[PATCH 11/21] rtems: Move internal structures to tasksdata.h
Thu Nov 8 12:52:04 UTC 2018
Update #3598.
 cpukit/headers.am                      |  1 +
 cpukit/include/rtems/confdefs.h        |  1 +
 cpukit/include/rtems/rtems/tasks.h     | 62 ++-------------------------
 cpukit/include/rtems/rtems/tasksdata.h | 76 ++++++++++++++++++++++++++++++++++
 cpukit/include/rtems/rtems/tasksimpl.h |  2 +-
 cpukit/libmisc/monitor/mon-task.c      |  1 +
 cpukit/rtems/src/eventreceive.c        |  2 +-
 cpukit/rtems/src/eventsend.c           |  2 +-
 cpukit/rtems/src/signalcatch.c         |  2 +-
 cpukit/rtems/src/signalsend.c          |  2 +-
 cpukit/rtems/src/systemeventreceive.c  |  2 +-
 cpukit/rtems/src/systemeventsend.c     |  2 +-
 cpukit/rtems/src/taskmode.c            |  2 +-
 13 files changed, 90 insertions(+), 67 deletions(-)
 create mode 100644 cpukit/include/rtems/rtems/tasksdata.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 02f45542d7..458c0ae75d 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -275,6 +275,7 @@ include_rtems_rtems_HEADERS += include/rtems/rtems/statusimpl.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/support.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/taskmp.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/tasks.h
+include_rtems_rtems_HEADERS += include/rtems/rtems/tasksdata.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/tasksimpl.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/timer.h
 include_rtems_rtems_HEADERS += include/rtems/rtems/timerimpl.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 0062d3934f..5ba3caebca 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -39,6 +39,7 @@
 #include <rtems/rtems/ratemondata.h>
 #include <rtems/rtems/regiondata.h>
 #include <rtems/rtems/semdata.h>
+#include <rtems/rtems/tasksdata.h>
 #include <rtems/posix/key.h>
 #include <rtems/posix/mqueue.h>
 #include <rtems/posix/pthread.h>
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 10f8936a0f..e0272e06f9 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -1,28 +1,9 @@
- * @file rtems/rtems/tasks.h
+ * @file
- * @defgroup ClassicTasks Tasks
+ * @ingroup ClassicTasks
- * @ingroup ClassicRTEMS
- * @brief RTEMS Tasks
- * This include file contains all constants and structures associated
- * with RTEMS tasks. This manager provides a comprehensive set of directives
- * to create, delete, and administer tasks.
- * Directives provided are:
- * - create a task
- * - get an ID of a task
- * - start a task
- * - restart a task
- * - delete a task
- * - suspend a task
- * - resume a task
- * - set a task's priority
- * - change the current task's mode
- * - wake up after interval
- * - wake up when specified
+ * @brief Classic Task Manager API
@@ -37,12 +18,9 @@
 #ifndef _RTEMS_RTEMS_TASKS_H
 #define _RTEMS_RTEMS_TASKS_H
-#include <rtems/score/object.h>
-#include <rtems/rtems/asrdata.h>
 #include <rtems/rtems/attr.h>
-#include <rtems/rtems/eventdata.h>
@@ -676,40 +654,6 @@ rtems_status_code rtems_scheduler_remove_processor(
- *  This is the API specific information required by each thread for
- *  the RTEMS API to function correctly.
-typedef struct {
-  /** This field contains the event control for this task. */
-  Event_Control            Event;
-  /** This field contains the system event control for this task. */
-  Event_Control            System_event;
-  /** This field contains the Classic API Signal information for this task. */
-  ASR_Information          Signal;
-   * @brief Signal post-switch action in case signals are pending.
-  Thread_Action            Signal_action;
-}  RTEMS_API_Control;
- *  @brief _RTEMS_tasks_Initialize_user_tasks_body
- *  This routine creates and starts all configured user
- *  initialization threads.
- *  Input parameters: NONE
- *  Output parameters:  NONE
- *  RTEMS Task Manager
-extern void _RTEMS_tasks_Initialize_user_tasks_body( void );
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/include/rtems/rtems/tasksdata.h b/cpukit/include/rtems/rtems/tasksdata.h
new file mode 100644
index 0000000000..22e524d027
--- /dev/null
+++ b/cpukit/include/rtems/rtems/tasksdata.h
@@ -0,0 +1,76 @@
+ * @file
+ * @ingroup ClassicTasksImpl
+ * @brief Classic Tasks Manager Data Structures
+ * COPYRIGHT (c) 1989-2014.
+ * On-Line Applications Research Corporation (OAR).
+#ifndef _RTEMS_RTEMS_TASKSDATA_H
+#define _RTEMS_RTEMS_TASKSDATA_H
+#include <rtems/rtems/tasks.h>
+#include <rtems/rtems/asrdata.h>
+#include <rtems/rtems/eventdata.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup ClassicTasksImpl
+ *  This is the API specific information required by each thread for
+ *  the RTEMS API to function correctly.
+typedef struct {
+  /** This field contains the event control for this task. */
+  Event_Control            Event;
+  /** This field contains the system event control for this task. */
+  Event_Control            System_event;
+  /** This field contains the Classic API Signal information for this task. */
+  ASR_Information          Signal;
+   * @brief Signal post-switch action in case signals are pending.
+  Thread_Action            Signal_action;
+}  RTEMS_API_Control;
+ *  @brief _RTEMS_tasks_Initialize_user_tasks_body
+ *  This routine creates and starts all configured user
+ *  initialization threads.
+ *  Input parameters: NONE
+ *  Output parameters:  NONE
+ *  RTEMS Task Manager
+extern void _RTEMS_tasks_Initialize_user_tasks_body( void );
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/include/rtems/rtems/tasksimpl.h b/cpukit/include/rtems/rtems/tasksimpl.h
index b0432351f3..b6694cc416 100644
--- a/cpukit/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/include/rtems/rtems/tasksimpl.h
@@ -17,7 +17,7 @@
 #ifndef _RTEMS_RTEMS_TASKSIMPL_H
 #define _RTEMS_RTEMS_TASKSIMPL_H
-#include <rtems/rtems/tasks.h>
diff --git a/cpukit/libmisc/monitor/mon-task.c b/cpukit/libmisc/monitor/mon-task.c
index 26528d7292..e1126b6457 100644
--- a/cpukit/libmisc/monitor/mon-task.c
+++ b/cpukit/libmisc/monitor/mon-task.c
@@ -8,6 +8,7 @@
 #include <rtems/monitor.h>
diff --git a/cpukit/rtems/src/eventreceive.c b/cpukit/rtems/src/eventreceive.c
index 193960b7b2..75a5293787 100644
--- a/cpukit/rtems/src/eventreceive.c
+++ b/cpukit/rtems/src/eventreceive.c
@@ -19,7 +19,7 @@
 #endif
 #include <rtems/rtems/eventimpl.h>
diff --git a/cpukit/rtems/src/eventsend.c b/cpukit/rtems/src/eventsend.c
index 8a159fc7f3..6a383d8892 100644
--- a/cpukit/rtems/src/eventsend.c
+++ b/cpukit/rtems/src/eventsend.c
@@ -19,7 +19,7 @@
 #endif
 rtems_status_code rtems_event_send(
diff --git a/cpukit/rtems/src/signalcatch.c b/cpukit/rtems/src/signalcatch.c
index 435ea2fa54..03c2b976d3 100644
--- a/cpukit/rtems/src/signalcatch.c
+++ b/cpukit/rtems/src/signalcatch.c
@@ -21,7 +21,7 @@
 #include <rtems/sysinit.h>
 #include <rtems/rtems/signalimpl.h>
 #include <rtems/rtems/asrimpl.h>
diff --git a/cpukit/rtems/src/signalsend.c b/cpukit/rtems/src/signalsend.c
index 777e306afc..b2931916d9 100644
--- a/cpukit/rtems/src/signalsend.c
+++ b/cpukit/rtems/src/signalsend.c
@@ -20,7 +20,7 @@
diff --git a/cpukit/rtems/src/systemeventreceive.c b/cpukit/rtems/src/systemeventreceive.c
index 93a5694eec..64093c27a5 100644
--- a/cpukit/rtems/src/systemeventreceive.c
+++ b/cpukit/rtems/src/systemeventreceive.c
@@ -25,7 +25,7 @@
 #endif
diff --git a/cpukit/rtems/src/systemeventsend.c b/cpukit/rtems/src/systemeventsend.c
index 978c49b7ac..53d9b6f1eb 100644
--- a/cpukit/rtems/src/systemeventsend.c
+++ b/cpukit/rtems/src/systemeventsend.c
@@ -25,7 +25,7 @@
 #endif
 rtems_status_code rtems_event_system_send(
diff --git a/cpukit/rtems/src/taskmode.c b/cpukit/rtems/src/taskmode.c
index e16faa53fb..7f26bff14e 100644
--- a/cpukit/rtems/src/taskmode.c
+++ b/cpukit/rtems/src/taskmode.c
@@ -18,7 +18,7 @@
 #include "config.h"
 #endif
 #include <rtems/rtems/modesimpl.h>
2.16.4
