[PATCH] Generate coverage analysis Report
Wed May 30 20:32:09 UTC 2018
On Wed, May 30, 2018 at 3:29 PM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On 31 May 2018 at 00:28, Joel Sherrill <joel at rtems.org> wrote:
>> I may not understand correctly but there is test_run and coverage_run.
>> Someone
>> suggested making coverage_running an option to test_run. If that's what's
>> being
>> asked for, then I think doing it in a follow up patch is OK.
>> If that's the intended request, perhaps a ticket should be filed.
> Sorry for all the confusion.
> This patch doesn't change the way test works. It only adds an option to
> run
> the coverage script. coverage_run just runs the coverage.coverage_run
:) And I am saying if we want to have one test_run with an argument, do it
as
a future work iteration. File a ticket.
We need to get the code working on the master.
>>>>>> >      except error.general as gerr:
>>>>>> >          print(gerr)
>>>>>> > diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> > index 6b5e7e6..2f89117 100644
>>>>>> > --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> > +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> > @@ -31,9 +31,10 @@
>>>>>> >  # The Leon 3 QEMU BSP
>>>>>> > -[leon3-qemu]
>>>>>> > +[leon3-qemu-cov]
>>>>>> >  bsp               = leon3-qemu
>>>>>> >  arch              = sparc
>>>>>> > +target            = sparc-rtems5
>>>>>> >  tester            = %{_rtscripts}/qemu.cfg
>>>>>> >  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>>>> >  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>>> > diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> > new file mode 100644
>>>>>> > index 0000000..a2ec7bc
>>>>>> > --- /dev/null
>>>>>> > +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> > @@ -0,0 +1,36 @@
>>>>>> > +# RTEMS Tools Project (http://www.rtems.org/)
>>>>>> > +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>>> > +# All rights reserved.
>>>>>> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>> > +# Redistribution and use in source and binary forms, with or
>>>>>> without
>>>>>> > +# modification, are permitted provided that the following
>>>>>> conditions are met:
>>>>>> > +# 1. Redistributions of source code must retain the above
>>>>>> copyright notice,
>>>>>> > +# this list of conditions and the following disclaimer.
>>>>>> > +# 2. Redistributions in binary form must reproduce the above
>>>>>> copyright notice,
>>>>>> > +# this list of conditions and the following disclaimer in the
>>>>>> documentation
>>>>>> > +# and/or other materials provided with the distribution.
>>>>>> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>> CONTRIBUTORS "AS IS"
>>>>>> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>>> LIMITED TO, THE
>>>>>> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>> PARTICULAR PURPOSE
>>>>>> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>> CONTRIBUTORS BE
>>>>>> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>>>>> OR
>>>>>> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>> PROCUREMENT OF
>>>>>> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>> BUSINESS
>>>>>> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>> WHETHER IN
>>>>>> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>> OTHERWISE)
>>>>>> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>> ADVISED OF THE
>>>>>> > +# POSSIBILITY OF SUCH DAMAGE.
>>>>>> > +[symbol-sets]
>>>>>> > +sets = score,rtems
>>>>>> > +[libraries]
>>>>>> > +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>>> > +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>>> > diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>>>>>> qemu.cfg
>>>>>> > index bfcd2f5..52a3752 100644
>>>>>> > --- a/tester/rtems/testing/qemu.cfg
>>>>>> > +++ b/tester/rtems/testing/qemu.cfg
>>>>>> > @@ -51,8 +51,8 @@
>>>>>> >  # Qemu common option patterns.
>>>>>> > -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>>> -nographic
>>>>>> > -%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>>>> -nographic
>>>>>> > +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>>> -nographic
>>>>>> > +#%define qemu_opts_base   -no-reboot -serial null -serial
>>>>>> mon:stdio -nographic
>>>>>> Why changing the common options for qemu?
>>>>>> actually it's a bit experimental on advice of Cillian.
>>>>> It stayed in the patch.
>>>> I know the impact of some of those options but maybe it would make sense
>>>> to add a comment block with the impact of each option? It would help
>>>> future
>>>> readers.
>>>> And, from personal experience, qemu changes arguments from time to
>>>> time. Knowing
>>>> what the old intent was helps mapping to different versions and target
>>>> architectures.
>>>> That's a good Idea.
>>>>> >  %define qemu_opts_no_net -net none
>>>>>> > 2.14.3
>>>>>> > _______________________________________________
>>>>>> > devel mailing list
>>>>>> > devel at rtems.org
>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>>>> devel mailing list
>>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/b695393d/attachment-0002.html>
