[PATCH] Generate coverage analysis Report
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed May 30 20:29:30 UTC 2018
On 31 May 2018 at 00:28, Joel Sherrill <joel at rtems.org> wrote:
> I may not understand correctly but there is test_run and coverage_run.
> Someone
> suggested making coverage_running an option to test_run. If that's what's
> being
> asked for, then I think doing it in a follow up patch is OK.
> If that's the intended request, perhaps a ticket should be filed.
Sorry for all the confusion.
This patch doesn't change the way test works. It only adds an option to run
the coverage script. coverage_run just runs the coverage.coverage_run
>>>>> >      except error.general as gerr:
>>>>> >          print(gerr)
>>>>> > diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> > index 6b5e7e6..2f89117 100644
>>>>> > --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> > +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> > @@ -31,9 +31,10 @@
>>>>> >  # The Leon 3 QEMU BSP
>>>>> > -[leon3-qemu]
>>>>> > +[leon3-qemu-cov]
>>>>> >  bsp               = leon3-qemu
>>>>> >  arch              = sparc
>>>>> > +target            = sparc-rtems5
>>>>> >  tester            = %{_rtscripts}/qemu.cfg
>>>>> >  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>>> >  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>> > diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> > new file mode 100644
>>>>> > index 0000000..a2ec7bc
>>>>> > --- /dev/null
>>>>> > +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> > @@ -0,0 +1,36 @@
>>>>> > +# RTEMS Tools Project (http://www.rtems.org/)
>>>>> > +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>> > +# All rights reserved.
>>>>> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>> > +# Redistribution and use in source and binary forms, with or without
>>>>> > +# modification, are permitted provided that the following
>>>>> conditions are met:
>>>>> > +# 1. Redistributions of source code must retain the above copyright
>>>>> notice,
>>>>> > +# this list of conditions and the following disclaimer.
>>>>> > +# 2. Redistributions in binary form must reproduce the above
>>>>> copyright notice,
>>>>> > +# this list of conditions and the following disclaimer in the
>>>>> documentation
>>>>> > +# and/or other materials provided with the distribution.
>>>>> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>> CONTRIBUTORS "AS IS"
>>>>> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>>> TO, THE
>>>>> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>> PARTICULAR PURPOSE
>>>>> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>> CONTRIBUTORS BE
>>>>> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>>>> OR
>>>>> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>>>> OF
>>>>> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>> BUSINESS
>>>>> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>> WHETHER IN
>>>>> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>> OTHERWISE)
>>>>> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>> ADVISED OF THE
>>>>> > +# POSSIBILITY OF SUCH DAMAGE.
>>>>> > +[symbol-sets]
>>>>> > +sets = score,rtems
>>>>> > +[libraries]
>>>>> > +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>> > +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>> > diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>>>>> qemu.cfg
>>>>> > index bfcd2f5..52a3752 100644
>>>>> > --- a/tester/rtems/testing/qemu.cfg
>>>>> > +++ b/tester/rtems/testing/qemu.cfg
>>>>> > @@ -51,8 +51,8 @@
>>>>> >  # Qemu common option patterns.
>>>>> > -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>> -nographic
>>>>> > -%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>>> -nographic
>>>>> > +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>> -nographic
>>>>> > +#%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>>> -nographic
>>>>> Why changing the common options for qemu?
>>>>> actually it's a bit experimental on advice of Cillian.
>>>> It stayed in the patch.
>>> I know the impact of some of those options but maybe it would make sense
>>> to add a comment block with the impact of each option? It would help
>>> future
>>> readers.
>>> And, from personal experience, qemu changes arguments from time to time.
>>> Knowing
>>> what the old intent was helps mapping to different versions and target
>>> architectures.
>>> That's a good Idea.
>>>> >  %define qemu_opts_no_net -net none
>>>>> > 2.14.3
>>>>> > _______________________________________________
>>>>> > devel mailing list
>>>>> > devel at rtems.org
>>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>>> devel mailing list
>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180531/93575802/attachment-0002.html>
