[PATCH 09/21] rtems: Move internal structures to regiondata.h
Thu Nov 8 12:52:02 UTC 2018
Update #3598.
 cpukit/headers.am                       |  1 +
 cpukit/include/rtems/confdefs.h         |  1 +
 cpukit/include/rtems/rtems/region.h     | 35 ++-------------------
 cpukit/include/rtems/rtems/regiondata.h | 56 +++++++++++++++++++++++++++++++++
 cpukit/include/rtems/rtems/regionimpl.h |  2 +-
 cpukit/libmisc/monitor/mon-region.c     |  1 +
 6 files changed, 63 insertions(+), 33 deletions(-)
 create mode 100644 cpukit/include/rtems/rtems/regiondata.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index a274647105..95bc817773 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -260,6 +260,7 @@ include_rtems_rtems_HEADERS += include/rtems/rtems/ratemon.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/ratemondata.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/ratemonimpl.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/region.h
+include_rtems_rtems_HEADERS += include/rtems/rtems/regiondata.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/regionimpl.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/sem.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/semimpl.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 4eed0d2cfc..7b2b47ae00 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -37,6 +37,7 @@
 #include <rtems/rtems/messagedata.h>
 #include <rtems/rtems/partdata.h>
 #include <rtems/rtems/ratemondata.h>
+#include <rtems/rtems/regiondata.h>
 #include <rtems/posix/key.h>
 #include <rtems/posix/mqueue.h>
 #include <rtems/posix/pthread.h>
diff --git a/cpukit/include/rtems/rtems/region.h b/cpukit/include/rtems/rtems/region.h
index 4772e2835b..baa8a72806 100644
--- a/cpukit/include/rtems/rtems/region.h
+++ b/cpukit/include/rtems/rtems/region.h
@@ -1,22 +1,9 @@
- * @file rtems/rtems/region.h
+ * @file
- * @defgroup ClassicRegion Regions
+ * @ingroup ClassicRegion
- * @ingroup ClassicRTEMS
- * @brief Region Manager
- * This include file contains all the constants and structures associated
- * with the Region Manager. This manager provides facilities to dynamically
- * allocate memory in variable sized units which are returned as segments.
- * Directives provided are:
- * - create a region
- * - get an ID of a region
- * - delete a region
- * - get a segment from a region
- * - return a segment to a region
+ * @brief Classic Region Manager API
 /* COPYRIGHT (c) 1989-2013.
@@ -34,8 +21,6 @@
 #include <rtems/rtems/options.h>
-#include <rtems/score/heap.h>
-#include <rtems/score/threadq.h>
 #ifdef __cplusplus
 extern "C" {
@@ -51,20 +36,6 @@ extern "C" {
- *  The following records define the control block used to manage
- *  each region.
-typedef struct {
-  Objects_Control       Object;
-  Thread_queue_Control  Wait_queue;            /* waiting threads        */
-  const Thread_queue_Operations *wait_operations;
-  uintptr_t             maximum_segment_size;  /* in bytes               */
-  rtems_attribute       attribute_set;
-  Heap_Control          Memory;
-}  Region_Control;
  *  @brief rtems_region_create
diff --git a/cpukit/include/rtems/rtems/regiondata.h b/cpukit/include/rtems/rtems/regiondata.h
new file mode 100644
index 0000000000..75fc950691
--- /dev/null
+++ b/cpukit/include/rtems/rtems/regiondata.h
@@ -0,0 +1,56 @@
+ * @file
+ * @ingroup ClassicRegionImpl
+ * @brief Classic Region Manager Data Structures
+/* COPYRIGHT (c) 1989-2013.
+ * On-Line Applications Research Corporation (OAR).
+#ifndef _RTEMS_RTEMS_REGIONDATA_H
+#define _RTEMS_RTEMS_REGIONDATA_H
+#include <rtems/rtems/region.h>
+#include <rtems/score/heap.h>
+#include <rtems/score/object.h>
+#include <rtems/score/threadq.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup ClassicRegionImpl
+ *  The following records define the control block used to manage
+ *  each region.
+typedef struct {
+  Objects_Control       Object;
+  Thread_queue_Control  Wait_queue;            /* waiting threads        */
+  const Thread_queue_Operations *wait_operations;
+  uintptr_t             maximum_segment_size;  /* in bytes               */
+  rtems_attribute       attribute_set;
+  Heap_Control          Memory;
+}  Region_Control;
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/include/rtems/rtems/regionimpl.h b/cpukit/include/rtems/rtems/regionimpl.h
index 178b7ea32b..8a7ee258cc 100644
--- a/cpukit/include/rtems/rtems/regionimpl.h
+++ b/cpukit/include/rtems/rtems/regionimpl.h
@@ -17,7 +17,7 @@
 #ifndef _RTEMS_RTEMS_REGIONIMPL_H
 #define _RTEMS_RTEMS_REGIONIMPL_H
-#include <rtems/rtems/region.h>
 #include <rtems/score/apimutex.h>
 #include <rtems/score/heapimpl.h>
diff --git a/cpukit/libmisc/monitor/mon-region.c b/cpukit/libmisc/monitor/mon-region.c
index 023ada77cf..ece6a6a788 100644
--- a/cpukit/libmisc/monitor/mon-region.c
+++ b/cpukit/libmisc/monitor/mon-region.c
@@ -9,6 +9,7 @@
 #include <rtems/monitor.h>
 #include <string.h>    /* memcpy() */
2.16.4
