[PATCH 1/4] User: Simplify the top level headings.
chrisj at rtems.org chrisj at rtems.org
Fri Nov 2 05:55:21 UTC 2018
 user/bsps/index.rst    | 14 +++++++++++---
 user/ecosys/index.rst  |  6 ++----
 user/support/index.rst | 12 +++++++++++-
 user/tracing/index.rst |  4 ++--
 4 files changed, 26 insertions(+), 10 deletions(-)
diff --git a/user/bsps/index.rst b/user/bsps/index.rst
index c8f06d7..c1b4e4f 100644
--- a/user/bsps/index.rst
+++ b/user/bsps/index.rst
@@ -5,9 +5,17 @@
 .. _BoardSupportPackages:
-Board Support Packages (BSPs)
-.. index:: Board Support Packages (BSPs)
+Board Support Packages
+.. index:: Board Support Packages
+.. index:: BSP
+A Board Support Package or BSP is the software that glues a specific target or
+board or piece of hardware to RTEMS so it's services are available to
+applications.
+RTEMS contains a large number of BSPs for commonly available simulators and
+target hardware.
 .. toctree::
diff --git a/user/ecosys/index.rst b/user/ecosys/index.rst
index 1ea97df..f41cbb3 100644
--- a/user/ecosys/index.rst
+++ b/user/ecosys/index.rst
@@ -5,8 +5,8 @@
 .. _ecosystem:
-RTEMS Ecosystem
+Ecosystem
 .. index:: Ecosystem
 The RTEMS Ecosystem is the collection of tools, packages, code, documentation
@@ -239,5 +239,3 @@ build set::
   2. The GDB package tar file.
   3. The build set tar file. All the others in a single tar file.
diff --git a/user/support/index.rst b/user/support/index.rst
index 3e6aeef..294b7e4 100644
--- a/user/support/index.rst
+++ b/user/support/index.rst
@@ -1,7 +1,8 @@
 .. comment SPDX-License-Identifier: CC-BY-SA-4.0
 Support
+.. index:: Support
 RTEMS offers a variety of support options.
@@ -11,12 +12,15 @@ developers mailing list is the default location to send the report.
 RTEMS Project Support
+.. index:: RTEMS Project Support
 The following support channels are provided by the RTEMS Project and provide
 direct access to the RTEMS community.
 Bug Tracker
+.. index:: Bugs
+.. index:: Reporting bugs
 The bug tracker can be found at the :r:url:`bugs`.
@@ -38,6 +42,8 @@ The latest user documentation can always be found at the :r:url:`docs`.
 Mailing Lists
+.. index:: Community
+.. index:: Mailing lists
 We have several mailing lists for RTEMS users and developers.
@@ -63,6 +69,8 @@ We have several mailing lists for RTEMS users and developers.
 IRC
+.. index:: IRC
 RTEMS IRC is available on the Freenode network. See the `Freenode
 <http://www.freenode.net/>`_ web site for details on connecting, selecting a
@@ -86,6 +94,8 @@ to your search terms.
 Developers
+.. index:: Developers
 Developers can find help and support on the mailing lists, see
 :ref:`support-mailing-lists`.
diff --git a/user/tracing/index.rst b/user/tracing/index.rst
index 0d714bc..ac988fc 100644
--- a/user/tracing/index.rst
+++ b/user/tracing/index.rst
@@ -5,8 +5,8 @@
 .. _tracing-framework:
-RTEMS Tracing Framework
+Tracing
 .. index:: Tracing Framework
 RTEMS Tracing Framework is an on-target software based system which helps track
2.14.1
