Spike Fails to Build on CentOS 7 (Possible RSB Issue)
Joel Sherrill
joel at rtems.org
Tue Nov 20 16:43:03 UTC 2018
On Fri, Nov 16, 2018 at 6:57 PM Chris Johns <chrisj at rtems.org> wrote:
> On 17/11/18 1:45 am, Joel Sherrill wrote:
> > Hi
> > Hesham was nice enough to bump the Spike version in the RSB so others
> have a
> > chance of using it to test RISC-V executables. Unfortunately, it now
> doesn't
> > build for me. I am not sure if this is a
> > ../source-builder/sb-set-builder --log=l-spike.txt
> > --prefix=/home/joel/rtems-work/tools/5 devel/spike
> > RTEMS Source Builder - Set Builder, 5 (69e07b57d5ab)
> > Build Set: devel/spike
> > config: devel/spike-1.1.0.cfg
> > package: spike-1.1.0-x86_64-linux-gnu-1
> > building: spike-1.1.0-x86_64-linux-gnu-1
> > sizes: spike-1.1.0-x86_64-linux-gnu-1: 85.470MB (installed: 12.497MB)
> > cleaning: spike-1.1.0-x86_64-linux-gnu-1
> > reporting: devel/spike-1.1.0.cfg -> spike-1.1.0-x86_64-linux-gnu-1.txt
> > reporting: devel/spike-1.1.0.cfg -> spike-1.1.0-x86_64-linux-gnu-1.xml
> > installing: spike-1.1.0-x86_64-linux-gnu-1 ->
> > error: copying tree (3):
> /data/home/joel/rtems-work/rtems-source-builder/bare/build/tmp/spike-1.1.0-x86_64-linux-gnu-1-joel/home/joel/rtems-work/tools/5/lib/pkgconfig/riscv-dummy_rocc.pc
> > -> /home/joel/rtems-work/tools/5/lib/pkgconfig/riscv-dummy_rocc.pc:
> [Errno 13]
> > Permission denied:
> > u'/home/joel/rtems-work/tools/5/lib/pkgconfig/riscv-dummy_rocc.pc'
> What are the perms of the dest file?
$ ls -ial /home/joel/rtems-work/tools/5/lib/pkgconfig
total 28
11005191 drwxr-xr-x. 2 joel joel 146 Nov 19 17:52 .
822003261 drwxr-xr-x. 4 joel joel 4096 Nov 19 17:52 ..
11005192 -rw-r--r--. 1 joel joel 306 Nov 9 21:18 expat.pc
11046201 -r--r--r--. 1 joel joel 358 Nov 9 16:54 riscv-dummy_rocc.pc
11004685 -r--r--r--. 1 joel joel 341 Nov 19 17:52 riscv-fesvr.pc
11046200 -r--r--r--. 1 joel joel 324 Nov 9 16:54 riscv-riscv.pc
11043504 -r--r--r--. 1 joel joel 349 Nov 9 16:54 riscv-softfloat.pc
11043505 -r--r--r--. 1 joel joel 392 Nov 9 16:54 riscv-spike_main.pc
Could this be something else? Another weird Python 2/3 thing?
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181120/1052a004/attachment.html>
