psxtests: add POSIX API signature compliance tests for mqueue.h file (GCI 2018)
Joel Sherrill
joel at rtems.org
Wed Nov 28 17:28:18 UTC 2018
Thanks for approving it Vijay!
For the purposes of reviewing psxhdrs tasks, here are the guidelines. This
should help everyone.
+ good commit message including indication work is from GCI 2018
+ Build without warnings. Be warned, some POSIX methods require defining a
symbol
to make the method visible. This is noted in the POSIX standard and
Linux man pages.
+ All methods from the .h file are tested. See
http://pubs.opengroup.org/onlinepubs/9699919799/
and click on "headers" on the lower left hand side. All the POSIX header
requirements are a click
away from there.
If the new test uncovers an issue with a header or RTEMS method prototype,
discuss it
with your mentor and on deve at . This will likely require filing a ticket and
developer
follow up. It may be an option to commit the tests but comment out the
offending test
(if it does not compile) in the Makefile.am until it is resolved.
Issues uncovered will just have to be dealt with on a case by case basis.
Thanks.
--joel
On Wed, Nov 28, 2018 at 8:11 AM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On Wed, 28 Nov 2018 at 13:38, Himanshu Sekhar Nayak <
> himanshuwindows8.1 at gmail.com> wrote:
>> Hi guys,
>> Here is the patch file for mqueue.h file.
>> I have approved this task in GCI site.
>> Thanks
>> Himanshu
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181128/0c246e67/attachment.html>
