[GSOC] CTF generator configuration files
Vidushi Vashishth
reachvidu at gmail.com
Wed May 30 11:40:27 UTC 2018
Thats alright no problem! I will begin work on the documentation.
On Wed, May 30, 2018 at 4:59 PM, Sebastian Huber <
> On 30/05/18 13:27, Vidushi Vashishth wrote:
>> Hi Sebastian!
>> Yes I have been working on the documentation. I wrote a blog about the
>> the tracing framework use cases a while ago. It can be seen here
>> https://vidushivashishth.github.io/Third-post-copy/
>> I will write a blog about trace buffer generation which would explain all
>> the questions you have posed too. As suggested by Gedare the blog posts
>> will somewhat be the first draft of what is to go in the user manual. I
>> would appreciate your feedback on the blogpost.
> I would highly appreciate if you do this not in a blog. The primary medium
> for RTEMS development is this mailing list. Please start with a skeleton
> structure for this new stuff in the user manual and send patches to the
> mailing list for review.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/c6005c75/attachment-0002.html>
