[PATCH] score: Fix legacy RTEMS_STATIC_ASSERT()
Fri Oct 5 06:31:31 UTC 2018
In standard C pointer operands are not allowed in integer constant
expression.  Avoid a static assertion based on an array typedef since
this could lead to warnings ("variably modified 'x' at file scope" and
"typedef 'x' locally defined but not used");
This implementation requires unique messages.
 cpukit/include/rtems/score/basedefs.h    |  3 ++-
 cpukit/include/rtems/score/threadqimpl.h |  4 ++--
 cpukit/posix/src/mqueuerecvsupp.c        |  3 ++-
 cpukit/posix/src/mutexinit.c             |  2 +-
 cpukit/rtems/src/barrierwait.c           |  6 +++++-
 cpukit/rtems/src/msgqreceive.c           |  6 +++++-
 cpukit/rtems/src/semobtain.c             | 12 ++++++++----
 7 files changed, 25 insertions(+), 11 deletions(-)
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index fd803e1b45..0a2bf8dd17 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -317,7 +317,8 @@
     _Static_assert(cond, # msg)
 #else
   #define RTEMS_STATIC_ASSERT(cond, msg) \
-    typedef int rtems_static_assert_ ## msg [(cond) ? 1 : -1]
+    struct rtems_static_assert_ ## msg \
+      { int rtems_static_assert_ ## msg : (cond) ? 1 : -1; }
 #endif
 #define RTEMS_ARRAY_SIZE(array) (sizeof(array) / sizeof((array)[0]))
diff --git a/cpukit/include/rtems/score/threadqimpl.h b/cpukit/include/rtems/score/threadqimpl.h
index ecbd8fd42f..8d537cc9e3 100644
--- a/cpukit/include/rtems/score/threadqimpl.h
+++ b/cpukit/include/rtems/score/threadqimpl.h
@@ -1207,7 +1207,7 @@ typedef struct {
   Thread_queue_Control Wait_queue;
 } Thread_queue_Object;
-#define THREAD_QUEUE_OBJECT_ASSERT( object_type, wait_queue_member ) \
+#define THREAD_QUEUE_OBJECT_ASSERT( object_type, wait_queue_member, msg ) \
   RTEMS_STATIC_ASSERT( \
     offsetof( object_type, wait_queue_member ) \
       == offsetof( Thread_queue_Object, Wait_queue ) \
@@ -1217,7 +1217,7 @@ typedef struct {
       Thread_queue_Object, \
       Wait_queue \
-    object_type \
+    msg \
 #define THREAD_QUEUE_QUEUE_TO_OBJECT( queue ) \
diff --git a/cpukit/posix/src/mqueuerecvsupp.c b/cpukit/posix/src/mqueuerecvsupp.c
index c6d1805214..062bd50dbf 100644
--- a/cpukit/posix/src/mqueuerecvsupp.c
+++ b/cpukit/posix/src/mqueuerecvsupp.c
@@ -25,7 +25,8 @@
   POSIX_Message_queue_Control,
-  Message_queue.Wait_queue
+  Message_queue.Wait_queue,
+  POSIX_MESSAGE_QUEUE_CONTROL
diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
index 2d3857da75..45688eec1a 100644
--- a/cpukit/posix/src/mutexinit.c
+++ b/cpukit/posix/src/mutexinit.c
@@ -40,7 +40,7 @@ RTEMS_STATIC_ASSERT(
   offsetof( POSIX_Mutex_Control, Priority_ceiling )
     == offsetof( pthread_mutex_t, _Priority_ceiling ),
-  POSIX_MUTEX_CONTROL_SCHEDULER
+  POSIX_MUTEX_CONTROL_PRIORITY_CEILING
diff --git a/cpukit/rtems/src/barrierwait.c b/cpukit/rtems/src/barrierwait.c
index 4811c218b8..f30f152abe 100644
--- a/cpukit/rtems/src/barrierwait.c
+++ b/cpukit/rtems/src/barrierwait.c
@@ -21,7 +21,11 @@
 #include <rtems/rtems/barrierimpl.h>
 #include <rtems/rtems/statusimpl.h>
-THREAD_QUEUE_OBJECT_ASSERT( Barrier_Control, Barrier.Wait_queue );
+THREAD_QUEUE_OBJECT_ASSERT(
+  Barrier_Control,
+  Barrier.Wait_queue,
+  BARRIER_CONTROL
 rtems_status_code rtems_barrier_wait(
   rtems_id        id,
diff --git a/cpukit/rtems/src/msgqreceive.c b/cpukit/rtems/src/msgqreceive.c
index 2304be735a..606454d7c4 100644
--- a/cpukit/rtems/src/msgqreceive.c
+++ b/cpukit/rtems/src/msgqreceive.c
@@ -22,7 +22,11 @@
 #include <rtems/rtems/optionsimpl.h>
-THREAD_QUEUE_OBJECT_ASSERT( Message_queue_Control, message_queue.Wait_queue );
+  Message_queue_Control,
+  message_queue.Wait_queue,
+  MESSAGE_QUEUE_CONTROL
 rtems_status_code rtems_message_queue_receive(
   rtems_id        id,
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index db0c3f2e0c..2f73166df0 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -24,23 +24,27 @@
   Semaphore_Control,
-  Core_control.Wait_queue
+  Core_control.Wait_queue,
+  SEMAPHORE_CONTROL_GENERIC
   Semaphore_Control,
-  Core_control.Mutex.Recursive.Mutex.Wait_queue
+  Core_control.Mutex.Recursive.Mutex.Wait_queue,
+  SEMAPHORE_CONTROL_MUTEX
   Semaphore_Control,
-  Core_control.Semaphore.Wait_queue
+  Core_control.Semaphore.Wait_queue,
+  SEMAPHORE_CONTROL_SEMAPHORE
 #if defined(RTEMS_SMP)
   Semaphore_Control,
-  Core_control.MRSP.Wait_queue
+  Core_control.MRSP.Wait_queue,
+  SEMAPHORE_CONTROL_MRSP
 #endif
2.16.4
