[PATCH v2] m68k/mcf52235: Add missing Copyright/License notices
Joel Sherrill
joel at rtems.org
Wed Nov 7 18:22:39 UTC 2018
This work was part of GCI 2018.
Closes #2541.
bsps/m68k/mcf52235/btimer/btimer.c | 11 +++++++----
bsps/m68k/mcf52235/clock/clock.c | 13 +++++++++++++
bsps/m68k/mcf52235/console/console.c | 26 +++++++++++++++++++++-----
bsps/m68k/mcf52235/console/debugio.c | 19 ++++++++++++++-----
bsps/m68k/mcf52235/include/bsp.h | 14 +++++++++++++-
bsps/m68k/mcf52235/include/tm27.h | 10 +++++++++-
bsps/m68k/mcf52235/start/init52235.c | 12 ++++++++++++
bsps/m68k/mcf52235/start/linkcmds | 11 ++++++++---
bsps/m68k/mcf52235/start/start.S | 9 +++++++--
9 files changed, 104 insertions(+), 21 deletions(-)
diff --git a/bsps/m68k/mcf52235/btimer/btimer.c b/bsps/m68k/mcf52235/btimer/btimer.c
index f912254..5987481 100644
--- a/bsps/m68k/mcf52235/btimer/btimer.c
+++ b/bsps/m68k/mcf52235/btimer/btimer.c
@@ -2,10 +2,13 @@
* Timer Init
* Use the last DMA timer (DTIM3) as the diagnostic timer.
- * Author: W. Eric Norum <norume at aps.anl.gov>
- * COPYRIGHT (c) 2005.
+ * COPYRIGHT (c) 2018
+ * Eric Norum <WENorum at lbl.gov>
+ * Matthew Riek <matthew.riek at ibiscomputer.com.au>
+ * Ralf Corsepius <ralf.corsepius at rtems.org>
* On-Line Applications Research Corporation (OAR).
* The license and distribution terms for this file may be
diff --git a/bsps/m68k/mcf52235/clock/clock.c b/bsps/m68k/mcf52235/clock/clock.c
index d5e1817..f40abbc 100644
--- a/bsps/m68k/mcf52235/clock/clock.c
+++ b/bsps/m68k/mcf52235/clock/clock.c
@@ -2,6 +2,19 @@
* Use the last periodic interval timer (PIT2) as the system clock.
+ * Alexander Krutwig <alexander.krutwig at embedded-brains.de>
+ * Sebastian Huber <sebastian.huber at embedded-brains.de>
+ * On-Line Applications Research Corporation (OAR).
#include <rtems/timecounter.h>
#include <bsp.h>
diff --git a/bsps/m68k/mcf52235/console/console.c b/bsps/m68k/mcf52235/console/console.c
index c2b6e36..68d2b5e 100644
--- a/bsps/m68k/mcf52235/console/console.c
+++ b/bsps/m68k/mcf52235/console/console.c
@@ -1,8 +1,24 @@
- * Multi UART console serial I/O.
- * TO DO: Add DMA input/output
+ * Multi UART console serial I/O.
+ * TO DO: Add DMA input/output
+ * Kevin Kirspel <kevin-kirspel at idexx.com>
+ * Mike Bertosh <mbertosh at motioncontrol.org>
+ * Thomas Doerfler <Thomas.Doerfler at embedded-brains.de>
#include <fcntl.h>
diff --git a/bsps/m68k/mcf52235/console/debugio.c b/bsps/m68k/mcf52235/console/debugio.c
index 1fbf4b0..e1c1aaa 100644
--- a/bsps/m68k/mcf52235/console/debugio.c
+++ b/bsps/m68k/mcf52235/console/debugio.c
@@ -1,8 +1,17 @@
#include <fcntl.h>
diff --git a/bsps/m68k/mcf52235/include/bsp.h b/bsps/m68k/mcf52235/include/bsp.h
index ef3b928..465ecdd 100644
--- a/bsps/m68k/mcf52235/include/bsp.h
+++ b/bsps/m68k/mcf52235/include/bsp.h
@@ -7,7 +7,19 @@
- * mcf52235 BSP header file
+ * Chris Johns <chrisj at rtems.org>
+ * Gedare Bloom <gedare at rtems.org>
#ifndef LIBBSP_M68K_MCF52235_BSP_H
diff --git a/bsps/m68k/mcf52235/include/tm27.h b/bsps/m68k/mcf52235/include/tm27.h
index b4b62ef..9d3af4b 100644
--- a/bsps/m68k/mcf52235/include/tm27.h
+++ b/bsps/m68k/mcf52235/include/tm27.h
@@ -1,10 +1,18 @@
* @file
* @ingroup m68k_mcf52235
* @brief Implementations for interrupt mechanisms for Time Test 27
diff --git a/bsps/m68k/mcf52235/start/init52235.c b/bsps/m68k/mcf52235/start/init52235.c
index d54b624..505d9ac 100644
--- a/bsps/m68k/mcf52235/start/init52235.c
+++ b/bsps/m68k/mcf52235/start/init52235.c
@@ -4,6 +4,18 @@
* functions can be called from here.
#include <bsp.h>
#include <bsp/bootcard.h>
diff --git a/bsps/m68k/mcf52235/start/linkcmds b/bsps/m68k/mcf52235/start/linkcmds
index 0c4d15f..ceac10f 100644
--- a/bsps/m68k/mcf52235/start/linkcmds
+++ b/bsps/m68k/mcf52235/start/linkcmds
@@ -1,13 +1,18 @@
* This file contains directives for the GNU linker which are specific
* to the Freescale ColdFire mcf52235
- * COPYRIGHT (c) 1989-1999.
- * http://www.rtems.org/license/LICENSE.e
diff --git a/bsps/m68k/mcf52235/start/start.S b/bsps/m68k/mcf52235/start/start.S
index ecb2c5c..ba92b66 100644
--- a/bsps/m68k/mcf52235/start/start.S
+++ b/bsps/m68k/mcf52235/start/start.S
@@ -5,8 +5,13 @@
* The name of this entry point is compiler dependent.
* It jumps to the BSP which is responsible for performing
* all initialization.
- * COPYRIGHT (c) 1989-1998.
1.8.3.1
