or1k tool chain update to use GCC 9
Fri Nov 16 14:51:13 UTC 2018
Adding Stafford Horne since he is also likely to know what's up.
On Fri, Nov 16, 2018 at 4:45 AM Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> Hi,
> I built or1k toolchain and RTEMS today. Hello World works fine on
> qemu-system-or1k, but not on or1ksim (which hasn't been updated since
> 2016).
> Ticker on QEMU doesn't seem to get the timer interrupts i.e. it just
> prints out the first 3 tasks and hangs.
> Please note I haven't built or1k for a while, so I'm not sure that's
> because of the updated toolchain, or it the issue has been already
> there before.
> Cheers,
> Hesham
> On Wed, 14 Nov 2018 at 06:10, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Hello,
> > the RSB uses now GCC 9 to for the or1k tool chain:
> https://git.rtems.org/rtems-source-builder/commit/?id=8241563b6ec559fd562ec41147b04797a54dfe5f
> > I was able to build this RTEMS BSP with it and link the tests:
> https://git.rtems.org/rtems/commit/?id=28bf4cae7878f4e47cc24c114fc9c5567247ecc1
> > Please test the tool chain and fix new warnings in the RTEMS build. It
> > would be nice to have thread-local storage support for this port. The
> > console driver should be converted to use the new Termios device driver
> API.
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone   : +49 89 189 47 41-16
> > Fax     : +49 89 189 47 41-09
> > E-Mail  : sebastian.huber at embedded-brains.de
> > PGP     : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > devel mailing list
> > devel at rtems.org
> Hesham
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181116/32f7beec/attachment-0002.html>
