Counter vs Btimer for tmtests
Joel Sherrill
joel at rtems.org
Wed Nov 7 18:05:54 UTC 2018
Thanks.
A ticket needs to be filed to convert the tests if the counter works on all
BSPs.
What are the BSP requirements for counter?
Also, it likely means that results need to be recalibrated and cannot be
compared
for historical purposes.
At this point, I consider the two tests using counter future looking and
outliers.
--joel
On Wed, Nov 7, 2018 at 12:00 PM Sebastian Huber <
> ----- Am 7. Nov 2018 um 18:13 schrieb joel joel at rtems.org:
> > Hi
> > Do these report the same units?
> Not necessarily.
> > If not, there are only *tmtests which use rtems/counter.h and thus would
> be
> > reporting numbers with different units than the btimer.
> You can convert the counter value to nanoseconds:
> https://docs.rtems.org/doxygen/branches/master/group__ClassicCounter.html#ga3e50a042e60bfcafdff5dbd46cad8947
> This is used by some tests for the XML output which can be used to plot
> some graphs:
> https://git.rtems.org/rtems/tree/testsuites/tmtests/tmcontext01/tmcontext01.scn
> https://git.rtems.org/rtems/tree/testsuites/tmtests/tmcontext01/plot.py
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181107/367cfef6/attachment.html>
