m68k/av5282:Add per-section compilation and linking support
Tue Nov 27 15:28:15 UTC 2018
Thanks.Good work!
The associated GCI task appears to have already been approved.
On Mon, Nov 26, 2018 at 8:36 PM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> Hello,
> I just enabled the per-function and per-data element section support for
> the av5282 bsp in m68k architecture .
> The patch for the change has been attached
> Thank you
> Regards
> --Shashvat
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181127/fa48a97e/attachment-0002.html>
