m68k/mcf5235:Add per-section compilation and linking support (GCI 2018)
    Shashvat Jain
    shashvatjain2002 at gmail.com
    Wed Nov 28 13:29:10 UTC 2018
Hello ,
The per-function section linking has been enabled under this patch
, I faced permission denied for loopback test which i had fixed by giving
"x" attribute to loopback-init.o file .
if it happens with you , please enable the permission for this test.
and generate a patch which improves this .
Thank you
Regards
--Shashvat
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181128/46a23286/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181128/46a23286/attachment.obj>
