[PATCH] m68k/mcf52235: Add missing Copyright/License notices
Wed Nov 7 18:20:57 UTC 2018
From: Marçal Comajoan Cara <mcomajoancara at gmail.com>
Closes #2541.
 bsps/m68k/mcf52235/btimer/btimer.c   | 11 +++++++----
 bsps/m68k/mcf52235/clock/clock.c     | 13 +++++++++++++
 bsps/m68k/mcf52235/console/console.c | 26 +++++++++++++++++++++-----
 bsps/m68k/mcf52235/console/debugio.c | 19 ++++++++++++++-----
 bsps/m68k/mcf52235/include/bsp.h     | 14 +++++++++++++-
 bsps/m68k/mcf52235/include/tm27.h    | 10 +++++++++-
 bsps/m68k/mcf52235/start/init52235.c | 12 ++++++++++++
 bsps/m68k/mcf52235/start/linkcmds    | 11 ++++++++---
 bsps/m68k/mcf52235/start/start.S     |  9 +++++++--
 9 files changed, 104 insertions(+), 21 deletions(-)
diff --git a/bsps/m68k/mcf52235/btimer/btimer.c b/bsps/m68k/mcf52235/btimer/btimer.c
index f912254..5987481 100644
--- a/bsps/m68k/mcf52235/btimer/btimer.c
+++ b/bsps/m68k/mcf52235/btimer/btimer.c
@@ -2,10 +2,13 @@
  *  Timer Init
  *  Use the last DMA timer (DTIM3) as the diagnostic timer.
- *  Author: W. Eric Norum <norume at aps.anl.gov>
- *  COPYRIGHT (c) 2005.
+ *  COPYRIGHT (c) 2018
+ *  Eric Norum <WENorum at lbl.gov>
+ *  Matthew Riek <matthew.riek at ibiscomputer.com.au>
+ *  Ralf Corsepius <ralf.corsepius at rtems.org>
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may be
diff --git a/bsps/m68k/mcf52235/clock/clock.c b/bsps/m68k/mcf52235/clock/clock.c
index d5e1817..f40abbc 100644
--- a/bsps/m68k/mcf52235/clock/clock.c
+++ b/bsps/m68k/mcf52235/clock/clock.c
@@ -2,6 +2,19 @@
  * Use the last periodic interval timer (PIT2) as the system clock.
+ *  Alexander Krutwig <alexander.krutwig at embedded-brains.de>
+ *  Sebastian Huber <sebastian.huber at embedded-brains.de>
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
 #include <rtems/timecounter.h>
 #include <bsp.h>
diff --git a/bsps/m68k/mcf52235/console/console.c b/bsps/m68k/mcf52235/console/console.c
index c2b6e36..68d2b5e 100644
--- a/bsps/m68k/mcf52235/console/console.c
+++ b/bsps/m68k/mcf52235/console/console.c
@@ -1,8 +1,24 @@
-  *  Multi UART console serial I/O.
-  * TO DO: Add DMA input/output
+ *  Multi UART console serial I/O.
+ *  TO DO: Add DMA input/output
+ *  Kevin Kirspel <kevin-kirspel at idexx.com>
+ *  Mike Bertosh <mbertosh at motioncontrol.org>
+ *  Thomas Doerfler <Thomas.Doerfler at embedded-brains.de>
 #include <fcntl.h>
diff --git a/bsps/m68k/mcf52235/console/debugio.c b/bsps/m68k/mcf52235/console/debugio.c
index 1fbf4b0..e1c1aaa 100644
--- a/bsps/m68k/mcf52235/console/debugio.c
+++ b/bsps/m68k/mcf52235/console/debugio.c
@@ -1,8 +1,17 @@
 #include <fcntl.h>
diff --git a/bsps/m68k/mcf52235/include/bsp.h b/bsps/m68k/mcf52235/include/bsp.h
index ef3b928..465ecdd 100644
--- a/bsps/m68k/mcf52235/include/bsp.h
+++ b/bsps/m68k/mcf52235/include/bsp.h
@@ -7,7 +7,19 @@
- *  mcf52235 BSP header file
+ *  Chris Johns <chrisj at rtems.org>
+ *  Gedare Bloom <gedare at rtems.org>
 #ifndef LIBBSP_M68K_MCF52235_BSP_H
diff --git a/bsps/m68k/mcf52235/include/tm27.h b/bsps/m68k/mcf52235/include/tm27.h
index b4b62ef..9d3af4b 100644
--- a/bsps/m68k/mcf52235/include/tm27.h
+++ b/bsps/m68k/mcf52235/include/tm27.h
@@ -1,10 +1,18 @@
  * @file
  * @ingroup m68k_mcf52235
  * @brief Implementations for interrupt mechanisms for Time Test 27
diff --git a/bsps/m68k/mcf52235/start/init52235.c b/bsps/m68k/mcf52235/start/init52235.c
index d54b624..505d9ac 100644
--- a/bsps/m68k/mcf52235/start/init52235.c
+++ b/bsps/m68k/mcf52235/start/init52235.c
@@ -4,6 +4,18 @@
  *  functions can be called from here.
 #include <bsp.h>
 #include <bsp/bootcard.h>
diff --git a/bsps/m68k/mcf52235/start/linkcmds b/bsps/m68k/mcf52235/start/linkcmds
index 0c4d15f..ceac10f 100644
--- a/bsps/m68k/mcf52235/start/linkcmds
+++ b/bsps/m68k/mcf52235/start/linkcmds
@@ -1,13 +1,18 @@
  *  This file contains directives for the GNU linker which are specific
  *  to the Freescale ColdFire mcf52235
- *  COPYRIGHT (c) 1989-1999.
- *  http://www.rtems.org/license/LICENSE.e
diff --git a/bsps/m68k/mcf52235/start/start.S b/bsps/m68k/mcf52235/start/start.S
index ecb2c5c..ba92b66 100644
--- a/bsps/m68k/mcf52235/start/start.S
+++ b/bsps/m68k/mcf52235/start/start.S
@@ -5,8 +5,13 @@
  *  The name of this entry point is compiler dependent.
  *  It jumps to the BSP which is responsible for performing
  *  all initialization.
- *  COPYRIGHT (c) 1989-1998.
1.8.3.1
