[PATCH 1/2] covoar/ObjdumpProcessor.cc: Add processing for ... padding notation w/hack
Joel Sherrill
joel at rtems.org
Thu May 24 03:11:47 UTC 2018
On Wed, May 23, 2018, 9:59 PM Chris Johns <chrisj at rtems.org> wrote:
> On 24/5/18 12:07 pm, Joel Sherrill wrote:
> > tester/covoar/ObjdumpProcessor.cc | 22 ++++++++++++++++++++++
> > 1 file changed, 22 insertions(+)
> > diff --git a/tester/covoar/ObjdumpProcessor.cc
> b/tester/covoar/ObjdumpProcessor.cc
> > index d41906c..183722b 100644
> > --- a/tester/covoar/ObjdumpProcessor.cc
> > +++ b/tester/covoar/ObjdumpProcessor.cc
> > @@ -384,6 +384,28 @@ namespace Coverage {
> > break;
> > + // This string indicates a block of padding at the end of a method
> > + if (!strncmp(line.c_str(), "\t...", 4)) {
> You have an std::string so why no use C++ rather than resorting to C?
> For example http://en.cppreference.com/w/cpp/string/basic_string/compare.
I was in a hurry and had trouble getting this logic to trip at all. I still
fix this. It does need to be like strncmp.
The +4 is awful though
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180523/419aaba4/attachment-0002.html>
