Link RAP file error on zynq BSP
Sun Nov 11 05:51:35 UTC 2018
On 15/10/18 9:39 pm, jameszxj wrote:
>>It should be fixed with this commit:
>> https://git.rtems.org/rtems/commit/?id=186a0b1dc017b1e2e44620f8d6274dc1c6ba09d1
> thanks, compile is ok. but rtems-ld still has a error
> outputter:application: wsp/build/nssys.out
> image::close: removing wsp/build/nssys.out
> error: rap::object: Section index '65522' not found: wsp/build/nssys.elf
> make: *** [Makefile:103: nssys.elf] Error 10
> should  rtems-ld be patch too?
James, you do have a test case I can use to look into this?
Thanks
