[PATCH 10/21] rtems: Move internal structures to semdata.h
Thu Nov 8 12:52:03 UTC 2018
Update #3598.
 cpukit/headers.am                    |   1 +
 cpukit/include/rtems/confdefs.h      |   1 +
 cpukit/include/rtems/rtems/sem.h     |  84 ++---------------------------
 cpukit/include/rtems/rtems/semdata.h | 102 +++++++++++++++++++++++++++++++++++
 cpukit/include/rtems/rtems/semimpl.h |  16 ++++--
 cpukit/rtems/src/semcreate.c         |   1 +
 6 files changed, 121 insertions(+), 84 deletions(-)
 create mode 100644 cpukit/include/rtems/rtems/semdata.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 95bc817773..02f45542d7 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -263,6 +263,7 @@ include_rtems_rtems_HEADERS += include/rtems/rtems/region.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/regiondata.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/regionimpl.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/sem.h
+include_rtems_rtems_HEADERS += include/rtems/rtems/semdata.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/semimpl.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/semmp.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/signal.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 7b2b47ae00..0062d3934f 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -38,6 +38,7 @@
 #include <rtems/rtems/partdata.h>
 #include <rtems/rtems/ratemondata.h>
 #include <rtems/rtems/regiondata.h>
+#include <rtems/rtems/semdata.h>
 #include <rtems/posix/key.h>
 #include <rtems/posix/mqueue.h>
 #include <rtems/posix/pthread.h>
diff --git a/cpukit/include/rtems/rtems/sem.h b/cpukit/include/rtems/rtems/sem.h
index 41b0061979..8e83848465 100644
--- a/cpukit/include/rtems/rtems/sem.h
+++ b/cpukit/include/rtems/rtems/sem.h
@@ -3,22 +3,7 @@
  * @ingroup ClassicSem
- * @brief Classic Semaphores API
- * This include file contains all the constants and structures associated
- * with the Semaphore Manager. This manager utilizes standard Dijkstra
- * counting semaphores to provide synchronization and mutual exclusion
- * capabilities.
- * Directives provided are:
- * - create a semaphore
- * - get an ID of a semaphore
- * - delete a semaphore
- * - acquire a semaphore
- * - release a semaphore
- * - flush a semaphore
- * - set ceiling priority for a semaphore
+ * @brief Classic Semaphores Manager API
@@ -33,15 +18,10 @@
 #ifndef _RTEMS_RTEMS_SEM_H
 #define _RTEMS_RTEMS_SEM_H
-#include <rtems/rtems/types.h>
+#include <rtems/rtems/attr.h>
 #include <rtems/rtems/options.h>
-#include <rtems/rtems/support.h>
-#include <rtems/rtems/attr.h>
-#include <rtems/score/coremutex.h>
-#include <rtems/score/object.h>
-#include <rtems/score/coresem.h>
-#include <rtems/score/mrsp.h>
+#include <rtems/rtems/types.h>
 #ifdef __cplusplus
 extern "C" {
@@ -57,64 +37,6 @@ extern "C" {
- *  The following defines the control block used to manage each semaphore.
-typedef struct {
-  /** This field is the object management portion of a Semaphore instance. */
-  Objects_Control          Object;
-   *  This contains the memory associated with the SuperCore Semaphore or
-   *  Mutex instance that provides the primary functionality of each
-   *  Classic API Semaphore instance.  The structure used is dependent
-   *  on the attributes specified by the user on the create directive.
-   *  @note Only one of these has meaning in a particular Classic API
-   *        Semaphore instance.
-  union {
-     * @brief The thread queue present in all other variants.
-    Thread_queue_Control Wait_queue;
-     *  This is the SuperCore Mutex instance associated with this Classic
-     *  API Semaphore instance.
-    CORE_ceiling_mutex_Control Mutex;
-     *  This is the SuperCore Semaphore instance associated with this Classic
-    CORE_semaphore_Control Semaphore;
-#if defined(RTEMS_SMP)
-    MRSP_Control MRSP;
-#endif
-  } Core_control;
-   * @brief The semaphore variant.
-   * @see Semaphore_Variant.
-  unsigned int variant : 3;
-   * @brief The semaphore thread queue discipline.
-   * @see Semaphore_Discipline.
-  unsigned int discipline : 1;
-#if defined(RTEMS_MULTIPROCESSING)
-  unsigned int is_global : 1;
-#endif
-}   Semaphore_Control;
  *  @brief rtems_semaphore_create
diff --git a/cpukit/include/rtems/rtems/semdata.h b/cpukit/include/rtems/rtems/semdata.h
new file mode 100644
index 0000000000..04db07d6a0
--- /dev/null
+++ b/cpukit/include/rtems/rtems/semdata.h
@@ -0,0 +1,102 @@
+ * @file
+ * @ingroup ClassicSemImpl
+ * @brief Classic Semaphore Manager Data Structures
+ * COPYRIGHT (c) 1989-2008, 2016.
+ * On-Line Applications Research Corporation (OAR).
+#ifndef _RTEMS_RTEMS_SEMDATA_H
+#define _RTEMS_RTEMS_SEMDATA_H
+#include <rtems/rtems/sem.h>
+#include <rtems/score/coremutex.h>
+#include <rtems/score/coresem.h>
+#include <rtems/score/mrsp.h>
+#include <rtems/score/object.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup ClassicSemImpl
+ *  The following defines the control block used to manage each semaphore.
+typedef struct {
+  /** This field is the object management portion of a Semaphore instance. */
+  Objects_Control          Object;
+   *  This contains the memory associated with the SuperCore Semaphore or
+   *  Mutex instance that provides the primary functionality of each
+   *  Classic API Semaphore instance.  The structure used is dependent
+   *  on the attributes specified by the user on the create directive.
+   *  @note Only one of these has meaning in a particular Classic API
+   *        Semaphore instance.
+  union {
+     * @brief The thread queue present in all other variants.
+    Thread_queue_Control Wait_queue;
+     *  This is the SuperCore Mutex instance associated with this Classic
+     *  API Semaphore instance.
+    CORE_ceiling_mutex_Control Mutex;
+     *  This is the SuperCore Semaphore instance associated with this Classic
+    CORE_semaphore_Control Semaphore;
+#if defined(RTEMS_SMP)
+    MRSP_Control MRSP;
+#endif
+  } Core_control;
+   * @brief The semaphore variant.
+   * @see Semaphore_Variant.
+  unsigned int variant : 3;
+   * @brief The semaphore thread queue discipline.
+   * @see Semaphore_Discipline.
+  unsigned int discipline : 1;
+#if defined(RTEMS_MULTIPROCESSING)
+  unsigned int is_global : 1;
+#endif
+}   Semaphore_Control;
+#ifdef __cplusplus
+#endif
+#endif
+/*  end of include file */
diff --git a/cpukit/include/rtems/rtems/semimpl.h b/cpukit/include/rtems/rtems/semimpl.h
index 6d0f156e5c..1028879f39 100644
--- a/cpukit/include/rtems/rtems/semimpl.h
+++ b/cpukit/include/rtems/rtems/semimpl.h
@@ -1,9 +1,9 @@
  * @file
- * @ingroup ClassicSem
- * @brief Classic Semaphores Implementation
+ * @brief Classic Semaphore Manager Implementation
 /*  COPYRIGHT (c) 1989-2008.
@@ -17,7 +17,7 @@
 #ifndef _RTEMS_RTEMS_SEMIMPL_H
 #define _RTEMS_RTEMS_SEMIMPL_H
-#include <rtems/rtems/sem.h>
 #include <rtems/score/coresemimpl.h>
 #include <rtems/score/mrspimpl.h>
@@ -26,6 +26,14 @@
 extern "C" {
 #endif
+ * @defgroup ClassicSemImpl Semaphore Manager Implementation
  * @brief Classic semaphore variants.
@@ -108,6 +116,8 @@ RTEMS_INLINE_ROUTINE Semaphore_Control *_Semaphore_Get(
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index 77ee3d366d..fd266f8cd5 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -21,6 +21,7 @@
 #include <rtems/rtems/statusimpl.h>
+#include <rtems/rtems/support.h>
 #include <rtems/score/sysstate.h>
2.16.4
