[PATCH] config: Create a config directory and move the RTEMS arch/bsp data to it.
    chrisj at rtems.org
    chrisj at rtems.org
    Tue Oct  2 06:52:42 UTC 2018
Closes #3536
 {tester/rtems => config}/rtems-bsps-arm.ini      |   0
 {tester/rtems => config}/rtems-bsps-bfin.ini     |   0
 {tester/rtems => config}/rtems-bsps-epiphany.ini |   0
 {tester/rtems => config}/rtems-bsps-i386.ini     |   0
 {tester/rtems => config}/rtems-bsps-lm32.ini     |   0
 {tester/rtems => config}/rtems-bsps-m32c.ini     |   0
 {tester/rtems => config}/rtems-bsps-m68k.ini     |   0
 {tester/rtems => config}/rtems-bsps-mips.ini     |   0
 {tester/rtems => config}/rtems-bsps-moxie.ini    |   0
 {tester/rtems => config}/rtems-bsps-nios2.ini    |   0
 {tester/rtems => config}/rtems-bsps-or1k.ini     |   0
 {tester/rtems => config}/rtems-bsps-powerpc.ini  |   0
 {tester/rtems => config}/rtems-bsps-riscv.ini    |   0
 {tester/rtems => config}/rtems-bsps-riscv32.ini  |   0
 {tester/rtems => config}/rtems-bsps-riscv64.ini  |   0
 {tester/rtems => config}/rtems-bsps-sh.ini       |   0
 {tester/rtems => config}/rtems-bsps-sparc.ini    |   0
 {tester/rtems => config}/rtems-bsps-sparc64.ini  |   0
 {tester/rtems => config}/rtems-bsps-tiers.ini    |   0
 {tester/rtems => config}/rtems-bsps-v850.ini     |   0
 {tester/rtems => config}/rtems-bsps.ini          |   0
 config/wscript                                   |  44 +++
 rtemstoolkit/__init__.py                         |  12 +-
 rtemstoolkit/rtems.py                            | 372 +++++++++++++++++++++++
 rtemstoolkit/wscript                             |   1 +
 tester/rt/check.py                               | 341 +--------------------
 wscript                                          |   1 +
 27 files changed, 434 insertions(+), 337 deletions(-)
 rename {tester/rtems => config}/rtems-bsps-arm.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-bfin.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-epiphany.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-i386.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-lm32.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-m32c.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-m68k.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-mips.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-moxie.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-nios2.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-or1k.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-powerpc.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-riscv.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-riscv32.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-riscv64.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-sh.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-sparc.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-sparc64.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-tiers.ini (100%)
 rename {tester/rtems => config}/rtems-bsps-v850.ini (100%)
 rename {tester/rtems => config}/rtems-bsps.ini (100%)
 create mode 100644 config/wscript
 create mode 100755 rtemstoolkit/rtems.py
diff --git a/tester/rtems/rtems-bsps-arm.ini b/config/rtems-bsps-arm.ini
similarity index 100%
rename from tester/rtems/rtems-bsps-arm.ini
rename to config/rtems-bsps-arm.ini
diff --git a/tester/rtems/rtems-bsps-bfin.ini b/config/rtems-bsps-bfin.ini
rename from tester/rtems/rtems-bsps-bfin.ini
rename to config/rtems-bsps-bfin.ini
diff --git a/tester/rtems/rtems-bsps-epiphany.ini b/config/rtems-bsps-epiphany.ini
rename from tester/rtems/rtems-bsps-epiphany.ini
rename to config/rtems-bsps-epiphany.ini
diff --git a/tester/rtems/rtems-bsps-i386.ini b/config/rtems-bsps-i386.ini
rename from tester/rtems/rtems-bsps-i386.ini
rename to config/rtems-bsps-i386.ini
diff --git a/tester/rtems/rtems-bsps-lm32.ini b/config/rtems-bsps-lm32.ini
rename from tester/rtems/rtems-bsps-lm32.ini
rename to config/rtems-bsps-lm32.ini
diff --git a/tester/rtems/rtems-bsps-m32c.ini b/config/rtems-bsps-m32c.ini
rename from tester/rtems/rtems-bsps-m32c.ini
rename to config/rtems-bsps-m32c.ini
diff --git a/tester/rtems/rtems-bsps-m68k.ini b/config/rtems-bsps-m68k.ini
rename from tester/rtems/rtems-bsps-m68k.ini
rename to config/rtems-bsps-m68k.ini
diff --git a/tester/rtems/rtems-bsps-mips.ini b/config/rtems-bsps-mips.ini
rename from tester/rtems/rtems-bsps-mips.ini
rename to config/rtems-bsps-mips.ini
diff --git a/tester/rtems/rtems-bsps-moxie.ini b/config/rtems-bsps-moxie.ini
rename from tester/rtems/rtems-bsps-moxie.ini
rename to config/rtems-bsps-moxie.ini
diff --git a/tester/rtems/rtems-bsps-nios2.ini b/config/rtems-bsps-nios2.ini
rename from tester/rtems/rtems-bsps-nios2.ini
rename to config/rtems-bsps-nios2.ini
diff --git a/tester/rtems/rtems-bsps-or1k.ini b/config/rtems-bsps-or1k.ini
rename from tester/rtems/rtems-bsps-or1k.ini
rename to config/rtems-bsps-or1k.ini
diff --git a/tester/rtems/rtems-bsps-powerpc.ini b/config/rtems-bsps-powerpc.ini
rename from tester/rtems/rtems-bsps-powerpc.ini
rename to config/rtems-bsps-powerpc.ini
diff --git a/tester/rtems/rtems-bsps-riscv.ini b/config/rtems-bsps-riscv.ini
rename from tester/rtems/rtems-bsps-riscv.ini
rename to config/rtems-bsps-riscv.ini
diff --git a/tester/rtems/rtems-bsps-riscv32.ini b/config/rtems-bsps-riscv32.ini
rename from tester/rtems/rtems-bsps-riscv32.ini
rename to config/rtems-bsps-riscv32.ini
diff --git a/tester/rtems/rtems-bsps-riscv64.ini b/config/rtems-bsps-riscv64.ini
rename from tester/rtems/rtems-bsps-riscv64.ini
rename to config/rtems-bsps-riscv64.ini
diff --git a/tester/rtems/rtems-bsps-sh.ini b/config/rtems-bsps-sh.ini
rename from tester/rtems/rtems-bsps-sh.ini
rename to config/rtems-bsps-sh.ini
diff --git a/tester/rtems/rtems-bsps-sparc.ini b/config/rtems-bsps-sparc.ini
rename from tester/rtems/rtems-bsps-sparc.ini
rename to config/rtems-bsps-sparc.ini
diff --git a/tester/rtems/rtems-bsps-sparc64.ini b/config/rtems-bsps-sparc64.ini
rename from tester/rtems/rtems-bsps-sparc64.ini
rename to config/rtems-bsps-sparc64.ini
diff --git a/tester/rtems/rtems-bsps-tiers.ini b/config/rtems-bsps-tiers.ini
rename from tester/rtems/rtems-bsps-tiers.ini
rename to config/rtems-bsps-tiers.ini
diff --git a/tester/rtems/rtems-bsps-v850.ini b/config/rtems-bsps-v850.ini
rename from tester/rtems/rtems-bsps-v850.ini
rename to config/rtems-bsps-v850.ini
diff --git a/tester/rtems/rtems-bsps.ini b/config/rtems-bsps.ini
rename from tester/rtems/rtems-bsps.ini
rename to config/rtems-bsps.ini
diff --git a/config/wscript b/config/wscript
new file mode 100644
index 0000000..6ae6226
--- /dev/null
+++ b/config/wscript
@@ -0,0 +1,44 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2018 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+def options(opt):
+    opt.load('python')
+def configure(opt):
+    pass
+def build(bld):
+    # Install the configuration files.
+    config = bld.path.find_dir('.')
+    bld.install_files('${PREFIX}/share/rtems/config',
+                      config.ant_glob('**/*.ini'), cwd = config,
+                      relative_trick = True)
diff --git a/rtemstoolkit/__init__.py b/rtemstoolkit/__init__.py
index ca2d619..6878782 100644
--- a/rtemstoolkit/__init__.py
+++ b/rtemstoolkit/__init__.py
@@ -1,6 +1,6 @@
-# Copyright 2010-2016 Chris Johns (chrisj at rtems.org)
+# Copyright 2010-2018 Chris Johns (chrisj at rtems.org)
@@ -30,26 +30,36 @@
 all = ['check',
        'config',
+       'configuration',
        'error',
        'execute',
        'git',
+       'host',
        'log',
        'macros',
        'mailer',
        'options',
        'path',
        'reraise',
+       'rtems',
+       'stacktraces',
+       'textbox',
        'version']
 from . import check
 from . import config
+from . import configuration
 from . import error
 from . import execute
 from . import git
+from . import host
 from . import log
 from . import macros
 from . import mailer
 from . import options
 from . import path
 from . import reraise
+from . import rtems
+from . import stacktraces
+from . import textbox
 from . import version
diff --git a/rtemstoolkit/rtems.py b/rtemstoolkit/rtems.py
new file mode 100755
index 0000000..13b1e7a
--- /dev/null
+++ b/rtemstoolkit/rtems.py
@@ -0,0 +1,372 @@
+# Copyright 20162018 Chris Johns (chrisj at rtems.org)
+from __future__ import print_function
+import copy
+import os
+import re
+import textwrap
+from rtemstoolkit import configuration as configuration_
+from rtemstoolkit import error
+from rtemstoolkit import textbox
+from rtemstoolkit import version
+def clean_windows_path():
+    # On Windows MSYS2 prepends a path to itself to the environment
+    # path. This means the RTEMS specific automake is not found and which
+    # breaks the bootstrap. We need to remove the prepended path. Also
+    # remove any ACLOCAL paths from the environment.
+    if os.name == 'nt':
+        cspath = os.environ['PATH'].split(os.pathsep)
+        if 'msys' in cspath[0] and cspath[0].endswith('bin'):
+            os.environ['PATH'] = os.pathsep.join(cspath[1:])
+class configuration:
+    def __init__(self):
+        self.config = configuration_.configuration()
+        self.archs = { }
+        self.profiles = { }
+    def __str__(self):
+        s = self.name + os.linesep
+        s += 'Archs:' + os.linesep + \
+             pprint.pformat(self.archs, indent = 1, width = 80) + os.linesep
+        s += 'Profiles:' + os.linesep + \
+             pprint.pformat(self.profiles, indent = 1, width = 80) + os.linesep
+        return s
+    def _build_options(self, build, nesting = 0):
+        if ':' in build:
+            section, name = build.split(':', 1)
+            opts = [self.config.get_item(section, name)]
+            return opts
+        builds = self.builds_['builds']
+        if build not in builds:
+            raise error.general('build %s not found' % (build))
+        if nesting > 20:
+            raise error.general('nesting build %s' % (build))
+        options = []
+        for option in self.builds_['builds'][build]:
+            if ':' in option:
+                section, name = option.split(':', 1)
+            else:
+                opts = self._build_options(option, nesting + 1)
+            for opt in opts:
+                if opt not in options:
+                    options += [opt]
+        return options
+    def load(self, name, build):
+        self.config.load(name)
+        archs = []
+        self.profiles['profiles'] = \
+            self.config.comma_list('profiles', 'profiles', err = False)
+        if len(self.profiles['profiles']) == 0:
+            self.profiles['profiles'] = ['tier-%d' % (t) for t in range(1,4)]
+        for p in self.profiles['profiles']:
+            profile = {}
+            profile['name'] = p
+            profile['archs'] = self.config.comma_list(profile['name'], 'archs', err = False)
+            archs += profile['archs']
+            for arch in profile['archs']:
+                bsps = 'bsps_%s' % (arch)
+                profile[bsps] = self.config.comma_list(profile['name'], bsps)
+            self.profiles[profile['name']] = profile
+        invalid_chars = re.compile(r'[^a-zA-Z0-9_-]')
+        for a in set(archs):
+            if len(invalid_chars.findall(a)) != 0:
+                raise error.general('invalid character(s) in arch name: %s' % (a))
+            arch = {}
+            arch['excludes'] = {}
+            for exclude in self.config.comma_list(a, 'exclude', err = False):
+                arch['excludes'][exclude] = ['all']
+            for i in self.config.get_items(a, False):
+                if i[0].startswith('exclude-'):
+                    exclude = i[0][len('exclude-'):]
+                    if exclude not in arch['excludes']:
+                        arch['excludes'][exclude] = []
+                    arch['excludes'][exclude] += \
+                        sorted(set([b.strip() for b in i[1].split(',')]))
+            arch['bsps'] = self.config.comma_list(a, 'bsps', err = False)
+            for b in arch['bsps']:
+                if len(invalid_chars.findall(b)) != 0:
+                    raise error.general('invalid character(s) in BSP name: %s' % (b))
+                arch[b] = {}
+                arch[b]['bspopts'] = \
+                    self.config.comma_list(a, 'bspopts_%s' % (b), err = False)
+            self.archs[a] = arch
+        builds = {}
+        builds['default'] = self.config.get_item('builds', 'default')
+        if build is None:
+            build = builds['default']
+        builds['config'] = { }
+        for config in self.config.get_items('config'):
+            builds['config'][config[0]] = config[1]
+        builds['build'] = build
+        builds_ = self.config.get_item_names('builds')
+        builds['builds'] = {}
+        for build in builds_:
+            build_builds = self.config.comma_list('builds', build)
+            has_config = False
+            has_build = False
+            for b in build_builds:
+                if ':' in b:
+                    if has_build:
+                        raise error.general('config and build in build: %s' % (build))
+                    has_config = True
+                else:
+                    if has_config:
+                    has_build = True
+            builds['builds'][build] = build_builds
+        self.builds_ = builds
+    def configs(self):
+        return sorted(list(self.builds_['config'].keys()))
+    def config_flags(self, config):
+        if config not in self.builds_['config']:
+            raise error.general('config entry not found: %s' % (config))
+        return self.builds_['config'][config]
+    def build(self):
+        return self.builds_['build']
+    def builds(self):
+        if self.builds_['build'] in self.builds_['builds']:
+            build = copy.copy(self.builds_['builds'][self.builds_['build']])
+            if ':' in build[0]:
+                return [self.builds_['build']]
+            return build
+        return None
+    def build_options(self, build):
+        return ' '.join(self._build_options(build))
+    def excludes(self, arch, bsp):
+        return list(set(self.arch_excludes(arch) + self.bsp_excludes(arch, bsp)))
+    def exclude_options(self, arch, bsp):
+        return ' '.join([self.config_flags('no-' + e) for e in self.excludes(arch, bsp)])
+    def archs(self):
+        return sorted(self.archs.keys())
+    def arch_present(self, arch):
+        return arch in self.archs
+    def arch_excludes(self, arch):
+        excludes = self.archs[arch]['excludes'].keys()
+        for exclude in self.archs[arch]['excludes']:
+            if 'all' not in self.archs[arch]['excludes'][exclude]:
+                excludes.remove(exclude)
+        return sorted(excludes)
+    def arch_bsps(self, arch):
+        return sorted(self.archs[arch]['bsps'])
+    def bsp_present(self, arch, bsp):
+        return bsp in self.archs[arch]['bsps']
+    def bsp_excludes(self, arch, bsp):
+            if 'all' not in self.archs[arch]['excludes'][exclude] and \
+               bsp not in self.archs[arch]['excludes'][exclude]:
+    def bspopts(self, arch, bsp):
+        if arch not in self.archs:
+            raise error.general('invalid architecture: %s' % (arch))
+        if bsp not in self.archs[arch]:
+            raise error.general('invalid BSP: %s' % (bsp))
+        return self.archs[arch][bsp]['bspopts']
+    def profile_present(self, profile):
+        return profile in self.profiles
+    def profile_archs(self, profile):
+        if profile not in self.profiles:
+            raise error.general('invalid profile: %s' % (profile))
+        return self.profiles[profile]['archs']
+    def profile_arch_bsps(self, profile, arch):
+        if 'bsps_%s' % (arch) not in self.profiles[profile]:
+            raise error.general('invalid profile arch: %s' % (arch))
+        return ['%s/%s' % (arch, bsp) for bsp in self.profiles[profile]['bsps_%s' % (arch)]]
+    def report(self, profiles = True, builds = True, architectures = True):
+        width = 70
+        cols_1 = [width]
+        cols_2 = [10, width - 10]
+        s = textbox.line(cols_1, line = '=', marker = '+', indent = 1)
+        s1 = ' File(s)'
+        for f in self.config.files():
+            colon = ':'
+            for l in textwrap.wrap(f, width = cols_2[1] - 3):
+                s += textbox.row(cols_2, [s1, ' ' + l], marker = colon, indent = 1)
+                colon = ' '
+                s1 = ' ' * len(s1)
+        s += textbox.line(cols_1, marker = '+', indent = 1)
+        s += os.linesep
+        if profiles:
+            s += textbox.line(cols_1, line = '=', marker = '+', indent = 1)
+            profiles = sorted(self.profiles['profiles'])
+            archs = []
+            bsps = []
+            for profile in profiles:
+                archs += self.profiles[profile]['archs']
+                for arch in sorted(self.profiles[profile]['archs']):
+                    bsps += self.profiles[profile]['bsps_%s' % (arch)]
+            archs = len(set(archs))
+            bsps = len(set(bsps))
+            s += textbox.row(cols_1,
+                             [' Profiles : %d (archs:%d, bsps:%d)' % \
+                              (len(profiles), archs, bsps)],
+                             indent = 1)
+                textbox.row(cols_2,
+                            [profile, self.profiles[profile]['name']],
+                            indent = 1)
+                s += textbox.row(cols_1, [' %s' % (profile)], indent = 1)
+                profile = self.profiles[profile]
+                archs = sorted(profile['archs'])
+                for arch in archs:
+                    arch_bsps = ', '.join(profile['bsps_%s' % (arch)])
+                    if len(arch_bsps) > 0:
+                        s += textbox.line(cols_2, marker = '+', indent = 1)
+                        s1 = ' ' + arch
+                        for l in textwrap.wrap(arch_bsps,
+                                               width = cols_2[1] - 3):
+                            s += textbox.row(cols_2, [s1, ' ' + l], indent = 1)
+            s += os.linesep
+        if builds:
+                             [' Builds:  %s (default)' % (self.builds_['default'])],
+                             indent = 1)
+            bsize = 0
+            for build in builds:
+                if len(build) > bsize:
+                    bsize = len(build)
+            cols_b = [bsize + 2, width - bsize - 2]
+            s += textbox.line(cols_b, marker = '+', indent = 1)
+                s1 = ' ' + build
+                for l in textwrap.wrap(', '.join(builds[build]),
+                                       width = cols_b[1] - 3):
+                    s += textbox.row(cols_b, [s1, ' ' + l], indent = 1)
+            configs = self.builds_['config']
+                             [' Configure Options: %d' % (len(configs))],
+                             indent = 1)
+            csize = 0
+            for config in configs:
+                if len(config) > csize:
+                    csize = len(config)
+            cols_c = [csize + 3, width - csize - 3]
+            s += textbox.line(cols_c, marker = '+', indent = 1)
+                s1 = ' ' + config
+                for l in textwrap.wrap(configs[config], width = cols_c[1] - 3):
+                    s += textbox.row(cols_c, [s1, ' ' + l], indent = 1)
+            s += os.linesep
+        if architectures:
+            archs = sorted(self.archs.keys())
+            bsps = 0
+            asize = 0
+                if len(arch) > asize:
+                    asize = len(arch)
+                bsps += len(self.archs[arch]['bsps'])
+                             [' Architectures : %d (bsps: %d)' % (len(archs), bsps)],
+                             indent = 1)
+            cols_a = [asize + 2, width - asize - 2]
+            s += textbox.line(cols_a, marker = '+', indent = 1)
+                s += textbox.row(cols_a,
+                                 [' ' + arch, ' %d' % (len(self.archs[arch]['bsps']))],
+                                 indent = 1)
+            for archn in archs:
+                arch = self.archs[archn]
+                if len(arch['bsps']) > 0:
+                    bsize = 0
+                    for bsp in arch['bsps']:
+                        if len(bsp) > bsize:
+                            bsize = len(bsp)
+                    cols_b = [bsize + 3, width - bsize - 3]
+                    s += textbox.row(cols_1, [' ' + archn + ':'], indent = 1)
+                        s1 = ' ' + bsp
+                        bspopts = ' '.join(arch[bsp]['bspopts'])
+                        if len(bspopts):
+                            for l in textwrap.wrap('bopt: ' + bspopts,
+                        excludes = []
+                        for exclude in arch['excludes']:
+                            if 'all' in arch['excludes'][exclude] or \
+                               bsp in arch['excludes'][exclude]:
+                                excludes += [exclude]
+                        excludes = ', '.join(excludes)
+                        if len(excludes):
+                            for l in textwrap.wrap('ex: ' + excludes,
+                        if len(bspopts) == 0 and len(excludes) == 0:
+                            s += textbox.row(cols_b, [s1, ' '], indent = 1)
+            s += os.linesep
+        return s
diff --git a/rtemstoolkit/wscript b/rtemstoolkit/wscript
index 4b5fa34..1b124c7 100644
--- a/rtemstoolkit/wscript
+++ b/rtemstoolkit/wscript
@@ -148,6 +148,7 @@ def build(bld):
                   'options.py',
                   'path.py',
                   'reraise.py',
+                  'rtems.py',
                   'stacktraces.py',
                   'textbox.py',
                   'version.py',
diff --git a/tester/rt/check.py b/tester/rt/check.py
index e202946..0f9ee13 100755
--- a/tester/rt/check.py
+++ b/tester/rt/check.py
@@ -44,13 +44,13 @@ import traceback
 import pprint
-from rtemstoolkit import configuration
 from rtemstoolkit import execute
 from rtemstoolkit import host
 from rtemstoolkit import log
 from rtemstoolkit import mailer
 from rtemstoolkit import path
+from rtemstoolkit import rtems
@@ -880,327 +880,6 @@ class arch_bsp_builder:
             self._notice('Cleaning: %s' % (self._build_dir()))
             path.removeall(self._build_dir())
-class configuration_:
-    def __init__(self):
-        self.config = configuration.configuration()
-        self.archs = { }
-        self.builds_ = { }
-        self.profiles = { }
-    def __str__(self):
-        s = self.name + os.linesep
-        s += 'Archs:' + os.linesep + \
-             pprint.pformat(self.archs, indent = 1, width = 80) + os.linesep
-        s += 'Builds:' + os.linesep + \
-             pprint.pformat(self.builds_, indent = 1, width = 80) + os.linesep
-        s += 'Profiles:' + os.linesep + \
-             pprint.pformat(self.profiles, indent = 1, width = 80) + os.linesep
-        return s
-    def _build_options(self, build, nesting = 0):
-        if ':' in build:
-            section, name = build.split(':', 1)
-            opts = [self.config.get_item(section, name)]
-            return opts
-        builds = self.builds_['builds']
-        if build not in builds:
-            raise error.general('build %s not found' % (build))
-        if nesting > 20:
-            raise error.general('nesting build %s' % (build))
-        options = []
-        for option in self.builds_['builds'][build]:
-            if ':' in option:
-                section, name = option.split(':', 1)
-            else:
-                opts = self._build_options(option, nesting + 1)
-            for opt in opts:
-                if opt not in options:
-                    options += [opt]
-        return options
-    def load(self, name, build):
-        self.config.load(name)
-        archs = []
-        self.profiles['profiles'] = \
-            self.config.comma_list('profiles', 'profiles', err = False)
-        if len(self.profiles['profiles']) == 0:
-            self.profiles['profiles'] = ['tier-%d' % (t) for t in range(1,4)]
-        for p in self.profiles['profiles']:
-            profile = {}
-            profile['name'] = p
-            profile['archs'] = self.config.comma_list(profile['name'], 'archs', err = False)
-            archs += profile['archs']
-            for arch in profile['archs']:
-                bsps = 'bsps_%s' % (arch)
-                profile[bsps] = self.config.comma_list(profile['name'], bsps)
-            self.profiles[profile['name']] = profile
-        invalid_chars = re.compile(r'[^a-zA-Z0-9_-]')
-        for a in set(archs):
-            if len(invalid_chars.findall(a)) != 0:
-                raise error.general('invalid character(s) in arch name: %s' % (a))
-            arch = {}
-            arch['excludes'] = {}
-            for exclude in self.config.comma_list(a, 'exclude', err = False):
-                arch['excludes'][exclude] = ['all']
-            for i in self.config.get_items(a, False):
-                if i[0].startswith('exclude-'):
-                    exclude = i[0][len('exclude-'):]
-                    if exclude not in arch['excludes']:
-                        arch['excludes'][exclude] = []
-                    arch['excludes'][exclude] += \
-                        sorted(set([b.strip() for b in i[1].split(',')]))
-            arch['bsps'] = self.config.comma_list(a, 'bsps', err = False)
-            for b in arch['bsps']:
-                if len(invalid_chars.findall(b)) != 0:
-                    raise error.general('invalid character(s) in BSP name: %s' % (b))
-                arch[b] = {}
-                arch[b]['bspopts'] = \
-                    self.config.comma_list(a, 'bspopts_%s' % (b), err = False)
-            self.archs[a] = arch
-        builds = {}
-        builds['default'] = self.config.get_item('builds', 'default')
-        if build is None:
-            build = builds['default']
-        builds['config'] = { }
-        for config in self.config.get_items('config'):
-            builds['config'][config[0]] = config[1]
-        builds['build'] = build
-        builds_ = self.config.get_item_names('builds')
-        builds['builds'] = {}
-        for build in builds_:
-            build_builds = self.config.comma_list('builds', build)
-            has_config = False
-            has_build = False
-            for b in build_builds:
-                if ':' in b:
-                    if has_build:
-                        raise error.general('config and build in build: %s' % (build))
-                    has_config = True
-                else:
-                    if has_config:
-                    has_build = True
-            builds['builds'][build] = build_builds
-        self.builds_ = builds
-    def configs(self):
-        return sorted(list(self.builds_['config'].keys()))
-    def config_flags(self, config):
-        if config not in self.builds_['config']:
-            raise error.general('config entry not found: %s' % (config))
-        return self.builds_['config'][config]
-    def build(self):
-        return self.builds_['build']
-    def builds(self):
-        if self.builds_['build'] in self.builds_['builds']:
-            build = copy.copy(self.builds_['builds'][self.builds_['build']])
-            if ':' in build[0]:
-                return [self.builds_['build']]
-            return build
-        return None
-    def build_options(self, build):
-        return ' '.join(self._build_options(build))
-    def excludes(self, arch, bsp):
-        return list(set(self.arch_excludes(arch) + self.bsp_excludes(arch, bsp)))
-    def exclude_options(self, arch, bsp):
-        return ' '.join([self.config_flags('no-' + e) for e in self.excludes(arch, bsp)])
-    def archs(self):
-        return sorted(self.archs.keys())
-    def arch_present(self, arch):
-        return arch in self.archs
-    def arch_excludes(self, arch):
-        excludes = self.archs[arch]['excludes'].keys()
-        for exclude in self.archs[arch]['excludes']:
-            if 'all' not in self.archs[arch]['excludes'][exclude]:
-                excludes.remove(exclude)
-        return sorted(excludes)
-    def arch_bsps(self, arch):
-        return sorted(self.archs[arch]['bsps'])
-    def bsp_present(self, arch, bsp):
-        return bsp in self.archs[arch]['bsps']
-    def bsp_excludes(self, arch, bsp):
-            if 'all' not in self.archs[arch]['excludes'][exclude] and \
-               bsp not in self.archs[arch]['excludes'][exclude]:
-    def bspopts(self, arch, bsp):
-        if arch not in self.archs:
-            raise error.general('invalid architecture: %s' % (arch))
-        if bsp not in self.archs[arch]:
-            raise error.general('invalid BSP: %s' % (bsp))
-        return self.archs[arch][bsp]['bspopts']
-    def profile_present(self, profile):
-        return profile in self.profiles
-    def profile_archs(self, profile):
-        if profile not in self.profiles:
-            raise error.general('invalid profile: %s' % (profile))
-        return self.profiles[profile]['archs']
-    def profile_arch_bsps(self, profile, arch):
-        if 'bsps_%s' % (arch) not in self.profiles[profile]:
-            raise error.general('invalid profile arch: %s' % (arch))
-        return ['%s/%s' % (arch, bsp) for bsp in self.profiles[profile]['bsps_%s' % (arch)]]
-    def report(self, profiles = True, builds = True, architectures = True):
-        width = 70
-        cols_1 = [width]
-        cols_2 = [10, width - 10]
-        s = textbox.line(cols_1, line = '=', marker = '+', indent = 1)
-        s1 = ' File(s)'
-        for f in self.config.files():
-            colon = ':'
-            for l in textwrap.wrap(f, width = cols_2[1] - 3):
-                s += textbox.row(cols_2, [s1, ' ' + l], marker = colon, indent = 1)
-                colon = ' '
-                s1 = ' ' * len(s1)
-        s += textbox.line(cols_1, marker = '+', indent = 1)
-        s += os.linesep
-        if profiles:
-            s += textbox.line(cols_1, line = '=', marker = '+', indent = 1)
-            profiles = sorted(self.profiles['profiles'])
-            archs = []
-            bsps = []
-            for profile in profiles:
-                archs += self.profiles[profile]['archs']
-                for arch in sorted(self.profiles[profile]['archs']):
-                    bsps += self.profiles[profile]['bsps_%s' % (arch)]
-            archs = len(set(archs))
-            bsps = len(set(bsps))
-            s += textbox.row(cols_1,
-                             [' Profiles : %d (archs:%d, bsps:%d)' % \
-                              (len(profiles), archs, bsps)],
-                             indent = 1)
-                textbox.row(cols_2,
-                            [profile, self.profiles[profile]['name']],
-                            indent = 1)
-                s += textbox.row(cols_1, [' %s' % (profile)], indent = 1)
-                profile = self.profiles[profile]
-                archs = sorted(profile['archs'])
-                for arch in archs:
-                    arch_bsps = ', '.join(profile['bsps_%s' % (arch)])
-                    if len(arch_bsps) > 0:
-                        s += textbox.line(cols_2, marker = '+', indent = 1)
-                        s1 = ' ' + arch
-                        for l in textwrap.wrap(arch_bsps,
-                                               width = cols_2[1] - 3):
-                            s += textbox.row(cols_2, [s1, ' ' + l], indent = 1)
-            s += os.linesep
-        if builds:
-                             [' Builds:  %s (default)' % (self.builds_['default'])],
-                             indent = 1)
-            bsize = 0
-            for build in builds:
-                if len(build) > bsize:
-                    bsize = len(build)
-            cols_b = [bsize + 2, width - bsize - 2]
-            s += textbox.line(cols_b, marker = '+', indent = 1)
-                s1 = ' ' + build
-                for l in textwrap.wrap(', '.join(builds[build]),
-                                       width = cols_b[1] - 3):
-                    s += textbox.row(cols_b, [s1, ' ' + l], indent = 1)
-            configs = self.builds_['config']
-                             [' Configure Options: %d' % (len(configs))],
-                             indent = 1)
-            csize = 0
-            for config in configs:
-                if len(config) > csize:
-                    csize = len(config)
-            cols_c = [csize + 3, width - csize - 3]
-            s += textbox.line(cols_c, marker = '+', indent = 1)
-                s1 = ' ' + config
-                for l in textwrap.wrap(configs[config], width = cols_c[1] - 3):
-                    s += textbox.row(cols_c, [s1, ' ' + l], indent = 1)
-            s += os.linesep
-        if architectures:
-            archs = sorted(self.archs.keys())
-            bsps = 0
-            asize = 0
-                if len(arch) > asize:
-                    asize = len(arch)
-                bsps += len(self.archs[arch]['bsps'])
-                             [' Architectures : %d (bsps: %d)' % (len(archs), bsps)],
-                             indent = 1)
-            cols_a = [asize + 2, width - asize - 2]
-            s += textbox.line(cols_a, marker = '+', indent = 1)
-                s += textbox.row(cols_a,
-                                 [' ' + arch, ' %d' % (len(self.archs[arch]['bsps']))],
-                                 indent = 1)
-            for archn in archs:
-                arch = self.archs[archn]
-                if len(arch['bsps']) > 0:
-                    bsize = 0
-                    for bsp in arch['bsps']:
-                        if len(bsp) > bsize:
-                            bsize = len(bsp)
-                    cols_b = [bsize + 3, width - bsize - 3]
-                    s += textbox.row(cols_1, [' ' + archn + ':'], indent = 1)
-                        s1 = ' ' + bsp
-                        bspopts = ' '.join(arch[bsp]['bspopts'])
-                        if len(bspopts):
-                            for l in textwrap.wrap('bopt: ' + bspopts,
-                        excludes = []
-                        for exclude in arch['excludes']:
-                            if 'all' in arch['excludes'][exclude] or \
-                               bsp in arch['excludes'][exclude]:
-                                excludes += [exclude]
-                        excludes = ', '.join(excludes)
-                        if len(excludes):
-                            for l in textwrap.wrap('ex: ' + excludes,
-                        if len(bspopts) == 0 and len(excludes) == 0:
-                            s += textbox.row(cols_b, [s1, ' '], indent = 1)
-            s += os.linesep
-        return s
 class build_jobs:
     def __init__(self, config, arch, bsp):
@@ -1442,16 +1121,7 @@ def run_args(args):
     b = None
     ec = 0
     try:
-        # On Windows MSYS2 prepends a path to itself to the environment
-        # path. This means the RTEMS specific automake is not found and which
-        # breaks the bootstrap. We need to remove the prepended path. Also
-        # remove any ACLOCAL paths from the environment.
-        if os.name == 'nt':
-            cspath = os.environ['PATH'].split(os.pathsep)
-            if 'msys' in cspath[0] and cspath[0].endswith('bin'):
-                os.environ['PATH'] = os.pathsep.join(cspath[1:])
+        rtems.clean_windows_path()
         start = datetime.datetime.now()
         top = os.path.dirname(os.path.dirname(os.path.abspath(sys.argv[0])))
@@ -1460,10 +1130,9 @@ def run_args(args):
         build_dir = 'bsp-builds'
         logf = 'bsp-build-%s.txt' % \
                (datetime.datetime.now().strftime('%Y%m%d-%H%M%S'))
-        config_file = path.join(top, 'share', 'rtems', 'tester',
-                                'rtems', 'rtems-bsps.ini')
+        config_file = path.join(top, 'config', 'rtems-bsps.ini')
         if not path.exists(config_file):
-            config_file = path.join(top, 'tester', 'rtems', 'rtems-bsps.ini')
+            config_file = path.join(top, 'share', 'rtems', 'config', 'rtems-bsps.ini')
         argsp = argparse.ArgumentParser()
         argsp.add_argument('--prefix', help = 'Prefix to build the BSP.',
@@ -1521,7 +1190,7 @@ def run_args(args):
                                                         to_addr,
                                                         smtp_host))
-        config = configuration_()
+        config = rtems.configuration()
         config.load(config_file, opts.build)
         if opts.config_report:
diff --git a/wscript b/wscript
index 1716b90..c0286de 100644
--- a/wscript
+++ b/wscript
@@ -33,6 +33,7 @@ import os.path
 import wafwindows
 subdirs = ['rtemstoolkit',
+           'config',
            'linkers',
            'misc',
            'tester',
2.15.1
