[PATCH] pipe/fifo.c: Remove dead code (CID 1437649)
Joel Sherrill
joel at rtems.org
Thu Nov 22 00:48:13 UTC 2018
Closes #3581.
cpukit/libfs/src/pipe/fifo.c | 1 -
1 file changed, 1 deletion(-)
diff --git a/cpukit/libfs/src/pipe/fifo.c b/cpukit/libfs/src/pipe/fifo.c
index d664adf..71d5f85 100644
--- a/cpukit/libfs/src/pipe/fifo.c
+++ b/cpukit/libfs/src/pipe/fifo.c
@@ -100,7 +100,6 @@ static int pipe_alloc(
c = 'a';
return 0;
- rtems_barrier_delete(pipe->writeBarrier);
err_wbar:
rtems_barrier_delete(pipe->readBarrier);
err_rbar:
1.8.3.1
