RTEMS Plugin Xilinx SDK Not Generating HelloWorld Template
Sat Nov 10 18:33:37 UTC 2018
On Sat, Nov 10, 2018, 1:28 PM Joel Sherrill <joel at rtems.org wrote:
> Someone else developed the plugin and I have no idea what's going on with
> it relative to Eclipse but if the RTEMS applicstion code generated from the
> template isn't compiling, post it and more people can help solve that.
> On Sat, Nov 10, 2018, 1:18 PM Misra, Avinash <Avinash.Misra at jhuapl.edu
> wrote:
>> Hi,
>> I’m trying to get the RTEMS Plugin installed into the Xilinx SDK. The SDK
>> is running Eclipse 4.6
>> I’ve followed the steps from the tutorial (
>> https://devel.rtems.org/wiki/Developer/Eclipse/Plugin)to get the Xilinx
>> Plugin installed from the ftp website (
>> http://ftp//ftp.rtems.org/pub/rtems/eclipse/updates/
>> <http://ftp/ftp.rtems.org/pub/rtems/eclipse/updates/>).
>> I’ve configured Eclipse to point to the RTEMS toolchain (Installed in
>> C:/opt/rtems/5/bin) and the Xilinx Zynq BSP that I generated outside of
>> Eclipse as well as my MinGW and MSYS install paths.
>> The issue I’m having now is that when I go to create a RTEMS HelloWorld
>> project (New Project à C Project à RTEMS Hello-World Project) using the
>> RTEMS Toolchain it just generates a blank project folder when I click
>> finish. If I click Next and go to the select configuration page I get the
>> following error “*At least one configuration should be available.
>> Project cannot be created.”*
>> Any idea what might be going on? I added some screenshots to aide in
>> troubleshooting. Let me know if these didn’t make it through and I can send
>> some links instead.
>> Thanks,
>> Avi Misra
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181110/5a55e8a2/attachment-0002.html>
