RTEMS Plugin Xilinx SDK Not Generating HelloWorld Template
Misra, Avinash Avinash.Misra at jhuapl.edu
Sat Nov 10 18:18:10 UTC 2018
Hi,
I'm trying to get the RTEMS Plugin installed into the Xilinx SDK. The SDK is running Eclipse 4.6
[cid:image001.png at 01D478F5.6E6B3F70]
I've followed the steps from the tutorial (https://devel.rtems.org/wiki/Developer/Eclipse/Plugin)to get the Xilinx Plugin installed from the ftp website (http://ftp//ftp.rtems.org/pub/rtems/eclipse/updates/<http://ftp/ftp.rtems.org/pub/rtems/eclipse/updates/>).
I've configured Eclipse to point to the RTEMS toolchain (Installed in C:/opt/rtems/5/bin) and the Xilinx Zynq BSP that I generated outside of Eclipse as well as my MinGW and MSYS install paths.
[cid:image004.jpg at 01D478F7.D2F98490]
The issue I'm having now is that when I go to create a RTEMS HelloWorld project (New Project --> C Project --> RTEMS Hello-World Project) using the RTEMS Toolchain it just generates a blank project folder when I click finish. If I click Next and go to the select configuration page I get the following error "At least one configuration should be available. Project cannot be created."
[cid:image005.jpg at 01D478F7.D2F98490]
Any idea what might be going on? I added some screenshots to aide in troubleshooting. Let me know if these didn't make it through and I can send some links instead.
Thanks,
Avi Misra
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181110/d9050619/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181110/d9050619/attachment-0001.png>
Type: image/jpeg
Desc: image004.jpg
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181110/d9050619/attachment-0002.jpg>
Type: image/jpeg
Desc: image005.jpg
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181110/d9050619/attachment-0003.jpg>
