[PATCH] covoar.cc: Correct build path checks for multiple executables.
Mon May 21 12:09:33 UTC 2018
CPU-rtems5-objdump
Probably i386. Aren't you running pc386?
Not sparc/erc32 or Leon
On Mon, May 21, 2018, 6:35 AM Cillian O'Donnell <cpodonnell8 at gmail.com>
wrote:
> On Mon, 21 May 2018, 12:18 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 21 May 2018 at 16:39, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> On Mon, 21 May 2018, 12:08 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On Mon, 21 May 2018, 11:49 Vijay Kumar Banerjee, <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> On 21 May 2018 at 11:56, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On Sun, 20 May 2018, 22:33 Vijay Kumar Banerjee, <
>>>>>>> On 21 May 2018 at 02:29, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Sun, 20 May 2018, 15:35 Vijay Kumar Banerjee, <
>>>>>>>>> On 20 May 2018 at 00:53, Vijay Kumar Banerjee <
>>>>>>>>>> On Sun, 20 May 2018, 00:45 Cillian O'Donnell, <
>>>>>>>>>>> It works.. Sorry I was using the right covoar but the wrong
>>>>>>>>>>> rtems-test. Ahh its nice to see the data back in the reports again. Did you
>>>>>>>>>>> manage to track down 2 exes with the mismatch in symbol size?
>>>>>>>>>> Great! so next is the parsing of the symbol file.
>>>>>>>>>> I couldn't manage to track down the mismatch.
>>>>>>>>>> I have pushed these to my master branch.
>>>>>>>>> The latest update to cov-tester-support branch (please have a look)
>>>>>>>>> parses the symbol-set ini file from the coverage script. The
>>>>>>>>> parsing
>>>>>>>>> is working but currently it's not generating reports, as covoar
>>>>>>>>> needs to be updated .
>>>>>>>> It's best if covoar reads it's own config file, otherwise it
>>>>>>>> creates a dependency on the tester. Scanning over the recent changes to
>>>>>>>> covoar there, it looks like it can already handle multiple sets, so the one
>>>>>>>> ini with multiple sets in it is the way to go.
>>>>>>> Okay, Understood.
>>>>>>>> Here are the things that I have done and that needs to be
>>>>>>>>> done in order to generate reports :
>>>>>>>>> I have added a symbol-sets.ini file and parsed it from the
>>>>>>>>> coverage script
>>>>>>>>> this is how it works :
>>>>>>>>>    - The ini file can be updated with all the symbols, separated
>>>>>>>>>    by ' , ' (comma)
>>>>>>>> This is the way covoar is actually handling it now. You should test
>>>>>>>> a multi set ini and see if that's working.
>>>>>>> Yeah, I have seen it. will try with multiple sets.
>>>>>>>>>    - The coverages splits them and makes a list of all the sets
>>>>>>>>>    -  The respective libraries are parsed from the libraries
>>>>>>>>>    section.
>>>>>>>>>    - It returns a dict with all the symbols and thir resp.
>>>>>>>>>    library addresses.
>>>>>>>>>    - The library addresses are absolute so it can be run from
>>>>>>>>>    anywhere
>>>>>>>>>    top of build tree is not necessary.
>>>>>>>>> This was a good idea but it's just that dependency issue we want
>>>>>>>> to stay away from. Covoar has something to find the build directory too, it
>>>>>>>> just hasn't been connected up yet, so running it from the top of the build
>>>>>>>> directory is ok for the moment.
>>>>>>> yes it can find the build directory. I was giving it a shot to do it
>>>>>>> from the script.
>>>>>>> If covoar's standalone working is a necessity then it surely needs
>>>>>>> to be working
>>>>>>> from covoar and shouldn't depend on the script.
>>>>>> It should be working from covoar and it will.
>>>>>>>> Probably the most pressing thing now is investigating those
>>>>>>>> mismatch in symbol size.
>>>>>>> any advice on where/how to look for it ?
>>>>>> Before what I was doing was examining the objdump of 2 exes, looking
>>>>>> there on the weekend i think the info messages mentioned which ones were
>>>>>> having trouble for which symbol. It says something like "couldn't merge
>>>>>> coverage map for some_symbol because sizes from exe != to size of
>>>>>> other_exe. Look at the objdump of exe and other_exe, search for some_symbol
>>>>>> and compare the dissasembly. There'll be more lines in one than the other,
>>>>>> nop padding probably. Then you had to find a check that was strict enough
>>>>>> to chop the end of the symbol in question at the right place but not so
>>>>>> strict that it chopped other symbols in the wrong place. However the method
>>>>>> of obtaining the symbols has changed, I'll have to have a look over the
>>>>>> covoar changes tonight to see what would be the equivalent method of
>>>>>> checking this now. Unless Chris or Joel come back with the answer before
>>>>>> then.
>>>>>> Please have a look into this as I'm confused .
>>>>> From the messages it seems like there's something with
>>>>> the base_sp.exe .
>>>>> I tried to run objdum with -d , I'm getting an error
>>>>> objdump: can't disassemble for architecture UNKNOWN!
>>>>> what am I missing ?
>>>> It'll be a sparc-objdump that was built with the rsb in 5/bin/. I'm not
>>>> sure if we're still grabbing the objdump using rtems-tools
>>> can't run sparc-objdump.
> That might not be the exact name. Is there something that looks like it in
> that directory.
>> Sorry *rtemstoolkit
>>>> now, so not 100% sure that this still the way to investigate this.
>>>>> Also there will probably be multiple ini's with different collections
>>>>>> of sets that the user could run so it would be good to give them some
>>>>>> method of choosing which ini they want, like coverage=score will feed
>>>>>> score.ini to covoar. You could try have a go at that.
>>>>> yeah I was planning something similar with the script
>>>>> to let users  choose the sets, and run all by default .
>>>>> I guess it needs to be done from covoar to avoid dependancy.
>>>>> I can have look into this.
>>>> This is different in that it's just allowing the user an easier way of
>>>> choosing the right ini. So it wouldn't be a dependency like the other
>>>> thing, if you run it manually you will still have to select the ini you
>>>> want. So this will be part of the script.
>>> Oh , I will look into this then. :)
>>> This way we can parse all the symbols from the same ini file.
>>>>>>>>> what needs to be done :
>>>>>>>>>    - I have added #FIXME s in the code , those are the small
>>>>>>>>>    fixes that
>>>>>>>>>    would be needed .
>>>>>>>>>    - The covoar needs to be updated. My proposal is that we can
>>>>>>>>>    feed the
>>>>>>>>>    parsed  dict to the covoar instead of feeding the symbol file
>>>>>>>>>    and letting
>>>>>>>>>    covoar parse it ( As I mentioned previously).
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/81e93dfc/attachment-0002.html>
