Spike Fails to Build on CentOS 7 (Possible RSB Issue)
Sat Nov 17 00:57:42 UTC 2018
On 17/11/18 1:45 am, Joel Sherrill wrote:
> Hi
> Hesham was nice enough to bump the Spike version in the RSB so others have a
> chance of using it to test RISC-V executables. Unfortunately, it now doesn't
> build for me. I am not sure if this is a
> ../source-builder/sb-set-builder --log=l-spike.txt
> --prefix=/home/joel/rtems-work/tools/5 devel/spike
> RTEMS Source Builder - Set Builder, 5 (69e07b57d5ab)
> Build Set: devel/spike
> config: devel/spike-1.1.0.cfg
> package: spike-1.1.0-x86_64-linux-gnu-1
> building: spike-1.1.0-x86_64-linux-gnu-1
> sizes: spike-1.1.0-x86_64-linux-gnu-1: 85.470MB (installed: 12.497MB)
> cleaning: spike-1.1.0-x86_64-linux-gnu-1
> reporting: devel/spike-1.1.0.cfg -> spike-1.1.0-x86_64-linux-gnu-1.txt
> reporting: devel/spike-1.1.0.cfg -> spike-1.1.0-x86_64-linux-gnu-1.xml
> installing: spike-1.1.0-x86_64-linux-gnu-1 -> /home/joel/rtems-work/tools/5
> error: copying tree (3):
> /data/home/joel/rtems-work/rtems-source-builder/bare/build/tmp/spike-1.1.0-x86_64-linux-gnu-1-joel/home/joel/rtems-work/tools/5/lib/pkgconfig/riscv-dummy_rocc.pc
> -> /home/joel/rtems-work/tools/5/lib/pkgconfig/riscv-dummy_rocc.pc: [Errno 13]
> Permission denied:
> u'/home/joel/rtems-work/tools/5/lib/pkgconfig/riscv-dummy_rocc.pc'
What are the perms of the dest file?
