RTEMS Plugin Xilinx SDK Not Generating HelloWorld Template
Misra, Avinash
Avinash.Misra at jhuapl.edu
Sat Nov 10 18:31:28 UTC 2018
Hi Joel,
Thanks for the speedy reply. It’s not that the Application Code isn’t compiling, it’s that there’s nothing being generated when I try to create a Hello World project. It just generates a blank directory.
Thanks,
Avi
Sent: Saturday, November 10, 2018 1:29 PM
To: Misra, Avinash <Avinash.Misra at jhuapl.edu>
Cc: rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: RTEMS Plugin Xilinx SDK Not Generating HelloWorld Template
Someone else developed the plugin and I have no idea what's going on with it relative to Eclipse but if the RTEMS applicstion code generated from the template isn't compiling, post it and more people can help solve that.
On Sat, Nov 10, 2018, 1:18 PM Misra, Avinash <Avinash.Misra at jhuapl.edu<mailto:Avinash.Misra at jhuapl.edu> wrote:
Hi,
I’m trying to get the RTEMS Plugin installed into the Xilinx SDK. The SDK is running Eclipse 4.6
[cid:image001.png at 01D478F5.6E6B3F70]
I’ve followed the steps from the tutorial (https://devel.rtems.org/wiki/Developer/Eclipse/Plugin)to get the Xilinx Plugin installed from the ftp website (http://ftp//ftp.rtems.org/pub/rtems/eclipse/updates/<http://ftp/ftp.rtems.org/pub/rtems/eclipse/updates/>).
I’ve configured Eclipse to point to the RTEMS toolchain (Installed in C:/opt/rtems/5/bin) and the Xilinx Zynq BSP that I generated outside of Eclipse as well as my MinGW and MSYS install paths.
[cid:image004.jpg at 01D478F7.D2F98490]
The issue I’m having now is that when I go to create a RTEMS HelloWorld project (New Project --> C Project --> RTEMS Hello-World Project) using the RTEMS Toolchain it just generates a blank project folder when I click finish. If I click Next and go to the select configuration page I get the following error “At least one configuration should be available. Project cannot be created.”
[cid:image005.jpg at 01D478F7.D2F98490]
Any idea what might be going on? I added some screenshots to aide in troubleshooting. Let me know if these didn’t make it through and I can send some links instead.
Thanks,
Avi Misra
devel mailing list
devel at rtems.org<mailto:devel at rtems.org>
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181110/72e07d8b/attachment-0002.html>
