RSB set-builder Creates File Named "0"
Joel Sherrill
joel at rtems.org
Thu Nov 29 19:35:34 UTC 2018
On Thu, Nov 29, 2018 at 1:19 PM Chris Johns <chrisj at rtems.org> wrote:
> On 30/11/18 6:08 am, Joel Sherrill wrote:
> > On Thu, Nov 29, 2018 at 1:03 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 30 Nov 2018, at 4:27 am, Joel Sherrill <joel at rtems.org
> > <mailto:joel at rtems.org>> wrote:
> >> Hi
> >> I have been seeing this for a couple of weeks. I decided to watch a
> build
> >> of the sparc
> >> tools and see when it happened. I set a script to test for the
> existence
> >> of 0 and kill the set-builder. In the rtems/ subdirectory of the
> RSB, the
> >> script killed the set-builder when the gdb build started. So I think
> >> something in the gdb bset file is creating this file.
> > It will be something related to the gdb python support I added:
> https://git.rtems.org/rtems-source-builder/tree/source-builder/config/gdb-common-1.cfg#n70
> > Does it happen with the —dry-run option?
> > Yes.
> Great that makes finding it easier.
> If you now add --trace does anything appear in the log that might be the
> cause?
Lots of 0's and I didn't see anything.
I put the l-sparc.txt.bz2 in /tmp on rtems.org.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181129/a02b9ea5/attachment.html>
