RSB set-builder Creates File Named "0"
Thu Nov 29 19:19:25 UTC 2018
On 30/11/18 6:08 am, Joel Sherrill wrote:
> On Thu, Nov 29, 2018 at 1:03 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 30 Nov 2018, at 4:27 am, Joel Sherrill <joel at rtems.org
>     <mailto:joel at rtems.org>> wrote:
>>     Hi
>>     I have been seeing this for a couple of weeks. I decided to watch a build
>>     of the sparc
>>     tools and see when it happened. I set a script to test for the existence
>>     of 0 and kill the set-builder. In the rtems/ subdirectory of the RSB, the
>>     script killed the set-builder when the gdb build started. So I think
>>     something in the gdb bset file is creating this file.
>     It will be something related to the gdb python support I added:
>     https://git.rtems.org/rtems-source-builder/tree/source-builder/config/gdb-common-1.cfg#n70
>     Does it happen with the —dry-run option?
> Yes.
Great that makes finding it easier.
If you now add --trace does anything appear in the log that might be the cause?
