[POSIX Benchmark Test] psxtmmqrcvblock01 made (GCI 2018)
Shashvat Jain shashvatjain2002 at gmail.com
Fri Nov 16 18:08:39 UTC 2018
Glad to help!
On Fri, Nov 16, 2018 at 10:48 PM Joel Sherrill <joel at rtems.org> wrote:
> Thanks for double checking the commit and reporting this. I pushed a fix
> and gave you credit. :)
> --joel
> On Fri, Nov 16, 2018 at 10:56 AM Shashvat Jain <shashvatjain2002 at gmail.com>
> wrote:
>> Can someone change the status of the test to YES in the plan.csv file ,as
>> it has been commited
>> On Fri, Nov 16, 2018 at 8:22 PM Shashvat Jain <shashvatjain2002 at gmail.com>
>> wrote:
>>> ok , that makes sense
>>> On Fri, Nov 16, 2018 at 8:20 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> I agree we want to reduce the overall number of executables but the
>>>> timing tests which block
>>>> need a large set of tasks which do precisely the right thing. You have
>>>> to be very careful not to
>>>> accidentally measure the overhead of _Thread_Handler or any odd
>>>> initialization.
>>>> I am happy to see the cases which don't block or unblock merged into
>>>> single cases. The
>>>> newly added pthread attr tmtest has a lot of cases. But blocking,
>>>> unblocking, and preemption
>>>> cases need to be separate. They are very precise tests and hard to make
>>>> sure they measure
>>>> exactly what you think they measure without extras.
>>>> --joel
>>>> On Fri, Nov 16, 2018 at 7:30 AM Shashvat Jain <
>>>> shashvatjain2002 at gmail.com> wrote:
>>>>> I asked that before starting to make the test and Dr. Joel asked me to
>>>>> make a separate one
>>>>> On Fri, Nov 16, 2018 at 12:35 PM Sebastian Huber <
>>>>> sebastian.huber at embedded-brains.de> wrote:
>>>>>> Do we really need separate test programs for all these test cases?
>>>>>> Can't
>>>>>> we just add this to psxtmmq01?
>>>>>> The reason for this is that it needs time to load a test program to
>>>>>> the
>>>>>> target.
>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>> Phone   : +49 89 189 47 41-16
>>>>>> Fax     : +49 89 189 47 41-09
>>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>>> PGP     : Public key available on request.
>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181116/fededd8b/attachment-0002.html>
