverages splits them and makes a list of all the sets
>>>> - The respective libraries are parsed from the libraries section.
>>>> - It returns a dict with all the symbols and thir resp. library
>>>> addresses.
>>>> - The library addresses are absolute so it can be run from anywhere
>>>> top of build tree is not necessary.
>>>> This was a good idea but it's just that dependency issue we want to
>>> stay away from. Covoar has something to find the build directory too, it
>>> just hasn't been connected up yet, so running it from the top of the build
>>> directory is ok for the moment.
>> yes it can find the build directory. I was giving it a shot to do it from
>> the script.
>> If covoar's standalone working is a necessity then it surely needs to be
>> working
>> from covoar and shouldn't depend on the script.
> It should be working from covoar and it will.
>>> Probably the most pressing thing now is investigating those mismatch in
>>> symbol size.
>> any advice on where/how to look for it ?
> Before what I was doing was examining the objdump of 2 exes, looking there
> on the weekend i think the info messages mentioned which ones were having
> trouble for which symbol. It says something like "couldn't merge coverage
> map for some_symbol because sizes from exe != to size of other_exe. Look at
> the objdump of exe and other_exe, search for some_symbol and compare the
> dissasembly. There'll be more lines in one than the other, nop padding
> probably. Then you had to find a check that was strict enough to chop the
> end of the symbol in question at the right place but not so strict that it
> chopped other symbols in the wrong place. However the method of obtaining
> the symbols has changed, I'll have to have a look over the covoar changes
> tonight to see what would be the equivalent method of checking this now.
> Unless Chris or Joel come back with the answer before then.
> Please have a look into this as I'm confused .
>From the messages it seems like there's something with
the base_sp.exe .
I tried to run objdum with -d , I'm getting an error
objdump: can't disassemble for architecture UNKNOWN!
what am I missing ?
Also there will probably be multiple ini's with different collections of
> sets that the user could run so it would be good to give them some method
> of choosing which ini they want, like coverage=score will feed score.ini to
> covoar. You could try have a go at that.
yeah I was planning something similar with the script
to let users choose the sets, and run all by default .
I guess it needs to be done from covoar to avoid dependancy.
I can have look into this.
> This way we can parse all the symbols from the same ini file.
>>>> what needs to be done :
>>>> - I have added #FIXME s in the code , those are the small fixes
>>>> that
>>>> would be needed .
>>>> - The covoar needs to be updated. My proposal is that we can feed
>>>> the
>>>> parsed dict to the covoar instead of feeding the symbol file and
>>>> letting
>>>> covoar parse it ( As I mentioned previously).
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/459cbad9/attachment-0002.html>
