[PATCH] covoar.cc: Correct build path checks for multiple executables.
Cillian O'Donnell cpodonnell8 at gmail.com
Mon May 21 11:09:44 UTC 2018
On Mon, 21 May 2018, 12:08 Cillian O'Donnell, <cpodonnell8 at gmail.com> wrote:
> On Mon, 21 May 2018, 11:49 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 21 May 2018 at 11:56, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> On Sun, 20 May 2018, 22:33 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 21 May 2018 at 02:29, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> On Sun, 20 May 2018, 15:35 Vijay Kumar Banerjee, <
>>>>>> On 20 May 2018 at 00:53, Vijay Kumar Banerjee <
>>>>>>> On Sun, 20 May 2018, 00:45 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> It works.. Sorry I was using the right covoar but the wrong
>>>>>>>> rtems-test. Ahh its nice to see the data back in the reports again. Did you
>>>>>>>> manage to track down 2 exes with the mismatch in symbol size?
>>>>>>> Great! so next is the parsing of the symbol file.
>>>>>>> I couldn't manage to track down the mismatch.
>>>>>>> I have pushed these to my master branch.
>>>>>> The latest update to cov-tester-support branch (please have a look)
>>>>>> parses the symbol-set ini file from the coverage script. The parsing
>>>>>> is working but currently it's not generating reports, as covoar
>>>>>> needs to be updated .
>>>>> It's best if covoar reads it's own config file, otherwise it creates a
>>>>> dependency on the tester. Scanning over the recent changes to covoar there,
>>>>> it looks like it can already handle multiple sets, so the one ini with
>>>>> multiple sets in it is the way to go.
>>>> Okay, Understood.
>>>>> Here are the things that I have done and that needs to be
>>>>>> done in order to generate reports :
>>>>>> I have added a symbol-sets.ini file and parsed it from the coverage
>>>>>> script
>>>>>> this is how it works :
>>>>>>    - The ini file can be updated with all the symbols, separated by
>>>>>>    ' , ' (comma)
>>>>> This is the way covoar is actually handling it now. You should test a
>>>>> multi set ini and see if that's working.
>>>> Yeah, I have seen it. will try with multiple sets.
>>>>>>    - The coverages splits them and makes a list of all the sets
>>>>>>    -  The respective libraries are parsed from the libraries section.
>>>>>>    - It returns a dict with all the symbols and thir resp. library
>>>>>>    addresses.
>>>>>>    - The library addresses are absolute so it can be run from
>>>>>>    anywhere
>>>>>>    top of build tree is not necessary.
>>>>>> This was a good idea but it's just that dependency issue we want to
>>>>> stay away from. Covoar has something to find the build directory too, it
>>>>> just hasn't been connected up yet, so running it from the top of the build
>>>>> directory is ok for the moment.
>>>> yes it can find the build directory. I was giving it a shot to do it
>>>> from the script.
>>>> If covoar's standalone working is a necessity then it surely needs to
>>>> be working
>>>> from covoar and shouldn't depend on the script.
>>> It should be working from covoar and it will.
>>>>> Probably the most pressing thing now is investigating those mismatch
>>>>> in symbol size.
>>>> any advice on where/how to look for it ?
>>> Before what I was doing was examining the objdump of 2 exes, looking
>>> there on the weekend i think the info messages mentioned which ones were
>>> having trouble for which symbol. It says something like "couldn't merge
>>> coverage map for some_symbol because sizes from exe != to size of
>>> other_exe. Look at the objdump of exe and other_exe, search for some_symbol
>>> and compare the dissasembly. There'll be more lines in one than the other,
>>> nop padding probably. Then you had to find a check that was strict enough
>>> to chop the end of the symbol in question at the right place but not so
>>> strict that it chopped other symbols in the wrong place. However the method
>>> of obtaining the symbols has changed, I'll have to have a look over the
>>> covoar changes tonight to see what would be the equivalent method of
>>> checking this now. Unless Chris or Joel come back with the answer before
>>> then.
>>> Please have a look into this as I'm confused .
>> From the messages it seems like there's something with
>> the base_sp.exe .
>> I tried to run objdum with -d , I'm getting an error
>> objdump: can't disassemble for architecture UNKNOWN!
>> what am I missing ?
> It'll be a sparc-objdump that was built with the rsb in 5/bin/. I'm not
> sure if we're still grabbing the objdump using rtems-tools
Sorry *rtemstoolkit
> now, so not 100% sure that this still the way to investigate this.
>> Also there will probably be multiple ini's with different collections of
>>> sets that the user could run so it would be good to give them some method
>>> of choosing which ini they want, like coverage=score will feed score.ini to
>>> covoar. You could try have a go at that.
>> yeah I was planning something similar with the script
>> to let users  choose the sets, and run all by default .
>> I guess it needs to be done from covoar to avoid dependancy.
>> I can have look into this.
> This is different in that it's just allowing the user an easier way of
> choosing the right ini. So it wouldn't be a dependency like the other
> thing, if you run it manually you will still have to select the ini you
> want. So this will be part of the script.
>> This way we can parse all the symbols from the same ini file.
>>>>>> what needs to be done :
>>>>>>    - I have added #FIXME s in the code , those are the small fixes
>>>>>>    that
>>>>>>    would be needed .
>>>>>>    - The covoar needs to be updated. My proposal is that we can feed
>>>>>>    the
>>>>>>    parsed  dict to the covoar instead of feeding the symbol file and
>>>>>>    letting
>>>>>>    covoar parse it ( As I mentioned previously).
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/6e846a55/attachment-0002.html>
