qemu command line for arm zynq
Wed Nov 21 02:24:00 UTC 2018
On Tue, Nov 20, 2018, 8:10 PM Chris Johns <chrisj at rtems.org wrote:
> Hi,
> I have tracked down the issue I am having with an RSB qemu on FreeBSD with
> the
> xilinx_zynq_a9_qemu BSP. It is ...
> https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/qemu.cfg#n51
> FreeBSD needs the commented line and I assume Linux works with the
> uncommented line.
> Could someone on Linux please let me know if the commented line works?
> I would prefer a common command line if possible before I explore variants
> of
> the command line to use.
It depends on the version of qemu. I don't recall when it changed but it
seems that distros include a qemu that takes one and our git rsb takes
another.
At least that's what I recall. I have the same kind of commented lines in
the sim-scripts
> Thanks
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181120/ccc5098f/attachment-0002.html>
