[PATCH 15/21] score: Avoid include of <rtems/score/thread.h>
Thu Nov 8 12:52:08 UTC 2018
Update #3598.
 cpukit/include/rtems/score/userext.h     | 29 +++++++++++++++--------------
 cpukit/include/rtems/score/userextimpl.h |  3 ++-
 2 files changed, 17 insertions(+), 15 deletions(-)
diff --git a/cpukit/include/rtems/score/userext.h b/cpukit/include/rtems/score/userext.h
index 5af5824808..7b80227f37 100644
--- a/cpukit/include/rtems/score/userext.h
+++ b/cpukit/include/rtems/score/userext.h
@@ -20,12 +20,13 @@
 #include <rtems/score/interr.h>
-#include <rtems/score/thread.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
+struct _Thread_Control;
 typedef void User_extensions_routine RTEMS_DEPRECATED;
@@ -69,8 +70,8 @@ typedef void User_extensions_routine RTEMS_DEPRECATED;
  * return @a false and the entire thread create operation will fail.
 typedef bool ( *User_extensions_thread_create_extension )(
-  Thread_Control *executing,
-  Thread_Control *created
+  struct _Thread_Control *executing,
+  struct _Thread_Control *created
@@ -89,8 +90,8 @@ typedef bool ( *User_extensions_thread_create_extension )(
  * @param[in] deleted The deleted thread.
 typedef void( *User_extensions_thread_delete_extension )(
-  Thread_Control *deleted
+  struct _Thread_Control *deleted
@@ -109,8 +110,8 @@ typedef void( *User_extensions_thread_delete_extension )(
  * @param[in] started The started thread.
 typedef void( *User_extensions_thread_start_extension )(
-  Thread_Control *started
+  struct _Thread_Control *started
@@ -131,8 +132,8 @@ typedef void( *User_extensions_thread_start_extension )(
  * @param[in] restarted The executing thread.  Yes, the executing thread.
 typedef void( *User_extensions_thread_restart_extension )(
-  Thread_Control *restarted
+  struct _Thread_Control *restarted
@@ -154,8 +155,8 @@ typedef void( *User_extensions_thread_restart_extension )(
  * @param[in] heir The heir thread.
 typedef void( *User_extensions_thread_switch_extension )(
-  Thread_Control *heir
+  struct _Thread_Control *heir
@@ -169,7 +170,7 @@ typedef void( *User_extensions_thread_switch_extension )(
  * @param[in] executing The executing thread.
 typedef void( *User_extensions_thread_begin_extension )(
@@ -183,7 +184,7 @@ typedef void( *User_extensions_thread_begin_extension )(
 typedef void( *User_extensions_thread_exitted_extension )(
@@ -223,7 +224,7 @@ typedef void( *User_extensions_fatal_extension )(
  * @param[in] terminated The terminated thread.
 typedef void( *User_extensions_thread_terminate_extension )(
-  Thread_Control *terminated
+  struct _Thread_Control *terminated
diff --git a/cpukit/include/rtems/score/userextimpl.h b/cpukit/include/rtems/score/userextimpl.h
index 5ad2c63765..a842ae8e86 100644
--- a/cpukit/include/rtems/score/userextimpl.h
+++ b/cpukit/include/rtems/score/userextimpl.h
@@ -19,8 +19,9 @@
 #define _RTEMS_SCORE_USEREXTIMPL_H
 #include <rtems/score/userext.h>
-#include <rtems/score/isrlock.h>
+#include <rtems/score/isrlock.h>
+#include <rtems/score/thread.h>
 #ifdef __cplusplus
2.16.4
