qemu command line for arm zynq
Chris Johns
chrisj at rtems.org
Wed Nov 21 02:10:07 UTC 2018
Hi,
I have tracked down the issue I am having with an RSB qemu on FreeBSD with the
xilinx_zynq_a9_qemu BSP. It is ...
https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/qemu.cfg#n51
FreeBSD needs the commented line and I assume Linux works with the uncommented line.
Could someone on Linux please let me know if the commented line works?
I would prefer a common command line if possible before I explore variants of
the command line to use.
Thanks
