Advice Needed on Where to Put Some Items in Documentation
Tue Nov 20 22:43:21 UTC 2018
On 21/11/2018 01:50, Joel Sherrill wrote:
> Hi
> I have been reviewing the wiki
> page https://devel.rtems.org/wiki/TBR/Review/Debugging/Start
> and removed most of the content as horribly out of date or covered elsewhere
> better. But the content either needs a second opinion on its value or where it
> place it in the documentation.
> (1) First section is a brief into to hardware assisted debug with some Coldfire
> advice. The information would need to be updated with current links but Axman
> still is around and has
> a BDM module. Does this have a home in the documentation?
> (2) The rest of the page is common symptoms of application configuration errors.
> It seems
> like it would be nice to incorporate this information somewhere in the
> Configuring a System
> chapter. Would adding a new subsection on "Common Misconfiguration Scenarios"
> make sense?
Have you seen https://devel.rtems.org/wiki/Debugging?
