m68k/mcf5235:Add per-section compilation and linking support (GCI 2018)
Wed Nov 28 18:19:59 UTC 2018
On Wed, Nov 28, 2018 at 7:29 AM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> Hello ,
> The per-function section linking has been enabled under this patch
> , I faced permission denied for loopback test which i had fixed by giving
> "x" attribute to loopback-init.o file .
> if it happens with you , please enable the permission for this test.
> and generate a patch which improves this .
Committed. I don't know why you are seeing the x attribute on the init.o.
Is this still on MSYS2 or Linux?
--joel
> Thank you
> Regards
> --Shashvat
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181128/60f571db/attachment-0002.html>
