[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Mon May 21 11:18:52 UTC 2018
On 21 May 2018 at 16:39, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On Mon, 21 May 2018, 12:08 Cillian O'Donnell, <cpodonnell8 at gmail.com>
> wrote:
>> On Mon, 21 May 2018, 11:49 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 21 May 2018 at 11:56, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On Sun, 20 May 2018, 22:33 Vijay Kumar Banerjee, <
>>>>> On 21 May 2018 at 02:29, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On Sun, 20 May 2018, 15:35 Vijay Kumar Banerjee, <
>>>>>>> On 20 May 2018 at 00:53, Vijay Kumar Banerjee <
>>>>>>>> On Sun, 20 May 2018, 00:45 Cillian O'Donnell, <
>>>>>>>>> It works.. Sorry I was using the right covoar but the wrong
>>>>>>>>> rtems-test. Ahh its nice to see the data back in the reports again. Did you
>>>>>>>>> manage to track down 2 exes with the mismatch in symbol size?
>>>>>>>> Great! so next is the parsing of the symbol file.
>>>>>>>> I couldn't manage to track down the mismatch.
>>>>>>>> I have pushed these to my master branch.
>>>>>>> The latest update to cov-tester-support branch (please have a look)
>>>>>>> parses the symbol-set ini file from the coverage script. The parsing
>>>>>>> is working but currently it's not generating reports, as covoar
>>>>>>> needs to be updated .
>>>>>> It's best if covoar reads it's own config file, otherwise it creates
>>>>>> a dependency on the tester. Scanning over the recent changes to covoar
>>>>>> there, it looks like it can already handle multiple sets, so the one ini
>>>>>> with multiple sets in it is the way to go.
>>>>> Okay, Understood.
>>>>>> Here are the things that I have done and that needs to be
>>>>>>> done in order to generate reports :
>>>>>>> I have added a symbol-sets.ini file and parsed it from the coverage
>>>>>>> script
>>>>>>> this is how it works :
>>>>>>>    - The ini file can be updated with all the symbols, separated by
>>>>>>>    ' , ' (comma)
>>>>>> This is the way covoar is actually handling it now. You should test a
>>>>>> multi set ini and see if that's working.
>>>>> Yeah, I have seen it. will try with multiple sets.
>>>>>>>    - The coverages splits them and makes a list of all the sets
>>>>>>>    -  The respective libraries are parsed from the libraries
>>>>>>>    section.
>>>>>>>    - It returns a dict with all the symbols and thir resp. library
>>>>>>>    addresses.
>>>>>>>    - The library addresses are absolute so it can be run from
>>>>>>>    anywhere
>>>>>>>    top of build tree is not necessary.
>>>>>>> This was a good idea but it's just that dependency issue we want to
>>>>>> stay away from. Covoar has something to find the build directory too, it
>>>>>> just hasn't been connected up yet, so running it from the top of the build
>>>>>> directory is ok for the moment.
>>>>> yes it can find the build directory. I was giving it a shot to do it
>>>>> from the script.
>>>>> If covoar's standalone working is a necessity then it surely needs to
>>>>> be working
>>>>> from covoar and shouldn't depend on the script.
>>>> It should be working from covoar and it will.
>>>>>> Probably the most pressing thing now is investigating those mismatch
>>>>>> in symbol size.
>>>>> any advice on where/how to look for it ?
>>>> Before what I was doing was examining the objdump of 2 exes, looking
>>>> there on the weekend i think the info messages mentioned which ones were
>>>> having trouble for which symbol. It says something like "couldn't merge
>>>> coverage map for some_symbol because sizes from exe != to size of
>>>> other_exe. Look at the objdump of exe and other_exe, search for some_symbol
>>>> and compare the dissasembly. There'll be more lines in one than the other,
>>>> nop padding probably. Then you had to find a check that was strict enough
>>>> to chop the end of the symbol in question at the right place but not so
>>>> strict that it chopped other symbols in the wrong place. However the method
>>>> of obtaining the symbols has changed, I'll have to have a look over the
>>>> covoar changes tonight to see what would be the equivalent method of
>>>> checking this now. Unless Chris or Joel come back with the answer before
>>>> then.
>>>> Please have a look into this as I'm confused .
>>> From the messages it seems like there's something with
>>> the base_sp.exe .
>>> I tried to run objdum with -d , I'm getting an error
>>> objdump: can't disassemble for architecture UNKNOWN!
>>> what am I missing ?
>> It'll be a sparc-objdump that was built with the rsb in 5/bin/. I'm not
>> sure if we're still grabbing the objdump using rtems-tools
> can't run sparc-objdump.
> Sorry *rtemstoolkit
>> now, so not 100% sure that this still the way to investigate this.
>>> Also there will probably be multiple ini's with different collections of
>>>> sets that the user could run so it would be good to give them some method
>>>> of choosing which ini they want, like coverage=score will feed score.ini to
>>>> covoar. You could try have a go at that.
>>> yeah I was planning something similar with the script
>>> to let users  choose the sets, and run all by default .
>>> I guess it needs to be done from covoar to avoid dependancy.
>>> I can have look into this.
>> This is different in that it's just allowing the user an easier way of
>> choosing the right ini. So it wouldn't be a dependency like the other
>> thing, if you run it manually you will still have to select the ini you
>> want. So this will be part of the script.
> Oh , I will look into this then. :)
> This way we can parse all the symbols from the same ini file.
>>>>>>> what needs to be done :
>>>>>>>    - I have added #FIXME s in the code , those are the small fixes
>>>>>>>    that
>>>>>>>    would be needed .
>>>>>>>    - The covoar needs to be updated. My proposal is that we can
>>>>>>>    feed the
>>>>>>>    parsed  dict to the covoar instead of feeding the symbol file
>>>>>>>    and letting
>>>>>>>    covoar parse it ( As I mentioned previously).
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/c53509cd/attachment-0002.html>
