psxtmtests: add psxtmmqrcvblock02 -v2 (GCI 2018)
Joel Sherrill
joel at rtems.org
Sun Nov 25 15:55:11 UTC 2018
Odd comments:
+ Use the -vN option to git format-patch and don't manually put the
version number in the commit message
+ Put a space before the first parenthesis on the log message.
I have fixed this a couple of times for you and figure you will do more
tasks so
might as well have it right when submitted. This is the pickier kind of
comments
you get when we expect you to stick around. :)
I ran this on powerpc/psim which gives the number of instructions. The times
for all the mq_ operations are below. Note that the mq_receive and
mq_timedreceive
are quite close as would be expected:
log/psxtmmq01:mq_open: first open - 858
log/psxtmmq01:mq_send: no threads waiting - 208
log/psxtmmq01:mq_open: second open - 370
log/psxtmmq01:mq_receive: available - 166
log/psxtmmq01:mq_unlink: only case - 456
log/psxtmmq01:mq_timedsend: no threads waiting - 208
log/psxtmmq01:mq_timedreceive: available - 166
log/psxtmmq01:mq_notify: only case - 63
log/psxtmmq01:mq_close: close of second - 233
log/psxtmmq01:mq_close: close of first - 233
log/psxtmmqrcvblock01:mq_receive: not available: block - 1153
log/psxtmmqrcvblock02:mq_timedreceive: not available: block - 1198
Committed. Thanks!
--joel
--joel
On Sun, Nov 25, 2018 at 3:45 AM Himanshu Sekhar Nayak <
himanshuwindows8.1 at gmail.com> wrote:
> Hi guys,
> Here is the patch file with output
> https://paste.ofcode.org/khkkS9SLwsTtDUCPHAipCa .
> Thanks
> himanshu
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181125/d00a286e/attachment.html>
