RTEMS Plugin Xilinx SDK Not Generating HelloWorld Template
Sat Nov 10 18:28:52 UTC 2018
Someone else developed the plugin and I have no idea what's going on with
it relative to Eclipse but if the RTEMS applicstion code generated from the
template isn't compiling, post it and more people can help solve that.
On Sat, Nov 10, 2018, 1:18 PM Misra, Avinash <Avinash.Misra at jhuapl.edu
wrote:
> Hi,
> I’m trying to get the RTEMS Plugin installed into the Xilinx SDK. The SDK
> is running Eclipse 4.6
> I’ve followed the steps from the tutorial (
> https://devel.rtems.org/wiki/Developer/Eclipse/Plugin)to get the Xilinx
> Plugin installed from the ftp website (
> http://ftp//ftp.rtems.org/pub/rtems/eclipse/updates/
> <http://ftp/ftp.rtems.org/pub/rtems/eclipse/updates/>).
> I’ve configured Eclipse to point to the RTEMS toolchain (Installed in
> C:/opt/rtems/5/bin) and the Xilinx Zynq BSP that I generated outside of
> Eclipse as well as my MinGW and MSYS install paths.
> The issue I’m having now is that when I go to create a RTEMS HelloWorld
> project (New Project à C Project à RTEMS Hello-World Project) using the
> RTEMS Toolchain it just generates a blank project folder when I click
> finish. If I click Next and go to the select configuration page I get the
> following error “*At least one configuration should be available. Project
> cannot be created.”*
> Any idea what might be going on? I added some screenshots to aide in
> troubleshooting. Let me know if these didn’t make it through and I can send
> some links instead.
> Thanks,
> Avi Misra
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181110/37b74c84/attachment-0002.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181110/37b74c84/attachment-0002.jpg>
