[PATCH] Use rtems_task_exit()
Tue Oct 2 08:22:58 UTC 2018
Update #3530.
Update #3533.
 bsps/powerpc/mpc55xxevb/net/smsc9218i.c          |  2 +-
 bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c |  2 +-
 bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c        |  2 +-
 bsps/powerpc/shared/net/tsec.c                   |  4 ++--
 bsps/shared/dev/ide/ata.c                        |  2 +-
 bsps/sparc/shared/spw/grspw_pkt.c                |  2 +-
 cpukit/ftpd/ftpd.c                               |  2 +-
 cpukit/include/rtems/rtems/event.h               |  3 +--
 cpukit/include/rtems/status-checks.h             |  4 ++--
 cpukit/libblock/src/bdbuf.c                      |  6 +++---
 cpukit/libcsupport/src/termios.c                 |  4 ++--
 cpukit/libdebugger/rtems-debugger-server.c       |  4 ++--
 cpukit/libfs/src/nfsclient/src/nfs.c             |  2 +-
 cpukit/libmisc/cpuuse/cpuusagetop.c              |  2 +-
 cpukit/libmisc/monitor/mon-server.c              |  2 +-
 cpukit/libmisc/redirector/stdio-redirect.c       |  2 +-
 cpukit/libmisc/shell/shell.c                     |  2 +-
 cpukit/libnetworking/rtems/rtems_dhcp.c          |  2 +-
 cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c |  2 +-
 cpukit/librpc/src/rpc/rtems_portmapper.c         | 14 +++++++-------
 cpukit/pppd/rtemspppd.c                          |  2 +-
 cpukit/score/cpu/i386/sse_test.c                 |  2 +-
 cpukit/telnetd/telnetd.c                         |  8 ++++----
 23 files changed, 38 insertions(+), 39 deletions(-)
diff --git a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
index 30156a0d4f..1914c24022 100644
--- a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
+++ b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
@@ -1500,7 +1500,7 @@ static void smsc9218i_transmit_task(void *arg)
   rtems_bsdnet_semaphore_release();
   /* Terminate self */
-  (void) rtems_task_delete(RTEMS_SELF);
+  rtems_task_exit();
 #if defined(DEBUG)
diff --git a/bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c b/bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c
index ea29d766b3..91f90cc4f3 100644
--- a/bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c
+++ b/bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c
@@ -1569,6 +1569,6 @@ static void GT64260eth_daemon(void *arg)
    * theoretically, that variable could already
    * hold a newly created TID
-  rtems_task_delete(RTEMS_SELF);
diff --git a/bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c b/bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c
index 11705ac04b..74873475b8 100644
--- a/bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c
+++ b/bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c
@@ -1694,7 +1694,7 @@ static void i82544EI_daemon(void *arg)
diff --git a/bsps/powerpc/shared/net/tsec.c b/bsps/powerpc/shared/net/tsec.c
index 3dc77b0c8e..c51d47c619 100644
--- a/bsps/powerpc/shared/net/tsec.c
+++ b/bsps/powerpc/shared/net/tsec.c
@@ -776,7 +776,7 @@ static void tsec_rxDaemon
    * terminate daemon
   sc->rxDaemonTid = 0;
@@ -1126,7 +1126,7 @@ static void tsec_txDaemon
    * terminate daemon
   sc->txDaemonTid = 0;
diff --git a/bsps/shared/dev/ide/ata.c b/bsps/shared/dev/ide/ata.c
index fe2865fc90..8dc8d78478 100644
--- a/bsps/shared/dev/ide/ata.c
+++ b/bsps/shared/dev/ide/ata.c
@@ -908,7 +908,7 @@ ata_queue_task(rtems_task_argument arg)
             default:
 #if ATA_DEBUG
                 ata_printf("ata_queue_task: internal error\n");
-                rtems_task_delete (RTEMS_SELF);
 #endif
                 rtems_fatal_error_occurred(RTEMS_INTERNAL_ERROR);
                 break;
diff --git a/bsps/sparc/shared/spw/grspw_pkt.c b/bsps/sparc/shared/spw/grspw_pkt.c
index f28e4be634..c109a25a6b 100644
--- a/bsps/sparc/shared/spw/grspw_pkt.c
+++ b/bsps/sparc/shared/spw/grspw_pkt.c
@@ -2745,7 +2745,7 @@ void grspw_work_func(rtems_id msgQ)
 		rtems_message_queue_delete(msgQ);
 	grspw_work_event(WORKTASK_EV_QUIT, message);
 STATIC void grspw_isr(void *data)
diff --git a/cpukit/ftpd/ftpd.c b/cpukit/ftpd/ftpd.c
index 3526024063..0d713c03e8 100644
--- a/cpukit/ftpd/ftpd.c
+++ b/cpukit/ftpd/ftpd.c
@@ -2056,7 +2056,7 @@ ftpd_daemon(rtems_task_argument args RTEMS_UNUSED)
diff --git a/cpukit/include/rtems/rtems/event.h b/cpukit/include/rtems/rtems/event.h
index 1cd64c0cfa..0307fa4c8c 100644
--- a/cpukit/include/rtems/rtems/event.h
+++ b/cpukit/include/rtems/rtems/event.h
@@ -428,8 +428,7 @@ rtems_status_code rtems_event_system_receive(
  *   sc = rtems_event_transient_send(req->task_id);
  *   assert(sc == RTEMS_SUCCESSFUL);
- *   sc = rtems_task_delete(RTEMS_SELF);
- *   assert(sc == RTEMS_SUCCESSFUL);
+ *   rtems_task_exit();
  * void issue_request_and_wait_for_completion(void)
diff --git a/cpukit/include/rtems/status-checks.h b/cpukit/include/rtems/status-checks.h
index 54b045c6a0..94f30209c1 100644
--- a/cpukit/include/rtems/status-checks.h
+++ b/cpukit/include/rtems/status-checks.h
@@ -188,7 +188,7 @@ extern "C" {
 #define RTEMS_CHECK_SC_TASK( sc, msg) \
   if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
     RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
-    (void) rtems_task_delete( RTEMS_SELF); \
+    rtems_task_exit(); \
     return; \
   } else { \
     RTEMS_DEBUG_OK( msg); \
@@ -237,7 +237,7 @@ extern "C" {
 #define RTEMS_CHECK_RV_TASK( rv, msg) \
   if ((int) (rv) < 0) { \
     RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
     return; \
   } else { \
diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
index e2cdb900ca..1f34618274 100644
--- a/cpukit/libblock/src/bdbuf.c
+++ b/cpukit/libblock/src/bdbuf.c
@@ -2643,7 +2643,7 @@ rtems_bdbuf_swapout_worker_task (rtems_task_argument arg)
   free (worker);
@@ -2746,7 +2746,7 @@ rtems_bdbuf_swapout_task (rtems_task_argument arg)
   free (transfer);
 static void
@@ -2979,7 +2979,7 @@ rtems_bdbuf_read_ahead_task (rtems_task_argument arg)
     rtems_bdbuf_unlock_cache ();
 void rtems_bdbuf_get_device_stats (const rtems_disk_device *dd,
diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
index 2492efbaba..7cf8ca6814 100644
--- a/cpukit/libcsupport/src/termios.c
+++ b/cpukit/libcsupport/src/termios.c
@@ -1926,7 +1926,7 @@ static rtems_task rtems_termios_txdaemon(rtems_task_argument argument)
     if ((the_event & TERMIOS_TX_TERMINATE_EVENT) != 0) {
       tty->txTaskId = 0;
@@ -1974,7 +1974,7 @@ static rtems_task rtems_termios_rxdaemon(rtems_task_argument argument)
     if ((the_event & TERMIOS_RX_TERMINATE_EVENT) != 0) {
       tty->rxTaskId = 0;
diff --git a/cpukit/libdebugger/rtems-debugger-server.c b/cpukit/libdebugger/rtems-debugger-server.c
index 6e70d08ebf..411994d8bc 100644
--- a/cpukit/libdebugger/rtems-debugger-server.c
+++ b/cpukit/libdebugger/rtems-debugger-server.c
@@ -1691,7 +1691,7 @@ rtems_debugger_events(rtems_task_argument arg)
   if (rtems_debugger_verbose())
     rtems_debugger_printf("rtems-db: events finishing\n");
 static int
@@ -1913,7 +1913,7 @@ rtems_debugger_main(rtems_task_argument arg)
   rtems_debugger->server_finished = true;
   rtems_debugger_unlock();
 int
diff --git a/cpukit/libfs/src/nfsclient/src/nfs.c b/cpukit/libfs/src/nfsclient/src/nfs.c
index 6790c6bf77..ddb4dda313 100644
--- a/cpukit/libfs/src/nfsclient/src/nfs.c
+++ b/cpukit/libfs/src/nfsclient/src/nfs.c
@@ -3105,7 +3105,7 @@ rtems_filesystem_location_info_t	old;
 		rtems_filesystem_current->location = old;
 	rtems_binary_semaphore_post(&rpa->sync);
diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
index c37fae0c56..ee5d79051f 100644
--- a/cpukit/libmisc/cpuuse/cpuusagetop.c
+++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
@@ -495,7 +495,7 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
   data->thread_active = false;
 void rtems_cpu_usage_top_with_plugin(
diff --git a/cpukit/libmisc/monitor/mon-server.c b/cpukit/libmisc/monitor/mon-server.c
index 9949f66d63..3cb6cdf7ce 100644
--- a/cpukit/libmisc/monitor/mon-server.c
+++ b/cpukit/libmisc/monitor/mon-server.c
@@ -182,7 +182,7 @@ rtems_monitor_server_task(
 failed:
diff --git a/cpukit/libmisc/redirector/stdio-redirect.c b/cpukit/libmisc/redirector/stdio-redirect.c
index a756d5b3cb..7f3e9138a7 100644
--- a/cpukit/libmisc/redirector/stdio-redirect.c
+++ b/cpukit/libmisc/redirector/stdio-redirect.c
@@ -97,7 +97,7 @@ rtems_stdio_redirect_reader(rtems_task_argument arg)
   sr->state |= RTEMS_STDIO_REDIRECT_FINISHED;
 rtems_stdio_redirect*
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index b6aae781c5..d1fc9c65df 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -680,7 +680,7 @@ static rtems_task rtems_shell_task(rtems_task_argument task_argument)
   rtems_shell_main_loop( shell_env );
   if (wake_on_end != RTEMS_INVALID_ID)
     rtems_event_send (wake_on_end, RTEMS_EVENT_1);
-  rtems_task_delete( RTEMS_SELF );
 static bool rtems_shell_init_user_env(void)
diff --git a/cpukit/libnetworking/rtems/rtems_dhcp.c b/cpukit/libnetworking/rtems/rtems_dhcp.c
index ca89b19fd5..6d7a1cb892 100644
--- a/cpukit/libnetworking/rtems/rtems_dhcp.c
+++ b/cpukit/libnetworking/rtems/rtems_dhcp.c
@@ -796,7 +796,7 @@ dhcp_task (rtems_task_argument _sdl)
   dhcp_task_id = 0;
   printf ("dhcpc: exiting lease renewal task.\n");
-  rtems_task_delete( RTEMS_SELF);
diff --git a/cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c b/cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c
index 10ac661aee..65c107d19b 100644
--- a/cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c
+++ b/cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c
@@ -326,7 +326,7 @@ static void dhcp_monitor_task (rtems_task_argument ifp_arg)
 error_out:
   printf("Stopping dhcp monitoring application.\n");
diff --git a/cpukit/librpc/src/rpc/rtems_portmapper.c b/cpukit/librpc/src/rpc/rtems_portmapper.c
index 9d327b5ded..11724c1508 100644
--- a/cpukit/librpc/src/rpc/rtems_portmapper.c
+++ b/cpukit/librpc/src/rpc/rtems_portmapper.c
@@ -63,7 +63,7 @@ static rtems_task rtems_portmapper (rtems_task_argument unused)
 	rtems_rpc_task_init ();
 	if ((sock = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP)) < 0) {
 		perror("portmap cannot create socket");
 	addr.sin_addr.s_addr = 0;
@@ -72,13 +72,13 @@ static rtems_task rtems_portmapper (rtems_task_argument unused)
 	if (bind(sock, (struct sockaddr *)&addr, len) != 0) {
 		perror("portmap cannot bind");
 		close (sock);
 	if ((xprt = svcudp_create(sock)) == (SVCXPRT *)NULL) {
 		fprintf(stderr, "couldn't do udp_create\n");
 		close (sock);
 	/* make an entry for ourself */
 	pml = (struct pmaplist *)malloc(sizeof(struct pmaplist));
@@ -92,18 +92,18 @@ static rtems_task rtems_portmapper (rtems_task_argument unused)
 	if ((sock = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP)) < 0) {
 		close (sock);
 		close (sock);
 	if ((xprt = svctcp_create(sock, RPCSMALLMSGSIZE, RPCSMALLMSGSIZE))
 		fprintf(stderr, "couldn't do tcp_create\n");
 		close (sock);
@@ -119,7 +119,7 @@ static rtems_task rtems_portmapper (rtems_task_argument unused)
 	svc_run();
 	fprintf(stderr, "run_svc returned unexpectedly\n");
 	close (sock);
 static struct pmaplist *
diff --git a/cpukit/pppd/rtemspppd.c b/cpukit/pppd/rtemspppd.c
index 3d11638fdf..e6b1b18639 100644
--- a/cpukit/pppd/rtemspppd.c
+++ b/cpukit/pppd/rtemspppd.c
@@ -72,7 +72,7 @@ static rtems_task pppTask(rtems_task_argument arg)
   /* terminate myself */
   rtems_pppd_taskid = 0;
 int rtems_pppd_initialize(void)
diff --git a/cpukit/score/cpu/i386/sse_test.c b/cpukit/score/cpu/i386/sse_test.c
index 416a07f01a..dc87371c1f 100644
--- a/cpukit/score/cpu/i386/sse_test.c
+++ b/cpukit/score/cpu/i386/sse_test.c
@@ -766,7 +766,7 @@ bail:
 		rtems_task_delete( hp_task );
 	if ( ! (flags & SSE_TEST_NO_DEL) )
 static void
diff --git a/cpukit/telnetd/telnetd.c b/cpukit/telnetd/telnetd.c
index f68b08ab3c..81c03b164b 100644
--- a/cpukit/telnetd/telnetd.c
+++ b/cpukit/telnetd/telnetd.c
@@ -211,7 +211,7 @@ rtems_task_telnetd(void *task_argument)
   if ((des_socket=socket(PF_INET,SOCK_STREAM,0))<0) {
     perror("telnetd:socket");
   setsockopt(des_socket,SOL_SOCKET,SO_KEEPALIVE,&i,sizeof(i));
@@ -222,12 +222,12 @@ rtems_task_telnetd(void *task_argument)
   if ((bind(des_socket,&srv.sa,size_adr))<0) {
     perror("telnetd:bind");
     close(des_socket);
   if ((listen(des_socket,5))<0) {
     perror("telnetd:listen");
           close(des_socket);
   /* we don't redirect stdio as this probably
@@ -457,7 +457,7 @@ wrap_delete(rtems_task_argument arg)
   free(pwa);
   t(a);
 rtems_id
2.16.4
