[PATCH] covoar.cc: Correct build path checks for multiple executables.
Cillian O'Donnell cpodonnell8 at gmail.com
Mon May 21 11:35:44 UTC 2018
On Mon, 21 May 2018, 12:18 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On 21 May 2018 at 16:39, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> On Mon, 21 May 2018, 12:08 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>> wrote:
>>> On Mon, 21 May 2018, 11:49 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 21 May 2018 at 11:56, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> On Sun, 20 May 2018, 22:33 Vijay Kumar Banerjee, <
>>>>>> On 21 May 2018 at 02:29, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> On Sun, 20 May 2018, 15:35 Vijay Kumar Banerjee, <
>>>>>>>> On 20 May 2018 at 00:53, Vijay Kumar Banerjee <
>>>>>>>>> On Sun, 20 May 2018, 00:45 Cillian O'Donnell, <
>>>>>>>>>> It works.. Sorry I was using the right covoar but the wrong
>>>>>>>>>> rtems-test. Ahh its nice to see the data back in the reports again. Did you
>>>>>>>>>> manage to track down 2 exes with the mismatch in symbol size?
>>>>>>>>> Great! so next is the parsing of the symbol file.
>>>>>>>>> I couldn't manage to track down the mismatch.
>>>>>>>>> I have pushed these to my master branch.
>>>>>>>> The latest update to cov-tester-support branch (please have a look)
>>>>>>>> parses the symbol-set ini file from the coverage script. The
>>>>>>>> parsing
>>>>>>>> is working but currently it's not generating reports, as covoar
>>>>>>>> needs to be updated .
>>>>>>> It's best if covoar reads it's own config file, otherwise it creates
>>>>>>> a dependency on the tester. Scanning over the recent changes to covoar
>>>>>>> there, it looks like it can already handle multiple sets, so the one ini
>>>>>>> with multiple sets in it is the way to go.
>>>>>> Okay, Understood.
>>>>>>> Here are the things that I have done and that needs to be
>>>>>>>> done in order to generate reports :
>>>>>>>> I have added a symbol-sets.ini file and parsed it from the coverage
>>>>>>>> script
>>>>>>>> this is how it works :
>>>>>>>>    - The ini file can be updated with all the symbols, separated
>>>>>>>>    by ' , ' (comma)
>>>>>>> This is the way covoar is actually handling it now. You should test
>>>>>>> a multi set ini and see if that's working.
>>>>>> Yeah, I have seen it. will try with multiple sets.
>>>>>>>>    - The coverages splits them and makes a list of all the sets
>>>>>>>>    -  The respective libraries are parsed from the libraries
>>>>>>>>    section.
>>>>>>>>    - It returns a dict with all the symbols and thir resp. library
>>>>>>>>    addresses.
>>>>>>>>    - The library addresses are absolute so it can be run from
>>>>>>>>    anywhere
>>>>>>>>    top of build tree is not necessary.
>>>>>>>> This was a good idea but it's just that dependency issue we want to
>>>>>>> stay away from. Covoar has something to find the build directory too, it
>>>>>>> just hasn't been connected up yet, so running it from the top of the build
>>>>>>> directory is ok for the moment.
>>>>>> yes it can find the build directory. I was giving it a shot to do it
>>>>>> from the script.
>>>>>> If covoar's standalone working is a necessity then it surely needs to
>>>>>> be working
>>>>>> from covoar and shouldn't depend on the script.
>>>>> It should be working from covoar and it will.
>>>>>>> Probably the most pressing thing now is investigating those mismatch
>>>>>>> in symbol size.
>>>>>> any advice on where/how to look for it ?
>>>>> Before what I was doing was examining the objdump of 2 exes, looking
>>>>> there on the weekend i think the info messages mentioned which ones were
>>>>> having trouble for which symbol. It says something like "couldn't merge
>>>>> coverage map for some_symbol because sizes from exe != to size of
>>>>> other_exe. Look at the objdump of exe and other_exe, search for some_symbol
>>>>> and compare the dissasembly. There'll be more lines in one than the other,
>>>>> nop padding probably. Then you had to find a check that was strict enough
>>>>> to chop the end of the symbol in question at the right place but not so
>>>>> strict that it chopped other symbols in the wrong place. However the method
>>>>> of obtaining the symbols has changed, I'll have to have a look over the
>>>>> covoar changes tonight to see what would be the equivalent method of
>>>>> checking this now. Unless Chris or Joel come back with the answer before
>>>>> then.
>>>>> Please have a look into this as I'm confused .
>>>> From the messages it seems like there's something with
>>>> the base_sp.exe .
>>>> I tried to run objdum with -d , I'm getting an error
>>>> objdump: can't disassemble for architecture UNKNOWN!
>>>> what am I missing ?
>>> It'll be a sparc-objdump that was built with the rsb in 5/bin/. I'm not
>>> sure if we're still grabbing the objdump using rtems-tools
>> can't run sparc-objdump.
That might not be the exact name. Is there something that looks like it in
that directory.
> Sorry *rtemstoolkit
>>> now, so not 100% sure that this still the way to investigate this.
>>>> Also there will probably be multiple ini's with different collections
>>>>> of sets that the user could run so it would be good to give them some
>>>>> method of choosing which ini they want, like coverage=score will feed
>>>>> score.ini to covoar. You could try have a go at that.
>>>> yeah I was planning something similar with the script
>>>> to let users  choose the sets, and run all by default .
>>>> I guess it needs to be done from covoar to avoid dependancy.
>>>> I can have look into this.
>>> This is different in that it's just allowing the user an easier way of
>>> choosing the right ini. So it wouldn't be a dependency like the other
>>> thing, if you run it manually you will still have to select the ini you
>>> want. So this will be part of the script.
>> Oh , I will look into this then. :)
>> This way we can parse all the symbols from the same ini file.
>>>>>>>> what needs to be done :
>>>>>>>>    - I have added #FIXME s in the code , those are the small fixes
>>>>>>>>    that
>>>>>>>>    would be needed .
>>>>>>>>    - The covoar needs to be updated. My proposal is that we can
>>>>>>>>    feed the
>>>>>>>>    parsed  dict to the covoar instead of feeding the symbol file
>>>>>>>>    and letting
>>>>>>>>    covoar parse it ( As I mentioned previously).
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/3c426c54/attachment-0002.html>
