m68k/av5282:Add per-section compilation and linking support
Shashvat Jain
shashvatjain2002 at gmail.com
Tue Nov 27 02:36:39 UTC 2018
Hello,
I just enabled the per-function and per-data element section support for
the av5282 bsp in m68k architecture .
The patch for the change has been attached
Thank you
Regards
--Shashvat
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181127/ff1851f7/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181127/ff1851f7/attachment-0001.obj>
