LIST OF IO BENCHMARKS
Udit agarwal dev.madaari at gmail.com
Mon May 21 13:31:48 UTC 2018
Hi Gedare, Hi Joel,
On Mon, May 21, 2018 at 6:53 PM, Gedare Bloom <gedare at rtems.org> wrote:
> "License type customized" is not clear to me what that means, it would
> be worth explaining
In case of IOZONE's license <http://www.iozone.org/docs/Iozone_License.txt>
,  by customized license type, I just mean that it's not one of  standard
OSS licenses like GPL, BSD etc.
BTW, My domain name's DNS is currently misconfigured, website can be
accessed from here <http://81.4.107.225/wordpress/>. And for backup, I have
exported the
wordpress content to blogger(here <http://nerdyclap.blogspot.in/>). (There
are some alignment issues after exporting, mainly due to the custom CSS i
was using, i'll fix that ASAP)
Regards,
Udit Agarwal
On Sun, May 20, 2018 at 7:32 PM, Joel Sherrill <joel at rtems.org> wrote:
> > On Sat, May 19, 2018, 5:06 PM Udit agarwal <dev.madaari at gmail.com>
> wrote:
> >> Hi,
> >> On Fri, May 18, 2018 at 11:19 PM, Gedare Bloom <gedare at rtems.org>
> wrote:
> >>> Udit,
> >>> Can you please compare pros/cons of FIO, IOZONE, and Bonnie++,
> >>> probably in a blog post is a good idea.
> >> Done, here is the comparison.
> > That url has a hard-coded IP address in it. GSoC blogs should be hosted
> > somewhere where they will have a long life with stable URLs.
> > It looks nice though. :)
> >>> The GPLv2 is not a problem for test suites / benchmarks. It is only a
> >>> problem for code that should get merged into the rtems.git.
> >>> Gedare
> >>> On Thu, May 17, 2018 at 5:20 AM, Udit agarwal <dev.madaari at gmail.com>
> >>> wrote:
> >>> > Hi all,
> >>> > As discussed in yesterday's IRC meeting, here is the list of
> different
> >>> > IO
> >>> > benchmarks(which are supported by FreeBSD) in the decreasing order of
> >>> > their
> >>> > popularity  :
> >>> > FIO - License type:  GPLv2 - Widely accepted for storage device
> >>> > benchmarking
> >>> > IOZONE - License: Customized - Large number of features, Also used
> for
> >>> > storage benchmarking
> >>> > Bonnie++ - GPLv2 - Widely known filesystem benchmark, Not much used
> for
> >>> > storage benchmarking.
> >>> > IOMETER -  GPLv2 - Out of active development.
> >>> > IORATE - Flexible - Out of active development
> >>> > I have performed SDIO-SDHCI performance analysis using IOZONE. Here
> are
> >>> > the
> >>> > results. And i have documented the process on my blog.
> >>> > Regards,
> >>> > Udit Agarwal
> >>> > _______________________________________________
> >>> > devel mailing list
> >>> > devel at rtems.org
> >>> > http://lists.rtems.org/mailman/listinfo/devel
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/b19b0255/attachment-0002.html>
