RSB set-builder Creates File Named "0"
Joel Sherrill
joel at rtems.org
Thu Nov 29 19:08:08 UTC 2018
On Thu, Nov 29, 2018 at 1:03 PM Chris Johns <chrisj at rtems.org> wrote:
> On 30 Nov 2018, at 4:27 am, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I have been seeing this for a couple of weeks. I decided to watch a build
> of the sparc
> tools and see when it happened. I set a script to test for the existence
> of 0 and kill the set-builder. In the rtems/ subdirectory of the RSB, the
> script killed the set-builder when the gdb build started. So I think
> something in the gdb bset file is creating this file.
> It will be something related to the gdb python support I added:
> https://git.rtems.org/rtems-source-builder/tree/source-builder/config/gdb-common-1.cfg#n70
> Does it happen with the —dry-run option?
Yes.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181129/3267ff24/attachment-0001.html>
