[PATCH] Generate coverage analysis Report
Wed May 30 18:58:05 UTC 2018
On Wed, May 30, 2018 at 1:34 PM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On 30 May 2018 at 23:29, Joel Sherrill <joel at rtems.org> wrote:
>> On Wed, May 30, 2018 at 12:54 PM, Vijay Kumar Banerjee <
>>> On 30 May 2018 at 22:51, Gedare Bloom <gedare at rtems.org> wrote:
>>>> Please provide your name in your commits (git config --user.name "My
>>>> Name") that you submit.
>>>> OK Noted :)
>>>> The first line of this commit, and therefore the email subject, is
>>>> overly vague. Provide a slightly more specific description.
>>> On Wed, May 30, 2018 at 1:00 PM, thelunatic <vijaykumar9597 at gmail.com>
>>>> wrote:
>>>> > + Add script to run covoar and generate an html report from
>>>> > the output generated from covoar
>>>> > + Add symbol-sets ini file for library addresses of the symbol-sets
>>>> > + tester/rt/test : Add options for running coverage
>>>> I'd rather see a narrative paragraph than this list of + bullet items.
>>>> Are all of these changes required to run the report? Should they be
>>>> broken into smaller commits that are logically related but separately
>>>> reviewable and commited?
>>>> OK, I will write in a descriptive paragraph.
>>> These changes are all needed to run coverage.
>>>> > Co-author : Cillian O'Donnel <cpodonnell8 at gmail.com>
>>>> I don't know what Co-Author should mean. I would prefer to receive
>>>> separate commits/patches for contributions made by different people if
>>>> that is possible.
>>>> Plese refer below...
>>>> >  tester/rt/coverage.py                         | 380
>>>> >  tester/rt/test.py                             |  36 ++-
>>>> >  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
>>>> >  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
>>>> >  tester/rtems/testing/qemu.cfg                 |   4 +-
>>>> >  5 files changed, 447 insertions(+), 12 deletions(-)
>>>> >  create mode 100644 tester/rt/coverage.py
>>>> >  create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>>>> > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>> > new file mode 100644
>>>> > index 0000000..38dcce6
>>>> > --- /dev/null
>>>> > +++ b/tester/rt/coverage.py
>>>> > @@ -0,0 +1,380 @@
>>>> > +# RTEMS Tools Project (http://www.rtems.org/)
>>>> > +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
>>>> Is this Krzysztof's code? if so, it should be added as a commit with
>>>> him as the --author="" field of git-commit option.
>>>> Actually this script has undergone a lot of updates.
>>> It doesn't even work the same way it used to. I am uncertain
>>> about the portions of the code that are written by him and still in
>>> the script. Basically I left the copyright notice untouched and
>>> let it be there because I am unsure of what to include there.
>>> Same is true in case of Cillian. I don't really know how much
>>> of Code is authored by him.
>>> It surely isn't the proper way to add him as the co-author in
>>> the log but that seemed like the only way to include him.
>> OK. I was afraid of it being technically impossible to separate out the
>> work
>> for revision control purposes.
>> Just make sure credit due is given.
>>>> > +# All rights reserved.
>>>> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>> > +# Redistribution and use in source and binary forms, with or without
>>>> > +# modification, are permitted provided that the following conditions
>>>> are met:
>>>> > +# 1. Redistributions of source code must retain the above copyright
>>>> notice,
>>>> > +# this list of conditions and the following disclaimer.
>>>> > +# 2. Redistributions in binary form must reproduce the above
>>>> copyright notice,
>>>> > +# this list of conditions and the following disclaimer in the
>>>> documentation
>>>> > +# and/or other materials provided with the distribution.
>>>> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>> CONTRIBUTORS 'AS IS'
>>>> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>> TO, THE
>>>> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>> PURPOSE
>>>> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>> CONTRIBUTORS BE
>>>> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>>> OF
>>>> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>> BUSINESS
>>>> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>> WHETHER IN
>>>> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>> OTHERWISE)
>>>> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>> ADVISED OF THE
>>>> > +# POSSIBILITY OF SUCH DAMAGE.
>>>> > +from rtemstoolkit import error
>>>> > +from rtemstoolkit import path
>>>> > +from rtemstoolkit import log
>>>> > +from rtemstoolkit import execute
>>>> > +from rtemstoolkit import macros
>>>> > +from datetime import datetime
>>>> > +from . import options
>>>> > +import shutil
>>>> > +import os
>>>> > +try:
>>>> > +    import configparser
>>>> > +except:
>>>> > +    import ConfigParser as configparser
>>>> > +class summary:
>>>> > +    def __init__(self, p_summary_dir):
>>>> > +        self.summary_file_path = path.join(p_summary_dir,
>>>> 'summary.txt')
>>>> > +        self.index_file_path = path.join(p_summary_dir, 'index.html')
>>>> > +        self.bytes_analyzed = 0
>>>> > +        self.bytes_not_executed = 0
>>>> > +        self.percentage_executed = 0.0
>>>> > +        self.percentage_not_executed = 100.0
>>>> > +        self.ranges_uncovered = 0
>>>> > +        self.branches_uncovered = 0
>>>> > +        self.branches_total = 0
>>>> > +        self.branches_always_taken = 0
>>>> > +        self.branches_never_taken = 0
>>>> > +        self.percentage_branches_covered = 0.0
>>>> > +        self.is_failure = False
>>>> > +    def parse(self):
>>>> > +        if(not path.exists(self.summary_file_path)):
>>>> > +            log.notice('summary file %s does not exist!' %
>>>> > +            self.is_failure = True
>>>> > +            return
>>>> > +        with open(self.summary_file_path,'r') as summary_file:
>>>> > +           self.bytes_analyzed = self._get_next_with_colon(summ
>>>> ary_file)
>>>> > +           self.bytes_not_executed = self._get_next_with_colon(summ
>>>> ary_file)
>>>> > +           self.percentage_executed = self._get_next_with_colon(summ
>>>> ary_file)
>>>> self._get_next_with_colon(summary_file)
>>>> > +           self.ranges_uncovered = self._get_next_with_colon(summ
>>>> ary_file)
>>>> > +           self.branches_total = self._get_next_with_colon(summ
>>>> ary_file)
>>>> > +           self.branches_uncovered = self._get_next_with_colon(summ
>>>> ary_file)
>>>> self._get_next_without_colon(summary_file)
>>>> > +           self.branches_never_taken = self._get_next_without_colon(s
>>>> ummary_file)
>>>> > +        if len(self.branches_uncovered) > 0 and
>>>> len(self.branches_total) > 0:
>>>> > +            self.percentage_branches_covered = \
>>>> > +            1 - (float(self.branches_uncovered) /
>>>> float(self.branches_total))
>>>> > +        else:
>>>> > +        return
>>>> > +    def _get_next_with_colon(self, summary_file):
>>>> > +        line = summary_file.readline()
>>>> > +        if ':' in line:
>>>> > +            return line.split(':')[1].strip()
>>>> > +        else:
>>>> > +            return ''
>>>> > +    def _get_next_without_colon(self, summary_file):
>>>> > +        return line.strip().split(' ')[0]
>>>> > +class report_gen_html:
>>>> > +    def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>>>> > +        self.symbol_sets_list = ['score']
>>>> > +        self.build_dir = build_dir
>>>> > +        self.partial_reports_files = list(["index.html",
>>>> "summary.txt"])
>>>> > +        self.number_of_columns = 1
>>>> > +        self.covoar_src_path = path.join(rtdir, 'covoar')
>>>> > +    def _find_partial_reports(self):
>>>> > +        partial_reports = {}
>>>> > +        for symbol_set in self.symbol_sets_list:
>>>> > +            set_summary = summary(path.join(self.build_dir,
>>>> "coverage",
>>>> > +                                  symbol_set))
>>>> > +            set_summary.parse()
>>>> > +            partial_reports[symbol_set] = set_summary
>>>> > +        return partial_reports
>>>> > +    def _prepare_head_section(self):
>>>> > +        head_section = '''
>>>> > +        <head>
>>>> > +        <title>RTEMS coverage report</title>
>>>> > +        <style type="text/css">
>>>> > +            progress[value] {
>>>> > +              -webkit-appearance: none;
>>>> > +               appearance: none;
>>>> > +              width: 150px;
>>>> > +              height: 15px;
>>>> > +        </style>
>>>> > +        </head>'''
>>>> > +        return head_section
>>>> > +    def _prepare_index_content(self, partial_reports):
>>>> > +        header = "<h1> RTEMS coverage analysis report </h1>"
>>>> > +        header += "<h3>Coverage reports by symbols sets:</h3>"
>>>> > +        table = "<table>"
>>>> > +        table += self._header_row()
>>>> > +        for symbol_set in partial_reports:
>>>> > +            table += self._row(symbol_set,
>>>> partial_reports[symbol_set])
>>>> > +        table += "</table> </br>"
>>>> > +        timestamp = "Analysis performed on " + datetime.now().ctime()
>>>> > +        return "<body>\n" + header + table + timestamp + "\n</body>"
>>>> > +    def _row(self, symbol_set, summary):
>>>> > +        row = "<tr>"
>>>> > +        row += "<td>" + symbol_set + "</td>"
>>>> > +        if summary.is_failure:
>>>> > +            row += ' <td colspan="' + str(self.number_of_columns-1) \
>>>> > +            + '" style="background-color:red">FAILURE</td>'
>>>> > +        else:
>>>> > +            row += " <td>" + self._link(summary.index_file_path,"Index")
>>>> > +            + "</td>"
>>>> > +            row += " <td>" + self._link(summary.summary_file_path,"Summary")
>>>> > +            + "</td>"
>>>> > +            row += " <td>" + summary.bytes_analyzed + "</td>"
>>>> > +            row += " <td>" + summary.bytes_not_executed + "</td>"
>>>> > +            row += " <td>" + summary.ranges_uncovered + "</td>"
>>>> > +            row += " <td>" + summary.percentage_executed + "%</td>"
>>>> > +            row += " <td>" + summary.percentage_not_executed +
>>>> "%</td>"
>>>> > +            row += ' <td><progress value="' +
>>>> summary.percentage_executed \
>>>> > +            + '" max="100"></progress></td>'
>>>> > +            row += " <td>" + summary.branches_uncovered + "</td>"
>>>> > +            row += " <td>" + summary.branches_total + "</td>"
>>>> > +            row += " <td> {:.3%} </td>".format(summary.percenta
>>>> ge_branches_covered)
>>>> > +            row += ' <td><progress value="{:.3}"
>>>> max="100"></progress></td>'.format(100*summary.percentage_br
>>>> anches_covered)
>>>> > +            row += "</tr>\n"
>>>> > +        return row
>>>> > +    def _header_row(self):
>>>> > +        row = "<tr>"
>>>> > +        row += "<th> Symbols set name </th>"
>>>> > +        row += "<th> Index file </th>"
>>>> > +        row += "<th> Summary file </th>"
>>>> > +        row += "<th> Bytes analyzed </th>"
>>>> > +        row += "<th> Bytes not executed </th>"
>>>> > +        row += "<th> Uncovered ranges </th>"
>>>> > +        row += "<th> Percentage covered </th>"
>>>> > +        row += "<th> Percentage uncovered </th>"
>>>> > +        row += "<th> Instruction coverage </th>"
>>>> > +        row += "<th> Branches uncovered </th>"
>>>> > +        row += "<th> Branches total </th>"
>>>> > +        row += "<th> Branches covered percentage </th>"
>>>> > +        row += "<th> Branches coverage </th>"
>>>> > +        row += "</tr>\n"
>>>> > +        self.number_of_columns = row.count('<th>')
>>>> > +        return row
>>>> > +    def _link(self, address, text):
>>>> > +        return '<a href="' + address + '">' + text + '</a>'
>>>> > +    def _create_index_file(self, head_section, content):
>>>> > +        with open(path.join(self.build_dir,"report.html"),'w') as f:
>>>> > +            f.write(head_section)
>>>> > +            f.write(content)
>>>> > +    def generate(self):
>>>> > +        partial_reports = self._find_partial_reports()
>>>> > +        head_section = self._prepare_head_section()
>>>> > +        index_content = self._prepare_index_content(partial_reports)
>>>> > +        self._create_index_file(head_section,index_content)
>>>> > +    def add_covoar_src_path(self):
>>>> > +        table_js_path = path.join(self.covoar_src_path, 'table.js')
>>>> > +        covoar_css_path = path.join(self.covoar_src_path,
>>>> 'covoar.css')
>>>> > +            symbol_set_dir = path.join(self.build_dir, "coverage",
>>>> symbol_set)
>>>> > +            html_files = os.listdir(symbol_set_dir)
>>>> > +            for html_file in html_files:
>>>> > +                html_file = path.join(symbol_set_dir, html_file)
>>>> > +                if path.exists(html_file) and 'html' in html_file:
>>>> > +                    with open(html_file, 'r') as f:
>>>> > +                        file_data = f.read()
>>>> > +                    file_data = file_data.replace('table.js',
>>>> table_js_path)
>>>> > +                    file_data = file_data.replace('covoar.css',
>>>> > +                                                  covoar_css_path)
>>>> > +                    with open(html_file, 'w') as f:
>>>> > +                        f.write(file_data)
>>>> > +class build_path_generator(object):
>>>> > +    Generates the build path from the path to executables
>>>> > +    def __init__(self, executables, target):
>>>> > +        self.executables = executables
>>>> > +        self.target = target
>>>> > +    def run(self):
>>>> > +        build_path = '/'
>>>> > +        Path = self.executables[0].split('/')
>>>> > +        for P in Path:
>>>> > +            if P == self.target:
>>>> > +                break;
>>>> > +            else:
>>>> > +                build_path = path.join(build_path, P)
>>>> > +        return build_path
>>>> > +class symbol_parser(object):
>>>> > +    Parse the symbol sets ini and create custom ini file for covoar
>>>> > +    def __init__(self, symbol_config_path,
>>>> > +                 symbol_select_path, coverage_arg, build_dir):
>>>> > +        self.symbol_select_file = symbol_select_path
>>>> > +        self.symbol_file = symbol_config_path
>>>> > +        self.symbol_sets = {}
>>>> > +        self.cov_arg = coverage_arg
>>>> > +        self.ssets = []
>>>> > +    def parse(self):
>>>> > +        config = configparser.ConfigParser()
>>>> > +        try:
>>>> > +            config.read(self.symbol_file)
>>>> > +            if self.cov_arg:
>>>> > +                self.ssets = self.cov_arg.split(',')
>>>> > +            else:
>>>> > +                self.ssets = config.get('symbol-sets',
>>>> 'sets').split(',')
>>>> > +                self.ssets = [ sset.encode('utf-8') for sset in
>>>> self.ssets]
>>>> > +            for sset in self.ssets:
>>>> > +                lib = path.join(self.build_dir,
>>>> > +                                config.get('libraries', sset))
>>>> > +                self.symbol_sets[sset] = lib.encode('utf-8')
>>>> > +        except:
>>>> > +            raise error.general('Symbol set parsing failed')
>>>> > +    def _write_ini(self):
>>>> > +        try:
>>>> > +            sets = ', '.join(self.symbol_sets.keys())
>>>> > +            config.add_section('symbol-sets')
>>>> > +            config.set('symbol-sets', 'sets', sets)
>>>> > +            for key in self.symbol_sets.keys():
>>>> > +                config.add_section(key)
>>>> > +                config.set(key, 'libraries', self.symbol_sets[key])
>>>> > +            with open(self.symbol_select_file, 'w') as conf:
>>>> > +                config.write(conf)
>>>> > +        except:
>>>> > +            raise error.general('write failed')
>>>> > +    def run(self):
>>>> > +        self.parse()
>>>> > +        self._write_ini()
>>>> > +class covoar(object):
>>>> > +    Covoar runner
>>>> > +    def __init__(self, base_result_dir, config_dir, executables,
>>>> explanations_txt):
>>>> > +        self.base_result_dir = base_result_dir
>>>> > +        self.config_dir = config_dir
>>>> > +        self.executables = ' '.join(executables)
>>>> > +        self.explanations_txt = explanations_txt
>>>> > +        self.project_name = 'RTEMS-5'
>>>> > +    def run(self, set_name, symbol_file):
>>>> > +        covoar_result_dir = path.join(self.base_result_dir,
>>>> set_name)
>>>> > +        if (not path.exists(covoar_result_dir)):
>>>> > +            path.mkdir(covoar_result_dir)
>>>> > +        if (not path.exists(symbol_file)):
>>>> > +            raise error.general('symbol set file: coverage %s was
>>>> not created for covoar, skipping %s'% (symbol_file, set_name))
>>>> > +        command = ('covoar -S ' + symbol_file
>>>> > +                  + ' -O ' + covoar_result_dir
>>>> > +                  + ' -E ' + self.explanations_txt
>>>> > +                  + ' -p ' + self.project_name + ' ' +
>>>> self.executables)
>>>> > +        log.notice('Running covoar for %s' % (set_name))
>>>> > +        print( 'covoar results directory:\n' + covoar_result_dir )
>>>> > +        executor = execute.execute(verbose = True, output =
>>>> self.output_handler)
>>>> > +        exit_code = executor.shell(command, cwd=os.getcwd())
>>>> > +        if (exit_code[0] != 0):
>>>> > +            raise error.general('covoar failure exit code: %d' %
>>>> (exit_code[0]))
>>>> > +        log.notice('Coverage run for %s finished successfully.' %
>>>> (set_name))
>>>> > +        log.notice('-----------------------------------------------'
>>>> > +    def output_handler(self, text):
>>>> > +        log.notice('%s' % (text))
>>>> > +class coverage_run(object):
>>>> > +    Coverage analysis support for rtems-test
>>>> > +    def __init__(self, p_macros, coverage_arg, target):
>>>> > +        Constructor
>>>> > +        self.macros = p_macros
>>>> > +        self.build_dir = self.macros['_cwd']
>>>> > +        self.explanations_txt = self.macros.expand(self.macros
>>>> ['cov_explanations'])
>>>> > +        self.test_dir = path.join(self.build_dir, 'coverage')
>>>> > +        if (not path.exists(self.test_dir)):
>>>> > +            path.mkdir(self.test_dir)
>>>> > +        self.rtdir = path.abspath(self.macros['_rtdir'])
>>>> > +        self.rtscripts = self.macros.expand(self.macros
>>>> ['_rtscripts'])
>>>> > +        self.coverage_config_path = path.join(self.rtscripts,
>>>> 'coverage')
>>>> > +        self.symbol_config_path = path.join(self.coverage_config
>>>> _path,
>>>> > +                                            'symbol-sets.ini')
>>>> > +        self.symbol_select_path = path.join(self.coverage_config
>>>> _path,
>>>> > +                                            'symbol-select.ini')
>>>> > +        self.executables = None
>>>> > +        self.symbol_sets = []
>>>> > +        self.no_clean = int(self.macros['_no_clean'])
>>>> > +        self.report_format = self.macros['cov_report_format']
>>>> > +        self.coverage_arg = coverage_arg
>>>> > +    def run(self):
>>>> > +        try:
>>>> > +            if self.executables is None:
>>>> > +                raise error.general('no test executables provided.')
>>>> > +            build_dir = build_path_generator(self.executables,
>>>> self.target).run()
>>>> > +            parser = symbol_parser(self.symbol_config_path,
>>>> > +                                   self.symbol_select_path,
>>>> > +                                   self.coverage_arg,
>>>> > +                                   build_dir)
>>>> > +            parser.run()
>>>> > +            covoar_runner = covoar(self.test_dir,
>>>> > +                                   self.executables,
>>>> self.explanations_txt)
>>>> > +            covoar_runner.run('score', self.symbol_select_path)
>>>> > +            self._generate_reports();
>>>> > +            self._summarize();
>>>> > +        finally:
>>>> > +            self._cleanup();
>>>> > +    def _generate_reports(self):
>>>> > +        log.notice('Generating reports')
>>>> > +        if self.report_format == 'html':
>>>> > +            report = report_gen_html(self.symbol_sets,
>>>> > +                                     self.build_dir,
>>>> > +                                     self.rtdir)
>>>> > +            report.generate()
>>>> > +            report.add_covoar_src_path()
>>>> > +    def _cleanup(self):
>>>> > +        if not self.no_clean:
>>>> > +            log.notice('***Cleaning tempfiles***')
>>>> > +            for exe in self.executables:
>>>> > +                trace_file = exe + '.cov'
>>>> > +                if path.exists(trace_file):
>>>> > +                    os.remove(trace_file)
>>>> > +    def _summarize(self):
>>>> > +        log.notice('Coverage analysis finished. You can find results
>>>> in %s' % (self.build_dir))
>>>> > diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>> > index f4d9b5c..cabec7b 100644
>>>> > --- a/tester/rt/test.py
>>>> > +++ b/tester/rt/test.py
>>>> > @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>> >  from rtemstoolkit import reraise
>>>> >  from rtemstoolkit import stacktraces
>>>> >  from rtemstoolkit import version
>>>> > +from rtemstoolkit import check
>>>> >  from . import bsps
>>>> >  from . import config
>>>> >  from . import console
>>>> >  from . import report
>>>> > +from . import coverage
>>>> >  class log_capture(object):
>>>> >      def __init__(self):
>>>> > @@ -147,7 +149,7 @@ class test_run(object):
>>>> >      def run(self):
>>>> >          self.thread = threading.Thread(target = self.runner,
>>>> > -                                       name = 'test[%s]' %
>>>> path.basename(self.executable))
>>>> > +                            name = 'test[%s]' %
>>>> >          self.thread.start()
>>>> >      def is_alive(self):
>>>> > @@ -214,6 +216,11 @@ def killall(tests):
>>>> >      for test in tests:
>>>> >          test.kill()
>>>> why extra new line here?
>>> Will correct it. Thanks.
>>>> > +def coverage_run(opts, coverage, executables):
>>>> > +    coverage.executables = executables
>>>> > +    coverage.run()
>>>> >  def run(command_path = None):
>>>> >      import sys
>>>> >      tests = []
>>>> > @@ -221,15 +228,16 @@ def run(command_path = None):
>>>> >      opts = None
>>>> >      default_exefilter = '*.exe'
>>>> >      try:
>>>> > -        optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>>>> > -                    '--rtems-bsp':   'The RTEMS BSP to run the test
>>>> on',
>>>> > -                    '--user-config': 'Path to your local user
>>>> configuration INI file',
>>>> > -                    '--report-mode': 'Reporting modes, failures
>>>> (default),all,none',
>>>> > -                    '--list-bsps':   'List the supported BSPs',
>>>> > -                    '--debug-trace': 'Debug trace based on specific
>>>> flags',
>>>> > -                    '--filter':      'Glob that executables must
>>>> match to run (default: ' +
>>>> > +        optargs = { '--rtems-tools':    'The path to the RTEMS
>>>> tools',
>>>> > +                    '--rtems-bsp':      'The RTEMS BSP to run the
>>>> test on',
>>>> > +                    '--user-config':    'Path to your local user
>>>> > +                    '--report-mode':    'Reporting modes, failures
>>>> > +                    '--list-bsps':      'List the supported BSPs',
>>>> > +                    '--debug-trace':    'Debug trace based on
>>>> specific flags',
>>>> > +                    '--filter':         'Glob that executables must
>>>> >                                default_exefilter + ')',
>>>> > -                    '--stacktrace':  'Dump a stack trace on a user
>>>> termination (^C)' }
>>>> > +                    '--stacktrace':     'Dump a stack trace on a
>>>> user termination (^C)',
>>>> > +                    '--coverage':       'Perform coverage analysis
>>>> of test exectuables.'}
>>>> Why are there changes outside of the last two lines (stacktrace and
>>>> coverage)? Only those two need to be modified to add the new option.
>>>> Typo: s/exectuables/executables
>>> Thanks
>>>> >          mailer.append_options(optargs)
>>>> >          opts = options.load(sys.argv,
>>>> >                              optargs = optargs,
>>>> > @@ -279,6 +287,14 @@ def run(command_path = None):
>>>> >              raise error.general('RTEMS BSP not provided or an
>>>> invalid option')
>>>> >          bsp = config.load(bsp[1], opts)
>>>> >          bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>>> > +        coverage_enabled = opts.find_arg('--coverage')
>>>> > +        if coverage_enabled:
>>>> > +            if len(coverage_enabled) == 2:
>>>> What is this len() check doing? This seems horribly hackish to me. It
>>>> is obviously assuming something, but I can't tell what that is. It
>>>> might be better to do an error check (like what is done with the bsp
>>>> variable before this) to see if len(coverage_enabled) != 2. From what
>>>> I see here, I have no clue what should be the arguments to this
>>>> --coverage, it seems like a binary value to me (on/off).
>>>> it's supposed to work this way ...
>>> --coverage option is supposed to run coverage for all the sets
>>> mentioned in the ini file.
>>> --coverage=set1,set2
>>> will run it specifically for set1 and set 2.
>>>> > +                coverage_runner = coverage.coverage_run(opts.def
>>>> aults,
>>>> > +                                                coverage_enabled[1],
>>>> opts.defaults['target'])
>>>> > +            else:
>>>> > +                coverage_runner = coverage.coverage_run(opts.defaults,
>>>> 0)
>>>> >          report_mode = opts.find_arg('--report-mode')
>>>> >          if report_mode:
>>>> >              if report_mode[1] != 'failures' and \
>>>> > @@ -365,6 +381,8 @@ def run(command_path = None):
>>>> >                      reports.failures(),
>>>> >                      'Log', '===', ''] + output.get()
>>>> >              mail.send(to_addr, subject, os.linesep.join(body))
>>>> > +            coverage_run(opts, coverage_runner, executables)
>>>> Design question: Should the coverage run replace the test_run? Or
>>>> should coverage be an option to test_run instead of how this is being
>>>> done?
>>>> It should be an option to test_run
>>> just adding --coverage will run coverage analysis.
>> Can this change be a follow up patch? I know Chris and I just want to get
>> work focused on the master.
> Sorry I couldn't understand.
> Which change ?
I may not understand correctly but there is test_run and coverage_run.
Someone
suggested making coverage_running an option to test_run. If that's what's
being
asked for, then I think doing it in a follow up patch is OK.
If that's the intended request, perhaps a ticket should be filed.
>>>> >      except error.general as gerr:
>>>> >          print(gerr)
>>>> > diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>> > index 6b5e7e6..2f89117 100644
>>>> > --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>> > +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>> > @@ -31,9 +31,10 @@
>>>> >  # The Leon 3 QEMU BSP
>>>> > -[leon3-qemu]
>>>> > +[leon3-qemu-cov]
>>>> >  bsp               = leon3-qemu
>>>> >  arch              = sparc
>>>> > +target            = sparc-rtems5
>>>> >  tester            = %{_rtscripts}/qemu.cfg
>>>> >  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>> >  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>> > diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>> > index 0000000..a2ec7bc
>>>> > --- /dev/null
>>>> > +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>> > @@ -0,0 +1,36 @@
>>>> > +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>> are met:
>>>> notice,
>>>> copyright notice,
>>>> documentation
>>>> CONTRIBUTORS "AS IS"
>>>> TO, THE
>>>> PURPOSE
>>>> CONTRIBUTORS BE
>>>> OF
>>>> BUSINESS
>>>> WHETHER IN
>>>> OTHERWISE)
>>>> ADVISED OF THE
>>>> > +[symbol-sets]
>>>> > +sets = score,rtems
>>>> > +[libraries]
>>>> > +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>> > +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>> > diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>>>> qemu.cfg
>>>> > index bfcd2f5..52a3752 100644
>>>> > --- a/tester/rtems/testing/qemu.cfg
>>>> > +++ b/tester/rtems/testing/qemu.cfg
>>>> > @@ -51,8 +51,8 @@
>>>> >  # Qemu common option patterns.
>>>> > -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>> -nographic
>>>> > -%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>> -nographic
>>>> > +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>> -nographic
>>>> > +#%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>> -nographic
>>>> Why changing the common options for qemu?
>>>> actually it's a bit experimental on advice of Cillian.
>>> It stayed in the patch.
>> I know the impact of some of those options but maybe it would make sense
>> to add a comment block with the impact of each option? It would help
>> future
>> readers.
>> And, from personal experience, qemu changes arguments from time to time.
>> Knowing
>> what the old intent was helps mapping to different versions and target
>> architectures.
>> That's a good Idea.
>>> >  %define qemu_opts_no_net -net none
>>>> > 2.14.3
>>>> > _______________________________________________
>>>> > devel mailing list
>>>> > devel at rtems.org
>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/19e4b7cf/attachment-0002.html>
