[PATCH 1/2] psxtmthreadattr01: Add new POSIX timing test (GCI 2018)
Thu Nov 15 20:14:23 UTC 2018
 testsuites/psxtmtests/Makefile.am                  |  11 +
 testsuites/psxtmtests/configure.ac                 |   1 +
 testsuites/psxtmtests/psxtmtests_plan.csv          |  34 +-
 testsuites/psxtmtests/psxtmthreadattr01/init.c     | 423 +++++++++++++++++++++
 .../psxtmthreadattr01/psxtmthreadattr01.doc        |  33 ++
 5 files changed, 485 insertions(+), 17 deletions(-)
 create mode 100644 testsuites/psxtmtests/psxtmthreadattr01/init.c
 create mode 100644 testsuites/psxtmtests/psxtmthreadattr01/psxtmthreadattr01.doc
diff --git a/testsuites/psxtmtests/Makefile.am b/testsuites/psxtmtests/Makefile.am
index 1607ac6..ae2af47 100644
--- a/testsuites/psxtmtests/Makefile.am
+++ b/testsuites/psxtmtests/Makefile.am
@@ -569,6 +569,17 @@ psxtmthread06_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxtmthread06) \
 	-DOPERATION_COUNT=$(OPERATION_COUNT)
 endif
+if TEST_psxtmthreadattr01
+psxtm_tests += psxtmthreadattr01
+psxtm_docs += psxtmthreadattr01/psxtmthreadattr01.doc
+psxtmthreadattr01_SOURCES = psxtmthreadattr01/init.c \
+	../tmtests/include/timesys.h ../support/src/tmtests_empty_function.c \
+	../support/src/tmtests_support.c
+psxtmthreadattr01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxtmthreadattr01) \
+	$(support_includes) -I$(top_srcdir)/../tmtests/include \
+	-DOPERATION_COUNT=$(OPERATION_COUNT)
+endif
 rtems_tests_PROGRAMS = $(psxtm_tests)
 dist_rtems_tests_DATA = $(psxtm_screens) $(psxtm_docs)
diff --git a/testsuites/psxtmtests/configure.ac b/testsuites/psxtmtests/configure.ac
index 0c3b143..dde3e9b 100644
--- a/testsuites/psxtmtests/configure.ac
+++ b/testsuites/psxtmtests/configure.ac
@@ -80,6 +80,7 @@ RTEMS_TEST_CHECK([psxtmthread03])
 RTEMS_TEST_CHECK([psxtmthread04])
 RTEMS_TEST_CHECK([psxtmthread05])
 RTEMS_TEST_CHECK([psxtmthread06])
+RTEMS_TEST_CHECK([psxtmthreadattr01])
 AC_CONFIG_FILES([Makefile])
 AC_OUTPUT
diff --git a/testsuites/psxtmtests/psxtmtests_plan.csv b/testsuites/psxtmtests/psxtmtests_plan.csv
index 68c27af..5bfb56d 100644
--- a/testsuites/psxtmtests/psxtmtests_plan.csv
+++ b/testsuites/psxtmtests/psxtmtests_plan.csv
@@ -28,23 +28,23 @@
 "pthread_create: no preempt","psxtmthread01","psxtmtest_single","Yes"
 "pthread_create: preempt","psxtmthread02","psxtmtest_single","Yes"
-"pthread_attr_init: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_destroy: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_getdetachstate: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_getguardsize: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_getinheritsched: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_getschedparam: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_getschedpolicy: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_getscope: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_getstack: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_getstacksize: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_setdetachstate: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_setguardsize: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_setinheritsched: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_setschedparam: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_setschedpolicy: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_setscope: only case", "psxtmthread07", "psxtmtest_single","No"
-"pthread_attr_setstack: only case", "psxtmthread07", "psxtmtest_single","No"
+"pthread_attr_init: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_destroy: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_getdetachstate: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_getguardsize: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_getinheritsched: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_getschedparam: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_getschedpolicy: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_getscope: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_getstack: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_getstacksize: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_setdetachstate: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_setguardsize: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_setinheritsched: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_setschedparam: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_setschedpolicy: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_setscope: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
+"pthread_attr_setstack: only case", "psxtmthreadattr01", "psxtmtest_single","Yes"
 "pthread_join"
 "pthread_detach"
diff --git a/testsuites/psxtmtests/psxtmthreadattr01/init.c b/testsuites/psxtmtests/psxtmthreadattr01/init.c
new file mode 100644
index 0000000..811f973
--- /dev/null
+++ b/testsuites/psxtmtests/psxtmthreadattr01/init.c
@@ -0,0 +1,423 @@
+ *  COPYRIGHT (c) 2018.
+ *  Himanshu Sekhar Nayak (GCI 2018)
+ *  Permission to use, copy, modify, and/or distribute this software
+ *  for any purpose with or without fee is hereby granted.
+ *  THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
+ *  WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
+ *  WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
+ *  BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
+ *  OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
+ *  WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
+ *  ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <timesys.h>
+#include <rtems/btimer.h>
+#include "test_support.h"
+#include <tmacros.h>
+#include <pthread.h>
+#include <sched.h>
+#define GUARDSIZE_TEST_VALUE 512
+#define STACKSIZE_TEST_VALUE 1024
+const char rtems_test_name[] = "PSXTMTHREADATTR01";
+/* forward declarations to avoid warnings */
+static void *POSIX_Init(void *argument);
+static pthread_attr_t attr;
+static size_t guardsize = GUARDSIZE_TEST_VALUE;
+static size_t stacksize = STACKSIZE_TEST_VALUE;
+static struct sched_param param;
+static int var = 2;
+static void *stackaddr;
+static void benchmark_create_pthread_attr(void)
+  benchmark_timer_t end_time;
+  int  status;
+  benchmark_timer_initialize();
+  status = pthread_attr_init(&attr);
+  end_time = benchmark_timer_read();
+  rtems_test_assert( status == 0 );
+  put_time(
+    "pthread_attr_init: only case",
+    end_time,
+    1,        /* Only executed once */
+    0,
+    0
+static void benchmark_pthread_attr_setdetachstate(void)
+  int  status;
+  status = pthread_attr_setdetachstate(&attr, PTHREAD_CREATE_DETACHED);
+  put_time(
+    "pthread_attr_setdetachstate: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_getdetachstate(void)
+  int  status;
+  int tmp_var;
+  status = pthread_attr_getdetachstate(&attr, &tmp_var);
+  rtems_test_assert( tmp_var == PTHREAD_CREATE_DETACHED );
+  put_time(
+    "pthread_attr_getdetachstate: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_setguardsize(void)
+  int  status;
+  status = pthread_attr_setguardsize(&attr, guardsize);
+  put_time(
+    "pthread_attr_setguardsize: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_getguardsize(void)
+  int  status;
+  size_t tmp_guardsize;
+  status = pthread_attr_getguardsize(&attr, &tmp_guardsize);
+  rtems_test_assert( tmp_guardsize == guardsize );
+  put_time(
+    "pthread_attr_getguardsize: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_setinheritsched(void)
+  int  status;
+  status = pthread_attr_setinheritsched(&attr, PTHREAD_EXPLICIT_SCHED);
+  put_time(
+    "pthread_attr_setinheritsched: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_getinheritsched(void)
+  int  status;
+  int tmp_var;
+  status = pthread_attr_getinheritsched(&attr, &tmp_var);
+  rtems_test_assert( tmp_var == PTHREAD_EXPLICIT_SCHED );
+  put_time(
+    "pthread_attr_getinheritsched: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_setschedparam(void)
+  int  status;
+  status = pthread_attr_setschedparam(&attr, &param);
+  param.sched_priority = sched_get_priority_min( SCHED_RR ) + 2;
+  put_time(
+    "pthread_attr_setschedparam: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_getschedparam(void)
+  int  status;
+  struct sched_param tmp_param;
+  status = pthread_attr_getschedparam(&attr, &tmp_param);
+  tmp_param.sched_priority = sched_get_priority_min( SCHED_RR ) + 2;
+  rtems_test_assert( tmp_param.sched_priority == param.sched_priority );
+  put_time(
+    "pthread_attr_getschedparam: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_setschedpolicy(void)
+  int  status;
+  status = pthread_attr_setschedpolicy(&attr, var);
+  put_time(
+    "pthread_attr_setschedpolicy: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_getschedpolicy(void)
+  int  status;
+  int tmp_var;
+  status = pthread_attr_getschedpolicy(&attr, &tmp_var);
+  rtems_test_assert( tmp_var == var );
+  put_time(
+    "pthread_attr_getschedpolicy: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_setscope(void)
+  int  status;
+  status = pthread_attr_setscope(&attr, PTHREAD_SCOPE_PROCESS);
+  put_time(
+    "pthread_attr_setscope: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_getscope(void)
+  int  status;
+  int scope;
+  status = pthread_attr_getscope(&attr, &scope);
+  rtems_test_assert( scope == PTHREAD_SCOPE_PROCESS );
+  put_time(
+    "pthread_attr_getscope: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_setstack(void)
+  int  status;
+  status = pthread_attr_setstack(&attr, stackaddr, stacksize);
+  put_time(
+    "pthread_attr_setstack: only case",
+    end_time,
+    0,
+    0
+static void benchmark_pthread_attr_getstack(void)
+  int  status;
+  size_t tmp_stacksize;
+  status = pthread_attr_getstack(&attr, &stackaddr, &tmp_stacksize);
+  rtems_test_assert(tmp_stacksize == stacksize);
+  put_time(
+    "pthread_attr_getstack: only case",
+    end_time,
+    0,
+    0
+static void benchmark_destroy_pthread_attr(void)
+  int  status;
+  status = pthread_attr_destroy(&attr);
+  put_time(
+    "pthread_attr_destroy: only case",
+    end_time,
+    0,
+    0
+  void *argument
+  TEST_BEGIN();
+  benchmark_create_pthread_attr();
+  benchmark_pthread_attr_setdetachstate();
+  benchmark_pthread_attr_getdetachstate();
+  benchmark_pthread_attr_setguardsize();
+  benchmark_pthread_attr_getguardsize();
+  benchmark_pthread_attr_setinheritsched();
+  benchmark_pthread_attr_getinheritsched();
+  benchmark_pthread_attr_setschedparam();
+  benchmark_pthread_attr_getschedparam();
+  benchmark_pthread_attr_setschedpolicy();
+  benchmark_pthread_attr_getschedpolicy();
+  benchmark_pthread_attr_setscope();
+  benchmark_pthread_attr_getscope();
+  benchmark_pthread_attr_setstack();
+  benchmark_pthread_attr_getstack();
+  benchmark_destroy_pthread_attr();
+  TEST_END();
+  rtems_test_exit(0);
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
+/* configure an instance of the object created/destroyed */
+#define CONFIGURE_MAXIMUM_POSIX_THREADS     1
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
+/* end of file */
diff --git a/testsuites/psxtmtests/psxtmthreadattr01/psxtmthreadattr01.doc b/testsuites/psxtmtests/psxtmthreadattr01/psxtmthreadattr01.doc
index 0000000..8d8d5b8
--- /dev/null
+++ b/testsuites/psxtmtests/psxtmthreadattr01/psxtmthreadattr01.doc
@@ -0,0 +1,33 @@
+#  COPYRIGHT (c) 2018.
+#  Himanshu Sekhar Nayak(GCI 2018)
+#  Permission to use, copy, modify, and/or distribute this software
+#  for any purpose with or without fee is hereby granted.
+#  THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
+#  WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
+#  WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
+#  BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
+#  OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
+#  WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
+#  ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+This test benchmarks the following operations:
++ pthread_attr_init - only case
++ pthread_attr_setdetachstate - only case
++ pthread_attr_getdetachstate - only case
++ pthread_attr_setguardsize - only case
++ pthread_attr_getguardsize - only case
++ pthread_attr_setinheritsched - only case
++ pthread_attr_getinheritsched - only case
++ pthread_attr_setschedparam - only case
++ pthread_attr_getschedparam - only case
++ pthread_attr_setschedpolicy - only case
++ pthread_attr_getschedpolicy - only case
++ pthread_attr_setscope - only case
++ pthread_attr_getscope - only case
++ pthread_attr_setstack - only case
++ pthread_attr_getstack - only case
++ pthread_attr_destroy - only case
1.8.3.1
