rtems-test error with coverage
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Nov 23 09:55:20 UTC 2018
On Fri, 23 Nov 2018 at 15:09, Chris Johns <chrisj at rtems.org> wrote:
> On 23/11/18 7:32 pm, Vijay Kumar Banerjee wrote:
> > Hi,
> > I was trying to run coverage with rtems-test on a fresh install, and
> faced
> > the following errors. This is strange as everything was working and I
> can't
> > figure out what went wrong.
> > Also, I don't see covoar executable in the covoar/ directory.
> > I'm using Python 2.7.15
> Are you sure? The latest version selects the python used.
> `python --version` returns 2.7.15
> If you do ...
> $ export RTEMS_PYTHON_OVERRIDE=python2
... does it work?
> Yes, this worked. Now I see
error: coverage: covoar not found
> > Traceback (most recent call last):
> > File
> "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py", line
> > 263, in parse
> > ss = ss.replace('@BSP@', self.bsp_name)
> > TypeError: a bytes-like object is required, not 'str'
> > During handling of the above exception, another exception occurred:
> This smells of a python3 type issue.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181123/433684d4/attachment.html>
