[POSIX Benchmark Test] psxtmmqrcvblock01 made (GCI 2018)
Fri Nov 16 17:18:37 UTC 2018
Thanks for double checking the commit and reporting this. I pushed a fix
and gave you credit. :)
--joel
On Fri, Nov 16, 2018 at 10:56 AM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> Can someone change the status of the test to YES in the plan.csv file ,as
> it has been commited
> On Fri, Nov 16, 2018 at 8:22 PM Shashvat Jain <shashvatjain2002 at gmail.com>
> wrote:
>> ok , that makes sense
>> On Fri, Nov 16, 2018 at 8:20 PM Joel Sherrill <joel at rtems.org> wrote:
>>> I agree we want to reduce the overall number of executables but the
>>> timing tests which block
>>> need a large set of tasks which do precisely the right thing. You have
>>> to be very careful not to
>>> accidentally measure the overhead of _Thread_Handler or any odd
>>> initialization.
>>> I am happy to see the cases which don't block or unblock merged into
>>> single cases. The
>>> newly added pthread attr tmtest has a lot of cases. But blocking,
>>> unblocking, and preemption
>>> cases need to be separate. They are very precise tests and hard to make
>>> sure they measure
>>> exactly what you think they measure without extras.
>>> --joel
>>> On Fri, Nov 16, 2018 at 7:30 AM Shashvat Jain <
>>> shashvatjain2002 at gmail.com> wrote:
>>>> I asked that before starting to make the test and Dr. Joel asked me to
>>>> make a separate one
>>>> On Fri, Nov 16, 2018 at 12:35 PM Sebastian Huber <
>>>> sebastian.huber at embedded-brains.de> wrote:
>>>>> Do we really need separate test programs for all these test cases?
>>>>> Can't
>>>>> we just add this to psxtmmq01?
>>>>> The reason for this is that it needs time to load a test program to
>>>>> the
>>>>> target.
>>>>> Sebastian Huber, embedded brains GmbH
>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>> Phone   : +49 89 189 47 41-16
>>>>> Fax     : +49 89 189 47 41-09
>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>> PGP     : Public key available on request.
>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181116/df17c787/attachment-0002.html>
