rtems-test error with coverage
Chris Johns
chrisj at rtems.org
Fri Nov 23 10:51:18 UTC 2018
> On 23 Nov 2018, at 8:55 pm, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com> wrote:
>> On Fri, 23 Nov 2018 at 15:09, Chris Johns <chrisj at rtems.org> wrote:
>> On 23/11/18 7:32 pm, Vijay Kumar Banerjee wrote:
>> > Hi,
>> > I was trying to run coverage with rtems-test on a fresh install, and faced
>> > the following errors. This is strange as everything was working and I can't
>> > figure out what went wrong.
>> > Also, I don't see covoar executable in the covoar/ directory.
>> > I'm using Python 2.7.15
>> Are you sure? The latest version selects the python used.
> `python --version` returns 2.7.15
The python command may not be used. It could python3.
>> If you do ...
>> $ export RTEMS_PYTHON_OVERRIDE=python2
>> ... does it work?
> Yes, this worked. Now I see
> error: coverage: covoar not found
I am not sure about this error but it does mean there maybe some issues with python3.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181123/89904433/attachment.html>
